Fiesta xr2i parts clearout!! : Parts For Sale | Fiesta Forums
Postby Abbott10 on Sun Aug 11, 2013 11:07 am
Hi all. Finally got around to clearing out my garage and these are the parts I have left over from my H reg Fiesta Xr2i 1.6 8V EFI which had around 80000 on the clock. I have tried to price the items fairly but hey if you want something Make Me an offer. I am Located in Manchester postcode M23 just near the Airport. Collection would be great but I would post at buyers expense. Keep looking as I will be updating regularly.
2 x Ford Valeo headlights £6 each or £10 for both
2 x Ford front indicators £4 each of £6 for both
2 x Ford side repeaters square type with wiring £5 each or £8 for both
2 x Ford tail lights £5 each or £8 for both
2 x Ford front wiper arms £3 each or £5 for both.
1 x Ford boot strut £4
1 x Alternator with plastic cover £8 SOLD
1 x Ford intank fuel pump £8
1 x Ford heater/demistor motor/blower £5
1 x Ford wiper washer bottle with washer motor and piping £7
1 x Ford header tank £5
1 x Starter motor £8
2 x Ford front brake calipers £10 each or £15 for both
1 x Ford gearbox mounting and bracket £8
1 x Ford engine mounting and bracket £13
1 x Ford jack and wheel brace £5
1 x Ford gearbox sandwhich plates (pair) £5
1 x Ford alternator engine mounting bracket £5
1 x Ford exhaust stabiliser (bolts to gearbox) £3
1 x Ford front wiper motor with cover £5
1 x Ford bonnet catch £3
2 x Ford bonnet hinges £3 each or £5 for both
4 x Ford various brackets £1 each
1 x Ford fuel bracket £3
1 x Ford S brace £5
1 x Ford pedal box with pedals £8
1 x Ford handbrake lever £3
2 x Ford A.R.B bush clamps £3 each or £5 for both
1 x Ford rear wiper motor £5
1 x Ford boot catch £3
1 x Ford internal fuse box cover £3
2 x Ford interior wing mirror trim £3 each or £5 for both
1 x Ford interior rear view mirror £3
1 x Ford boot shut contacts and loom £5
1 x Ford boot central locking motor with loom and push rods £8
1 x Ford flywheel in good condition no damage to ring Gear. £15
1 x Ford camshaft and pulley £10
5 x Ford big end caps with bolts £3 each or £10 for all
4 x Ford piston and conrods 3 with rings 1 without £5 each or £15 for all
1 x Ford oil pick up pipe £8
1 x Ford oil pump £5
1 x Ford rear main oil seal carrier £5
1 x Ford thermostat housing £4
1 x Ford rocker cover with oil cap £10
1 x Ford fuel rail and regulator £5
1 x Ford inlet manifold bottom half £5
8 x Ford hydraulic tappetts £3 each or £15 for all
8 x Ford rocker arms and seats with nuts £3 each or £15 for all
4 x Ford inlet valves,springs, and collets 4 x Ford exhaust valves, springs and collets £3 each or £15 for all
1 x Ford fuel blank plate with nuts £3
1 x Ford camshaft thrust washer £3
10 x Ford head bolt washers £2 for all
1 x Ford cylinder head damage to valve guides £15
1 x Ford cam belt covers (upper And lower) with seals £10
1 x Ford cross over charge pipe £10
1 x Ford crankshaft and pulleys with bolts for flywheel £10
1 x Ford oil sump pan with bolts £10
1 x Ford gearbox good condition including mounting £25
1 x Ford front A.R.B £8
1 x Ford manual steering rack £12 SOLD
1 x Ford gearbox cradle £8
1 x Ford bonnet stay £3
1 x Ford exhaust manifold and downpipe £15 complete or will spilt £10 manifold £5 downpipe
Selected Ford/Motorcraft engine coolant hoses £2 a hose
1 x Ford breather pot £3
1 x Ford steering column £6
1 x Ford drivers side electric window mechanism £15
