Postby Excursion on Tue Apr 19, 2005 11:01 pm
A year has gone so fast! The weather really wasn't kind to us that weekend was it :rolleyes:
Will look forward to seeing your car in action mate :Q
Postby heeman10 on Tue Apr 19, 2005 11:03 pm
It was the best day of the entire year....in the morning! Was a nasty drive back too, I was still giddy as a young camel though :lol: :D I'll be around and about a bit in summer so I'll drop in to take you out in your "old car" if you're in. I'll help you wire in your ST170 4 wheel electronic ABS too, by passing the insulation tape :)
Postby heeman10 on Mon Apr 25, 2005 5:39 pm
Small update:
My braided hoses came through from Fusion today, with the metric ends for the Fiesta connections and correct imperial ends for the American Wilwood calipers:
I'm installing oil pressure and temperature gauges, and am taking the pressure feed off the turbo oil feed. You can see in this pic where I needed a T-piece to allow me to run the pressure sender in-line with the oil feed:
And this little baby will allow me to do that:
The silver male/male fitting screws into the block as normal, then this little anodised fitting screws onto the end of that. The pressure sender screws into the 1/8NPT female thread at the side, and the oil feed screws onto the end of the T-adaptor :)
I go home on Saturday for about five days of work on the car, and hope I will be able to get it up and running and out on the road for some gentle miles of fault finding and generally checking all is well :)
Postby heeman10 on Sun May 01, 2005 7:04 pm
Update:
Well I came home on Friday night for my 4-5 day session on the car between assignments and exams at uni :lol: My bedroom was FULL of things...chromed stuff, polished stuff, radiator, intercooler, ECU, engine bay loom, boost hose...ALL sorts, it was like christmas!! :D
Work began yesterday morning, and the first discovery was that my radiator and intercooler, after the lonnnnnnng wait, don't fit :( Rather than waiting a few more months for Radtec to resolve the problem, I'm sending the radiator to Lee at Fusion Fabrication to carrying out the alterations required to allow them both to fit. That means I can't mount the intercooler yet either, so I will not be going to FITP now. These things happen, so I'm not angry at that, but if I'd had the cooler and radiator several months ago when I should've done, I could've found this out in February and had them modified already and they'd be on the car now. Ho hum!
Plugged in all the engine loom, HUGE thanks to Scort for checking it over, giving me an ERST AMAL valve and Zetec CPS, he is my saviour :) Thanks also for the tech support calls, you saved yet another ECU from heeman humiliation! :lol: So at around 10pm last night, I came to fire up the ignition to check the fuel pump was working, and after several adjustments and checks here and there, still had no life from it. The pump was new about three months ago, so I assumed it to be fine. Having blown our last fuse in the multimeter, I had no meter to check all current outs, but used an indicator bulb today, and I have power at the pump connector, meaning the pump is not working. That's gay, but it's good to know the feed is getting there, and so I can now wire in everything on the dash (plazma dials, three new gauges plus ACT gauge then boot release, central locking etc) and get the majority of the interior back in.
Gearbox cradle is now modified for the Deflex gearbox mounts, which are now bolted on, so the gearbox and engine are back up in the car again, solid as a rock. Ran out of things to do today, so spent about four minutes putting my Rawli lights on, and they look lovely :aviator:
So tomorrow I need to get some big fat M12 bolts to mount my new brakes, then bleed them and quite probably find my master cylinder is no longer good enough :rolleyes: And the fuel tank and pump need to come out again to see what's going on with it, and a replacement sorted if need be.
My dad's been having problems with the Caterham since he tried using a faster-cranking geared starter motor. The company (Racemettle, for those wondering who to steer clear of) ended up sending three motors as they were all rubbish, and the car hasn't started since. My dad sent off the ECU to be profressionally checked, and has checked every single wire on the car (sound familar Mr. andyhardy? ;) ) and found that the block temp sensor was a little inconsistent, so replaced it. In the meantime, the ECU was found to be spot on. He bought a set of Platinum NGK plugs for it, still no joy. Tried to old starter today and it fired up no problem! Misfire was gone, fuel was fine. So all that time and money (160 quid for ECU check) and it was these muppets giving him yet another crap starter motor! So after our frustrating day today, both having niggles with our Zetecs, I think we might be going out for a blast in the Caterham :D ahh 400bhp/tonne :Q
Pics will be up around Thursday, don't have my PC with me up here.
