[GUIDE]Footwell neons... ON THE CHEAP!!!
42 posts • Page 1 of 2 • 1, 2
Hi guys. Just installed some blue footwell neons (for those who know - continuing my blue theme within a red car.. )
Many of you will see Halfords prices for these beasties - anything upwards from £10/£20/£30. Being a car + computer enthusiast I put my mind to the job to combine the two, and scoured the Case Modding section of eBuyer.
Blue:
http://www.ebuyer.com/UK/product/51686
Red:
http://www.ebuyer.com/UK/product/55288
Blue and Green:
http://www.ebuyer.com/UK/product/105024
UV / Purple:
http://www.ebuyer.com/UK/product/58063
When you unpack the box after delivery - you'll have some molex connectors -
After these two cables there will be a switch, you can wire this in or leave it, depends on your style. If you dont want the switch, cut the cables after the switch, then connect the cables as below (only difference being the cables are yellow and black, rather than red and black)
The two cables you need are the two circled in this photo. The red is the live, and the black is ground. Find a spare illumination feed and a ground feed and connect these in whatever fashion you like.
Fit the black connector into the Inverter (black block) and connect the two neons with the white connectors into the opposite end of the inverter. Now fix the neon tubes whereever you want them in the car (usually under footwells!!)
Now, if everythings gone well, flick the supplied switch to the on position. Now it won't turn on - but now turn on the lights. It should illuminate your footwells nicely!
Quite a simple and quick job to do - and only costs £1.99!
Nick
Blue:
Red:
Blue and Green:
UV / Purple:
Nick
- dontpannic
hiya mate,
good job cool you found it out but cold cathodes is something people have been doing for quite a while, if you wanted to go a bit further, you could hook it up with your interior light to come on when the doors open, and replace the interior light with a white cold cathode.
looks good
looks good
- adz
- ant pittaway
ant pittaway :cheers for the links mate!
white socks!!! jacko!!!
Hehe. cheers guys. The white socks were with trainers but I threw the work shoes on to go outside to take the photos lol
- dontpannic
- dontpannic
Looks good. Might have to put some UV ones in my car, to replace the non existant interior light. Do they actually provide much light, or just make everything blue?
- GeForce Junky
- Location: Gloucestershire Claims: To be FT's Sole Hillman Imp Launtic
- adz
Yeah, it does give out quite a lot of light, considering it's so cheap.
Thats a good guide but only relates to the boot opening when you already have a boot light - some of us don't have the lamp or the wiring for it, plus this is for the footwells!!
- dontpannic
GeForce Junky :Looks good. Might have to put some UV ones in my car, to replace the non existant interior light. Do they actually provide much light, or just make everything blue?
They do provide quite a bit of light, Next ebuyer order I'm going for UV under the footwells, as you cannot see the light until your feet are under there, then a blue/white one replacing the interior light.
Can this be moved to guides yet?
- dontpannic
Cathode tubes are very bright when the light's shining onto something, or even to look at. UV ones won't light anything up though unfortunately but might make some colours stand out lol.
The brighter ones are white, blue or green
- Tweek
- Your car: VW Golf GTD
would be easy to wire it up so when the doors open the cathodes come on.
run the cathode power wire behind the pillar by the front window up to the roof lining. tuck it inbertween the lining and the roof then wire the + and - to the + and - on the interior light then it will work off that power.
so whan ya turn ya interior light on the cathodes come on and when ya open the door they come on aswell.
and ya already have a switch there - might not work but thats how i would do it.
- ~ John Reid ~
Yea it will work tho i hated it and set mine to comeon with the headlights.
and you dont need to go inoto the roof of the car eather just find the earth running from the doors
:: Edit ::
Dont forget to wire into both doors otherwise it will only work hen u open one door
:: Edit ::
- JohnBoy_DIY
- Your car: CAR
grrrr they dont seem to do green. i would only get neons if they were chep and these are!!
do you not need any relays or anything or is it just a case of splicing into the interior light feed?
really wanna do this with green as mine probs one of the only fiestas that could successfully pull it off.
- Jonezy
Jonezy :grrrr they dont seem to do green. i would only get neons if they were chep and these are!!
Should be able to get them in green...
Also try Microdirect, ebuyer or misco...
