Hard Days Work
35 posts • Page 1 of 1
- Ian C70T5
- Das Ist Kapput
- MOONDUST FRST
Good man.
Can you keep an eye on the exhaust manifold gasket? I need to know if I can use that one (I thought I couldn't because it wouldn't seal properly against the shape of the manifold ports, plus the ERST one uses fire rings...?).
Keep up the good work chap!
MOONDUST FRST :Coming on ian
Just out of interest are you spacing/raising the engine/gearbox using 10mm blocks
WHERE??? lol opps no what exactly do you have, and why does it need it
Only problem i have so far is driveshafts, the shorest is in, but ont in far, it needs to go in about another 2 inches i think
- Ian C70T5
- Das Ist Kapput
How would you space the engine mount down? The horizontal bolt hole would need to be re-drilled and tapped into the mount wouldn't it?
- grahamb
Yeah Al I re-drilled the offside chassis leg. Firstly got a piece of metal tube, measured the O/D then drilled centrally at the point I needed. Put the tube in and welded a seam at both ends.
Drilled a small hole underneath and sprayed wax everywhere.
Excursion :you could have masked off the washer fluid reservoir ian
Looking tidy innit
or taken it off i cleaned all under my arch liners the other day, put everything back 2 find out the pump had temp stopped workin
Looks tops Ian!
- Sphinx
Lol at my last post Mark was right i meant lower not raise the engine
Anyway we( ) spaced the gearbox cradle lower using 10mm blocks which also means you then have to lower the xmember 10mm too so it clears the cradle, this was how it was fitted in duncans car by shepards on advice from ian howell so i was told and i am sure it is so the charge carrier clears the bonnet!
- MOONDUST FRST
Al i used the ERST mnaifold gasket on mine when i took the tubby off and it just needs a little bit removing off one corner near the cam pulley side to fit correctly
- MOONDUST FRST
- MOONDUST FRST
MOONDUST FRST :Al i used the ERST mnaifold gasket on mine when i took the tubby off and it just needs a little bit removing off one corner near the cam pulley side to fit correctly
Mate - I made exactly the same msitake as that, flip it round and I think you'll see it lines up perfectly without cutting anything. If you've got it on by cutting it you'll see that the gasket covers 7mm of the ports.
I think that's right anyway, it was a while ago I did that....
Excursion, that what i done mate, was by mistake, didnt know it would fowl up the other way..
Marc, if you could mate, i would love some spacer plates if that ok?!?
Now got to plumb it in totally and wire up etc, sort out new downpipe, finish fitting one of my brake discs and bobs ya uncle, back to body work
May end up spraying enough paint on then running car in while i spend evenings with the polisher smoothing and polishing the paint.. need to get the miles on it as its booked for map
- Ian C70T5
- Das Ist Kapput
Excursion :MOONDUST FRST :Al i used the ERST mnaifold gasket on mine when i took the tubby off and it just needs a little bit removing off one corner near the cam pulley side to fit correctly
didnt see it covering the ports at all but it was a while ago now, bugger will have to take tubby off again now
- MOONDUST FRST
MOONDUST FRST :Excursion :MOONDUST FRST :Al i used the ERST mnaifold gasket on mine when i took the tubby off and it just needs a little bit removing off one corner near the cam pulley side to fit correctly
Oh I wouldn't take it off on my account just yet - I'll have a look tonight and tell you for definate, as the turbo is currently of mine
- custom boy
- chumkila
- Dirty Post Whore!
- MOONDUST FRST
Good stuff Ian Keep it coming lad!
- TomRS1800