P.S. I forgot...oil pressure sender is now plumbed in, inlet manifold is all re-assembled and back on the engine, and I've got dimensions for the custom bits I need from Fusion to plumb in the cooling. I've done lots more, just can't remember :lol:
Postby Captain Tightpants on Sun May 01, 2005 9:22 pm
Glad to see its coming on mate.
Looking forward to seeing some photographs too.
Keep up the good work mate.
Steve
Captain Tightpants
Postby heeman10 on Thu May 05, 2005 5:39 pm
Update
MY CAR IS GAY.
Postby MAD_Adamski on Thu May 05, 2005 5:43 pm
aint that the truth like the owner :lol:
MAD_Adamski
Postby Ghost on Thu May 05, 2005 5:43 pm
heeman10 :Update
MY CAR IS GAY.
care to elaborate?!
Ghost
Postby Captain Tightpants on Thu May 05, 2005 5:47 pm
What up mate?
Steve
Captain Tightpants
Postby RS_Rawli on Thu May 05, 2005 6:30 pm
its all that bloody leopard skin around it,
RS_Rawli
Postby Excursion on Thu May 05, 2005 6:49 pm
wha gwan?
Postby RS_Rawli on Thu May 05, 2005 7:05 pm
just been on the phone to him, his car isnt actually gay :lol:
just had a bad day on the camp
RS_Rawli
Postby Rhinopower on Thu May 05, 2005 9:20 pm
chrome bits good?
Rhinopower
Your car: Volvo FH330
Postby heeman10 on Fri May 06, 2005 4:32 pm
Ok, well a proper update now. I'll try to keep it short.
Modified gearbox cradle with Deflex mounts:
Oil pressure sender and turbo oil feed on back of the block:
Fast and the Furious style photo of all the stuff in my bedroom waiting for me:
Radiator/intercooler problem. Radiator pipe sticking out sideways blocked the intercooler pipe:
The pipe (top left) needed rotating round to face backwards, the bottom right pipe needed shortening, and I needed tabs on the top of the radiator to secure it to the car:
Drove all the way to Fusion Fabrication in the Metro, as I needed it all sorting ASAP. Lee set aside his entire afternoon (and early evening) sorting out all my problems, dedicating all his time to solving one problem, then saying "NEEEXT!" and I'd bring in the next offending item. The outcome....modified rad (sadly he welded the tabs on the wrong side, an oversight on my part partly :rolleyes: ), modified exhaust (to give alternator better clearance), custom actuator bracket (pics further down) and new intercooler mounting brackets.
Lovely weather for the drive down:
Radiator modified:
My actuator couldn't be mounted ANYWHERE with the compressor housing pointing down, and my new custom bracket allows it (A) to be mounted and (B) to clear the radiator healthily. The actuator had to be positioned as close as possible to the boost hose, and it is absolutely perfect:
Front view:
Rear view:
Lovely piece of work, and solved a number of problems :)
Also, this was sitting in his workshop:
My turbo assembly compared to ERST setup:
Test fit with new radiator:
Intercooler is not mounted yet, that is supported in position.
Heater vent block-off plate to stop my ACT and boost gauges overheating in cold weather with fans on hot:
And my new dash layout. Plazma dials, Autometer gauges and ACT gauge:
Brakes aren't finished yet, but close:
An idea of how the engine bay will be:
Fusion Fabricated Metro:
And the awesome sunset that greeted me when I arrived home:
This is a very brief update, there were a large number of problems I faced in this five day blast, and working on the car alone, doing the kind of work I was doing, was extremely draining physically and motivationally. I think I'll miss my live map at MSD thanks to the wasted time with the radiator and intercooler being made so slowly, but I should have it running by/before June anyway. Exams are next up.
Any questions, ask away :)
Postby Excursion on Fri May 06, 2005 4:37 pm
Good stuff Jim - nearly there!
What was the reason for mounting the radiator back to front then?
Postby Ruishy1 on Fri May 06, 2005 4:54 pm
coming along nicely there mate :D
Ruishy1
Postby Classkeeper on Fri May 06, 2005 5:33 pm
Looks great. Cant wait to see the finished result!