1 x Ford speedo cable £5
1 x Ford brake lines from inside engine bay £5
1 x Ford drivers side blue moulding £5
1 x Ford drivers side blue wing moulding £3
1 x Ford passenger side blue wing moulding £3
1 x Ford door blue moulding £5
1 x Ford complete gear linkage including blue trim gear knob £10
1 x Ford brake servo and brake bar £8
1 x Ford engine compartment scuttle panel cover
1 x Ford horn £2
1 x Ford fuel injector wiring loom £10
1 x Ford drivers side door loom £8
3 x Ford standard blue fuel injectors £8 each or £15 for all
4 x Ford original red HT leads No1,2,3 in good condition 4 damaged £15 the set or £7 each SOLD
1 x Ford EDIS4 unit £12
1 x Ford MAF sensor £8
1 x Ford air intake temp sensor £4
1 x Ford water temp sensor £4
3 x Ford other engine sensors (unsure which ones I'm picture) £2 each
1 x Ford passenger side door great condition no rust £25 complete (including glass and motor and loom) or £15 just for the door shell
BRAND NEW ITEMS
1 x N/S Delphi wishbone for fiesta MK3.5 onwards 1 x O/S Delphi wishbone for fiesta MK3.5 onwards brand new in packaging £15 a side or £25 for both
1 x Genuine ford piston ring set £3
1 x New front lower valence repair panel unsure of make £10
1 x Genuine ford gasket set (inlet and exhaust manifold gaskets and thermostat gasket) £8
1 x Ferodo Brake pads for xr2 and other models (part No FDB212) £5
1 x Ford powder coated MAF bracket £5
1 x Set of Motorcraft spark plugs brand new £5
5 x Genuine ford brake line clips £3
1 x Intermotor new sensor part No 55160 £2
1 x New rocker arm £3
1 x Ford blue trim gear stick Knob £4
4 x Delphi brake hoses various brand new £4 a hose
Can get other pictures if needed. Also have other items so don't be shy and ask. :lol:
Abbott10
Re: Fiesta xr2i parts clearout!!
Postby FRS_Steve on Sun Aug 11, 2013 10:45 pm
I'll take the front indicators if there are no chips or cracks on them?
Also the piston rings, assuming they are standard size?
And the gear knob too.
How much for that lot inc postage please?
FRS_Steve
Postby creator on Mon Aug 12, 2013 4:13 am
how much for the gearbox cradle posted mate?
creator
Postby Abbott10 on Mon Aug 12, 2013 7:15 am
Pm'd
Abbott10
Postby RS EDDIE on Mon Aug 12, 2013 12:33 pm
Ill have all four ignition leads. Location mate?? :D
RS EDDIE
Postby Abbott10 on Mon Aug 12, 2013 1:12 pm
Im in Manchester mate will you be collecting?
Abbott10
Postby rsturbonutter on Mon Aug 12, 2013 2:12 pm
I will take the indicators if they are ford stamped and alternator. How much posted
rsturbonutter
Your car: Fiesta RS turbo
Postby Abbott10 on Mon Aug 12, 2013 2:26 pm
rsturbonutter :I will take the indicators if they are ford stamped
Do you mean the side ones or front?
Abbott10
Postby RS EDDIE on Mon Aug 12, 2013 5:02 pm
Can you post them please mate. :D
RS EDDIE
Postby rsturbonutter on Mon Aug 12, 2013 5:09 pm
Abbott10 :
Fronts mate
rsturbonutter
Postby Abbott10 on Mon Aug 12, 2013 7:53 pm
Pm'd
Abbott10
Postby Abbott10 on Tue Aug 27, 2013 7:23 am
Bump. Make some offers
Abbott10
Postby Boostjunky on Thu Oct 24, 2013 12:37 am
Bonnet catch ??
Boostjunky
Your car: Ford
Postby willowandmikey on Thu Oct 24, 2013 4:31 pm
Gearstick knob posted price please
willowandmikey
Your car: ford fiesta xr2i 8V
Postby Layden on Fri Nov 01, 2013 8:37 am
Hey I'm after a few items. I had a little supranational and I'm sorry if I missed them from your list.
