FAO:Trackcar people - Harnesses
Postby Project_XR2i_Trackcar on Wed Dec 31, 2008 10:44 am
How have you got your harnesses fixed.
I have, until now, had my rear straps fitted to where the original rear belts went as per the photo below:
Now i've had some sound advice and the setup above has been deemed as quite dangerous, to the point that in an impact it would cause serious injury, ie break my collar bones :o
(see this useful link also; http://www.schroth.com/installation-ins ... index.html)
Subsequently, I am in the process of fitting a dedicated harness bar to my trackcar before its next outing. I wasnt aware of the issues of my current setup and i doubt most of you are either.
Has anyone else any thoughts on this and what are your current configurations? Will you be changing it having seen this thread and the link posted above?
Chris
Renault Sport Megane 250 Cup
Ford Fiesta XR2i 2.0 trackcar
Your car: Xr2i
Re: FAO:Trackcar people - Harnesses
Postby ~S1~ on Wed Dec 31, 2008 2:31 pm
Ive not looked at the link but I know that the rear mounts should be as near horizontal as possible. If not then no more than 45deg from the horizontal point where it leaves the seat. The reason being that the resultant forces pull down on the seat possibly breaking it and also your shoulders!
I had Fusion make me an oversize strut brace along with plates that fit on the inner wings to strenghten it, my harnesses are mounted around it.
~S1~
Hold On...
Hold On...
Postby Project_XR2i_Trackcar on Wed Dec 31, 2008 2:46 pm
Thats what i plan on doing, either that or welded directly to cages node points slightly higher.
How much was yours out of interest, can i assume its bolted in?
Your car: Xr2i
Postby ~S1~ on Wed Dec 31, 2008 2:51 pm
Cant remember tbh, not a great deal. GIve Lee a ring r.e prices as he makes them to order. The gap between the arches differs from car to car so he makes them to your supplied dimensions. I specified mine was to mount harnesses so it is bolted in through the arch with another plate on the other side so it wont pull through in the event of a crash. Think the bolts are M10?
~S1~
Hold On...
Hold On...
Postby Turboboy67 on Wed Dec 31, 2008 3:20 pm
Mine are mounted on the floor as well :oooh:
Will have to reposition them before my next track outing :wink:
Turboboy67
Your car: 911GT3 RS
Postby luca on Wed Dec 31, 2008 6:51 pm
My rear strut brace is now situated on the top of the rear turrets and this allows the harnesses to be looped over and secured.
This leaves the belt at what can only be deemed a safe position to do there work in the worst of situations.
luca
Postby Project_XR2i_Trackcar on Wed Dec 31, 2008 6:52 pm
Luke, i take it your rear strut brace is custom fabricated then?
Your car: Xr2i
Postby luca on Wed Dec 31, 2008 7:02 pm
The rear strut brace is literally a section of roll cage tube purchased from Merlin motorsport.
This has been cut to length and tapped into place then welded.
http://www.merlinmotorsport.co.uk/p4330/1-1/2%22-(38MM)-12G-ROLL-CAGE-TUBE/product_info.html?osCsid=74c46619a705901e02216605abd798f9
Pic below of the bar in question, please note the harnesses have not been attached and are just dangling on the floor.
luca
Postby Project_XR2i_Trackcar on Wed Dec 31, 2008 7:04 pm
Ah, seen.
Exactly the same as i was planning.
Your car: Xr2i
Postby ~nomad~ on Thu Jan 01, 2009 1:22 pm
My trackcar had the same setup as yours Projectxr2i and it was was also pointed out to me that it was unsafe. The cage thats in now has the rear bar bracing the rear struts, as above. Paul has some harnesses suitable so these will be fitted for this years trackdays. :)
~nomad~
Your car: Breadvan
Postby wildheart on Wed Jan 07, 2009 5:56 am
Fitted mine to the strut brace too for safety!
3dr Sierra Cosworth Track car
S1 Escort RS Turbo
wildheart
Your car: 3dr Cosworth,S1 RST,Fiesta XR2
Postby Project_XR2i_Trackcar on Wed Jan 07, 2009 8:43 am
wildheart :Fitted mine to the strut brace too for safety!
I hope its a custom weld in one mate, the one in my pic is no where near suitable. too much flex.
Your car: Xr2i
Postby ~nomad~ on Wed Jan 07, 2009 10:28 am
yeah the omp across the top ones wont do bugger all! would prob snap before stopping you in a serious smack lol.
~nomad~
Your car: Breadvan
Postby wildheart on Wed Jan 07, 2009 11:09 am
Yes at the moment its on a chocolate omp one but soon to be replaced with a proper weld in one.
The thought is there for now though :lol:
S1 Escort RS Turbo
wildheart
Postby jonboisescort on Wed Jan 07, 2009 1:10 pm
after reading this i have now moved mine to the mounting point by the rear quarter window
jonboisescort
Car: 1994 Ford Fiesta
Postby Project_XR2i_Trackcar on Wed Jan 07, 2009 1:39 pm
jonboisxr2i :after reading this i have now moved mine to the mounting point by the rear quarter window
at an angle then?
Your car: Xr2i
Postby jonboisescort on Wed Jan 07, 2009 1:59 pm
ive seen it mounted there before so thought it might be better there for now
as i read this
harness-vt146881/?hilit=mounting%20harness
but will be doing the same as you :)
jonboisescort
Postby Project_XR2i_Trackcar on Wed Jan 07, 2009 3:00 pm
I would. I wouldnt wear that belt with it attached where it is now though. probably worse than the lower ones.
Also, I've just noticed that all this time my brace could have been upside down anyway.
Your car: Xr2i
Postby jonboisescort on Wed Jan 07, 2009 3:06 pm
just been doing some research into it :(
so i will move it lower down were the rear seat belt mechanism bolts to
just above the strutbrace :-?
when i got my rear brace the omp logo was facing up so i put it like that
jonboisescort
Postby luca on Wed Jan 07, 2009 3:24 pm
jonboisxr2i : when i got my rear brace the omp logo was facing up so i put it like that
Its a "dwo" strut brace though mate :lol: :lol:
luca
Postby jonboisescort on Wed Jan 07, 2009 3:58 pm
:bonkers: :bonkers: :lol:
jonboisescort
Postby Project_XR2i_Trackcar on Wed Jan 07, 2009 4:24 pm
The optimum position is pretty much were Luke has his. It not only needs to be at a certain angle/height in relation to the shoulders but also straight back (180 deg ??).
If you are using this car as a daily runner and you have to drive it then i would suggest you fix them to the lower fixing points, under where the bench was. It's not ideal but it must be better than having them off centre from the shoulders.
Your car: Xr2i
Postby M1K3Y_B on Wed Jan 07, 2009 4:54 pm
The thing i don't get is:
Luca has a bar running along the exact same place, where jonboisxr2i's rear strut brace is, so why can't the harnesses just be attached to that?
M1K3Y_B
Car: 1996 Ford Fiesta Classic
Postby sjoyce666 on Wed Jan 07, 2009 5:03 pm
M1K3Y_B :The thing i don't get is:
In a crash the bolt in OMP wont be strong enough to handle the force of the harnesses being moved whereas a weld in brace would be
Scott
sjoyce666
Postby M1K3Y_B on Wed Jan 07, 2009 5:09 pm
Oh ok i get it now, didn't think off that :rolleyes:
M1K3Y_B