Nick
- dontpannic
tryed microdirect alreddy nd they only do them as a well expensive kit (£30).
gonna have to sort the interior light out first as its playin up, works of switch but not when you open the doors, took the light apart to see whats up, everythin seems ok, took the triger in the doors apart and everythin seems ok too, just cleaned the connectors up but still no joy.
had an alarm fitted a while age, could this have caused probs as they havnt worked for a while.
il keep tryin as at 1.99 you cant leave it there.
help on the door bits light trigger greatly apprieciated.
- Jonezy
sca.com have the greens, check these out to see if there the same, i assume they are as there sold as a kit.
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=45347
no pics i know but have gander anyway plz.
- Jonezy
Jonezy :sca.com have the greens, check these out to see if there the same, i assume they are as there sold as a kit.
Nothing comes up in the images or description for some odd reason, but the title seems kosher.
If it ain't right you can always send 'em back.
WRT the interior light playing up, either clean up or replace the door switches. They were caked up with Copper Oxide when I got mine, so just clean the green crap off them...
Nick
- dontpannic
Jonezy :no green crap, rubbed em down anyway to nice shiny copper tho, wierd how both sides stop working at once tho, think the alarm guys had summat to do with it.
Possibly - both mine went at the same time. Bit gay really lol
- dontpannic
I have a MK5 Fiesta.. I was going to wire it in with the interior light ad I have made MY OWN SWITCH.. will this remain live IE does the light need to be on or the door open for the circuit to be live?
Aaron
Aaron
- Aaron_UGL
If the switch connects to the door open live / ground, when the switch is on the lights will come on with the doors, but if the switch is off it will stay off. Might be better getting a 3 way switch that will do:
Illumination
Doors Open
Ground
So you can switch between having it on with the illumination or with the doors open....
Nick
Illumination
Doors Open
Ground
Nick
- dontpannic
- dontpannic
I have done my and they look awesome will put a pic up soon.
They have lot of new colours now
Blue
http://www.ebuyer.com/product/51686/product_info/rb/0
Green
http://www.ebuyer.com/product/125802/product_info/rb/0
White
http://www.ebuyer.com/product/42959/product_info/rb/0
Red
http://www.ebuyer.com/product/55351/product_info/rb/0
Purple
http://www.ebuyer.com/product/125793/product_info/rb/0
Hope this helps people
Mike
Blue
Green
White
Red
Purple
Mike
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
They aren't "spare" as such - if you put a CD player in the car, there is an illumination feed which supplies the standard ford unit - in the MK3 the cable was grey/yellow. Not sure about the MK4/5 I'll take a look at Lunchtime. Ground you can use any ground you find, just splice into the feed - I used one of the radio grounds.
Gracefully borrowed from Andy (AW3K):
Pin 4 is the one to use - cut the cable, connect the two back together and merge with the live for the neons, and the same with the ground (Pin 6).
Hope this helps - if not let me know and I'll take some photos.
Nick
fiestaguides.co.uk :Pin Number, Colour, Description
1 Orange/Black 12V Permanent Feed
2 Black/Yellow Earth
3 Blue/Black 12V Switched Feed (Accessory)
4 Orange/Black Illumination
5 Black/Orange To Alarm/ PATS
6 Black/Green Earth
7 Not used
Nick
- dontpannic
gumbsy1 :photos would help, cheers
but wont this effect the cd player?
No. As long as you reconnect the cables to where they came from originally. Basically you are creating a T piece. Can't get photos at the moment but I'll try a ASCII diagram!
Illumination Feed
---------------- To Neon Live
From Loom -----------------/---------------- To Radio Pin 4
Ground
---------------- To Neon Negative
From Loom ------------------/---------------- To Radio Pin 6
Nick
- dontpannic
gumbsy1 :kk, and how do i connect them?
Any way you like - bullet connectors, crimps, even just strip the ends off the cables and wrap them together, then insulate with electricians tape. Disconnect the battery first though, as a precaution.
Nick
- dontpannic
dontpannic : even just strip the ends off the cables and wrap them together, then insulate with electricians tape.
No! Don't! Fire!
If you're going to strip the wires solder them! Then insulate them with heatshrink preferably.
- properphatboy
- Your car: Peugeot 306 D L