Rear seats.
Big end bearing.
Head gaslit kit.
4 wheels.
Layden
Your car: Volvo s60
Postby Turboboy67 on Fri Nov 01, 2013 11:10 pm
"5 x Genuine ford brake line clips £3"
I'll take these please if they are still available,
pm me payment details.
Turboboy67
Your car: 911GT3 RS
Postby Turboboy67 on Thu Nov 21, 2013 8:13 pm
I've still not received my clips :-?
Turboboy67
Your car: 911GT3 RS
Postby b0yracer on Wed Nov 27, 2013 2:21 pm
pm sent
b0yracer
Your car: ford
Postby Jw-Photography on Sun Dec 01, 2013 12:31 pm
Starter motor and Alternator bracket ??
Still there mate if so how much for both posted ?
https://www.facebook.com/pages/Jw-Photography/538267489530245?bookmark_t=page
Jw-Photography
Your car: Mk3 Fiesta, Mk1 Focus RS
Postby Abbott10 on Mon Dec 02, 2013 2:23 pm
Yeah mate I still have both of these. Hows £18 posted?
Abbott10
Postby Jw-Photography on Tue Dec 03, 2013 8:15 pm
sounds magic mate :) can i pay you friday when my money goes in ?
Jw-Photography
Postby b0yracer on Tue Dec 10, 2013 3:42 pm
parts received as described, cheers m8 nice one
b0yracer
Your car: ford
Postby Thepriest91 on Mon Dec 16, 2013 11:10 pm
do you have the xr2i wing mirrors? cheers
Thepriest91
Your car: 1.3 MK3 Fiesta
Postby Richy p on Tue Dec 17, 2013 7:36 am
How much for heater motor posted to Durham?
Richy p
Your car: 1990 FIESTA RS TURBO (RED)
Postby Abbott10 on Tue Dec 17, 2013 12:13 pm
Thepriest91 :do you have the xr2i wing mirrors? cheers
unfortunately not mate
Abbott10
Richy p :How much for heater motor posted to Durham?
Hows a tenner sound mate?
Abbott10
Postby gazaboi on Wed Dec 18, 2013 11:42 pm
il take your rocker cover and breather pot with any breather hoses if you still got them how much could you do for me on that lot posted cheers
gazaboi
Your car: fiesta rs turbo
Postby Abbott10 on Thu Dec 19, 2013 12:56 am
gazaboi :il take your rocker cover and breather pot with any breather hoses if you still got them how much could you do for me on that lot posted cheers
do them two for £18 posted mate!
Abbott10
Postby gazaboi on Thu Dec 19, 2013 2:17 pm
Il take them for that bud do you have any breather pipes as ive basically havent got any as guna try to put origional to improve my system
gazaboi
Postby Abbott10 on Thu Dec 19, 2013 10:57 pm
gazaboi :Il take them for that bud do you have any breather pipes as ive basically havent got any as guna try to put origional to improve my system
Sounds good mate the only ones I have are the ones that are on it in the picture??
Abbott10
Postby gazaboi on Fri Dec 20, 2013 10:42 am
That's okay I did have a length of small blue hose with the car when I bought it it maybe the right size for breather, if you pm me I can pay for them and give you my address, cheers
gazaboi
Postby Matt Walsh on Fri Dec 20, 2013 11:14 pm
Can I call down over Christmas and have a rummage. After a few bits that you have. I'm in north Manchester so your not that far.
Matt Walsh
Your car: Ford Fiesta XR2i J Reg
Postby Richy p on Sat Dec 21, 2013 8:10 am
Abbott10 :
PM,d you mate.
Richy p
Postby Abbott10 on Mon Dec 30, 2013 11:30 am
Matt Walsh :Can I call down over Christmas and have a rummage. After a few bits that you have. I'm in north Manchester so your not that far.
Yeah mate thatll be great.
Abbott10
Postby Richy p on Wed Jan 01, 2014 11:54 am
Got heater motor spot on mate thankyou.
Richy p