Classkeeper
Postby PaulFRST on Fri May 06, 2005 6:35 pm
Hi mate, cars coming along great
where can i get those plasma dials, they look wicked
Image Image
PaulFRST
Your car: Vivaro Van
Postby Max M4X WW on Fri May 06, 2005 6:39 pm
Everythings looking spot on :)
Postby Mint_FRST on Fri May 06, 2005 6:42 pm
What are these things...? :o :o
And where did you get them :o :o
Mint Moondust FRST / Focus RS
Mint_FRST
Postby Max M4X WW on Fri May 06, 2005 6:47 pm
Looks like the rear panels to me!
Postby FezzR on Fri May 06, 2005 6:58 pm
scuttle / bulk head pannels
FezzR
God Damn Lazy
God Damn Lazy
Postby heeman10 on Fri May 06, 2005 7:51 pm
Excursion - I'm not mounting it back-to-front you tart :lol:
MintFRST - Yep, bulkhead panels. I'm not 100% happy with having so much chrome stuff, but I want everything clean, and smooth/shiny surfaces make that easier! I think I'll get used to it, and it's better than it was.
Another update...my Forge recirculating dump valve:
Was a bit of a rushed update above, so if anyone does have questions I'd be happy to answer them :)
Postby Excursion on Fri May 06, 2005 7:59 pm
heeman10 :Excursion - I'm not mounting it back-to-front you tart :lol:
:lol: slut.
Maybe back to front was the wrong term, end to end perhaps? The piece you just had modified should have been like that, it goes to the water pump - that's why you've got the header tank inlet on the wrong side now (that small tube). Did you have some clearance issues or something with the new turbo arrangement?
Postby heeman10 on Fri May 06, 2005 10:04 pm
wtf :aaah: I thought the small nubbin pipe was for turbo water or something :-? Ah well, it'll work as it is :lol: It WILL work :x
Postby xrsi on Fri May 06, 2005 10:23 pm
spoke to radtech today mate!
will be with me wed/thurs! :D
doesnt lok like i'll have any probs with fitting at all from those pics! :D
they said that they were waiting to hear if there were any fitting issues with yours befor they finished mine off completely as it wasnt from their own design!
oh and also yeah you rad is swapped round... what you have on the right should actually be on the left as you look at the front of the car! it would have needed modifiying anyways as the angle the bottom hose would have entered was backwards from where it should have been!
but yeah the small hose connection is for turbo cooling water to be put back into the rad!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby heeman10 on Fri May 06, 2005 10:26 pm
All is well. I don't have a water-cooled turbo anyhoo, and the radiator needed to be RIGHT over to the left hand side, so it's all still fine. Glad you're getting yours in good time at least!
Postby xrsi on Fri May 06, 2005 10:29 pm
wont hold my breath over it but will be nice when it does come! :D
where did you get all the chrome bits from? wouldnt mind getting a few bits done myself!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby heeman10 on Fri May 06, 2005 10:32 pm
Chroming and polishing was done through Rhinopower. Sadly some bits got damaged in the post, resulting in cracked chrome. I'm not totally sure I like it all chromed, but time will tell. Just need it running and driving first :)
Postby sleeky on Fri May 06, 2005 10:33 pm
Coming along really well mate, gonna be an awesome car :Q
Lee.
sleeky
Location: Cuffley, hertfordshire Drives: Mk2 Fiesta, Arosa 1.4Tdi
Postby andyhardy on Fri May 06, 2005 10:57 pm
Great stuff - it's really taking shape now mate!
I'm watching this post with a keen eye :D
Postby Superal on Fri May 06, 2005 11:37 pm
im gonna be following this closely as i am hopefully going to embark on a 1.8 zetec turbo project in future :)
Superal
Postby wilson123 on Sat May 07, 2005 1:45 pm
Cant wait to see the end product of this, its become somewhat of an emotional rollercoaster for me, like a favourite dvd that i just watch over and over again :lol:
Shaping up to be awesome end product though, any ideas how much wonga you spent on it so far J?
:'( goodbye uni it has been fun!
wilson123
Postby MAD_Adamski on Sat May 07, 2005 2:33 pm
heeman10 :Image
All im gonna say id those leopard skin pants are coming off to often man you need to get a g/f and get out more :rolleyes:
MAD_Adamski
Postby Rhinopower on Sat May 07, 2005 6:12 pm
Glad you like the chrome, what bits got cracked?? If you want i'l give the place a call on monday and see if he'l redo it FOC for you??
Want more BLIIIINGGG and shiny link that?? PM ME PEOPLE!
Rhinopower
