Mods - please delete. New thread started!
Postby Gadget on Mon Apr 14, 2014 11:16 pm
Gadget
Your car: 05 Mondeo ST Tdci & FRST
Re: Breaking Fiesta Rs turbo track car / Zetec Turbo - Loads new
Postby Gadget on Tue Apr 15, 2014 8:58 am
New FRST header tank ( still with ford stickers on ) £40
New Mondeo zetec alternator £35 ( was gonna use with my zetec turbo )
Gadget
Postby reithy on Tue Apr 15, 2014 10:31 am
I'll take the water hoses and the starter motor how much posted?
reithy
Postby Gadget on Tue Apr 15, 2014 12:42 pm
The standard hoses?
£12 next day for the hoses and starter.
Whereabouts are you? I'm near Romford Essex on Saturday
Text me as I'm about to leave for work 07946367994
Gadget
Postby rsturbonutter on Tue Apr 15, 2014 12:51 pm
Can I have the driveshafts please fella
rsturbonutter
Your car: Fiesta RS turbo
Postby russ-RST on Tue Apr 15, 2014 2:07 pm
Could you send me pics of the flocked dash board pleae ? Also interested in the turbo oil feed with filter, and I'd like to get the c/f roof but your quite a distance from me and not sure whether postage/courier would be safe :( lol
Pm me pls
Russ
russ-RST
Your car: fiesta rs turbo
Postby twins5555 on Tue Apr 15, 2014 8:06 pm
just spoke with gary ,he is in work till late so will reply later ,but he will be in romford essex on saturday so could bring parts down if you wanted to collect
twins5555
Your car: rs turbo
Postby Gadget on Tue Apr 15, 2014 9:10 pm
Front brakes sold
Map sensor sold
Turbo oil feed sold
Fuel pump sold
Throttle body, TPS, sold
She'll sold
Turbo sold
Russ, pm'd re roof and dash
Gadget
Postby FRSJON on Tue Apr 15, 2014 10:07 pm
such a shame gary and i hope work sorts itself out... some nice parts there ,tempted by a few but nearly all sold lol
FRSJON
Postby Gadget on Wed Apr 16, 2014 12:05 am
FRSJON :such a shame gary and i hope work sorts itself out... some nice parts there ,tempted by a few but nearly all sold lol
Still got inlet and exhaust fanny moulds!
Gutted but onwards and upwards :(
Gadget
Postby Gadget on Thu Apr 17, 2014 8:05 am
Driveshafts and gearbox mounts sold
Cage Sold
Russ - Re roof and dash. PM'd. I can possibly deliver them to you saturday night?
Gadget
Postby Gadget on Fri Apr 18, 2014 8:36 am
Custom breather made for me by " Crazycage ". Was designed to fit on the bulkhead of a fiesta under the scuttle but obviously can be fitted elsewhere also, and on other cars.
3 inlet, 2 outlet and baffle plate inside.
Sizes are 220mm x 140mm x 180mm tall.
£45 posted
Gadget
Postby reithy on Fri Apr 18, 2014 9:32 am
Money sent for the standard hoses and starter.
reithy
Postby Gadget on Fri Apr 18, 2014 8:53 pm
-10 speedflow fittings, brand new. £20
Gadget
Postby Gadget on Mon Apr 21, 2014 9:16 pm
This is the large intercooler, measures 780mm to the widest part of the pipes, 300mm tall and 75mm thick.
It has threaded bosses on the top and bottom to mount the cooler.
Also have the Airtec largest alloy rad, unused in black, measures 640mm x 330mm ( same as fitted to the car pictured above ) £223 new, £170
http://www.autospecialists.co.uk/Stage- ... t-863.html
Massive GRP A cossie K&N, some marks where it's rubbed on an inner wing or something but it's not gone through.
£45
Focus St170 front calipers, carriers and bolts. Slight rip to dust seal but fine to use as is. £40
Small washer bottle, ideal for trackcar. Measures 100 x 120 x 180 deep, comes with pump, switch, wiring, pipes and jets etc. £18 posted
Best pics of the dash i could get as it's in the loft. The pics show the grey looking lighter than it does in real life. Un fitted since the flocking was done. £80
25mm Hub centric spacers, machined from billet alloy then anodised. Cost me £150, unused. Offers??
Front shock nut and thread stainless covers. £15 delivered
Tested, working with no missfires, Coil pack £25 posted
Brand new, Genuine Ford / Jaguar ribbed idler pully, Ideal for blacktop zetec conversions. £45 + vat each new, £20 each posted
MTX gearlever assembly fitted with mondeo gearknob with Escort cossie insert, also shifter cables £40
Flo Flex FRST front shock top mount and front roll bar poly bushes, brand new £25 delivered
Brand new ignition barrel and tumblers so can be built to your key £20 posted
Grey oval gearknob, minimal wear ( the bit on the black top piece is a reflection! ) £10 delivered
Roll cage steering wheel hook, alloy. £15 delivered
Pectel T2 ecu with 460bhp cossie map. Unlock code is supplied.
900cc Cosworth Racing injectors, High impedance ( Harvey Gibbs says these injectors can be used on lower bhp engines also no problems! )
Motorsport braided loom configured for coilpack.
Tested weber ignition amplifier £25 delivered
Untested Weber Idle valve £30
Brand new Cosworth crank sensor £15 posted
Euro rear lamps with gaskets, lovely condition, one small nick out of the passenger side but not noticable when bootlid closed £90
Gadget
Re: Zetec turbo engine, manifolds and loads of other bits added
Postby Turboboy67 on Tue Apr 22, 2014 1:06 pm
I'll take the group A filter please Gary, pm me your payment details please.
Turboboy67
Your car: 911GT3 RS
Postby Gadget on Tue Apr 22, 2014 9:11 pm
Carbonboy67 :I'll take the group A filter please Gary, pm me your payment details please.
Just waiting on payment for it mate, if it falls through, it's yours
Gadget
Postby rich1987 on Wed Apr 23, 2014 10:06 pm
What front bumper have you got mate any pictures??
rich1987
Your car: fiesta rs turbo (zvh)
Postby Gadget on Thu Apr 24, 2014 4:56 am
Its a 12 bore one, looks like the MK1 focus RS one. Will get a pic later after work
Exhaust manifold sold
Inlet manifold deposit taken
dash sold
front bushes sold
washer bottle sold
shifter sold
nut covers sold
Gadget
Postby knuckles on Sat Apr 26, 2014 11:07 pm
Is the alloy zetec thermostat housing still available ?
if so I take it :)
regards
clark
knuckles
Your car: Fiesta Rs turbo
Postby Aidy on Mon Apr 28, 2014 11:33 am
Is the mtx gear lever still available pal
Aidy
Your car: Fiesta rs turbo mk3
Postby Gadget on Mon Apr 28, 2014 11:08 pm
Knuckles - pm'd
Aidy, sorry mate it's sold
Gadget
Postby Aidy on Tue Apr 29, 2014 8:00 am
Thanks anyway pal
Aidy
