Guide: fitting a 2.0 Focus inlet manifold LINK EDITED
Postby Dazza on Thu Feb 02, 2006 8:41 pm
Just completed this guide, availible on my site.
Its a good one for the guys with 2.0 fiesta's and well worth doing, just ask Sunil (Thanx bud) and he will tell you. Might have to re-write it as am such iv made mistakes somewhere, oh and need a 'aftershot' picture at the end. Hope it helps
Thanx to Excursion alittle :lol:
http://www.teamford.co.uk/webpage/technical.htm
[direct link to the guide - al]
Dazza
Postby Smo on Thu Feb 02, 2006 8:59 pm
Postby Dazza on Thu Feb 02, 2006 9:00 pm
my god I cant even spell my own website address!
My spelling is bad but jeeez!
Thanx SMO :)
Dazza
Postby Excursion on Thu Feb 02, 2006 9:23 pm
Is that PVC tape blocking off the vaccum ports?
Postby Dazza on Thu Feb 02, 2006 9:25 pm
That pic was taken when I was cleaning the inlet, so s**t didnt get inside. The picture was just to show you the area
Dazza
Postby Excursion on Thu Feb 02, 2006 9:35 pm
Ahh OK :D
Postby RS_Raz on Thu Feb 02, 2006 9:44 pm
any pics of it complete and in the car?
Raz
RS_Raz
Postby Dazza on Thu Feb 02, 2006 9:48 pm
Dazza_CW :Might have to re-write it as am such iv made mistakes somewhere, oh and need a 'aftershot' picture at the end.
Not just yet mate, i'll let you all know once its up if your interested
Dazza
Postby RS_Raz on Thu Feb 02, 2006 9:53 pm
yeah i'd be interested to see how the new inlet hoses would connect to the airbox.
Cheers.
RS_Raz
Postby Dazza on Thu Feb 02, 2006 9:56 pm
Personally I have it connected to a Pipercross Viper inductionkit but I see no reason why you cant you the standard focus airbox - Infact Iv heard the focus owners fit the ST170 airbox for a performance gain?
Ideally I need to relocated my battery to give me more space, then I can connect my morrette air intake directly to the Viper.
Yea I'll drop you a PM with a final pic - It was getting abit dark before
Dazza
Postby RS_Raz on Thu Feb 02, 2006 9:59 pm
cheers mate. how much did u pick the manifold up for?
RS_Raz
Postby Dazza on Thu Feb 02, 2006 10:01 pm
I got my manifold for £40 of the local scrappy - I know the guys in there very well but I recon 40 is the going rate, just make sure you get the inlet bolts and induction piping (Mine was off a 55reg Focus :D)
If not the bolts are only £2.70 from Fords
Dazza
Postby Rhinopower on Thu Feb 02, 2006 11:59 pm
how did you connect the throttle cable to the throttle body?
Postby Rhinopower on Fri Feb 03, 2006 12:01 am
also something worth adding, you can fit the idle valve off the escort gti, which is same fitment onto manifold, and same wiring connector!!
Postby Dazza on Fri Feb 03, 2006 12:18 am
Really? cool I didnt know that.
Totally forgot about the throttlecable - Am going down to Fords to see if the Focus and Fiesta share the same connection at the pedal end. If not I'll do as Excursion says and get the focus end piece attached
Dazza
Postby Rhinopower on Fri Feb 03, 2006 9:58 am
you can jsut say sod it and use an un modified throttle body of a 2.0 mondeo, the linkages are made for 'horizontal' use, and the accelerator cable will clip straight on! then you can use standard TPS, and not change any of the wiring!
Postby adamburzynski on Sun Feb 19, 2006 7:31 pm
what is the dimension of the focus throttle body?? is it bigger than the rs1800/2.0l mondeo? and what focus do i need to get one of these off?? as im guessing the different models will have different sized ports...
adamburzynski
Postby Dazza on Sun Feb 19, 2006 8:58 pm
The TB off a Mondeo wont fit (I dont think anyway) and you can use any 1.8/2.0 Focus inlet (Black plastic type)
Dazza
Postby Rhinopower on Sun Feb 19, 2006 10:18 pm
2.0 mondeo TB does fit
Postby lucasdemoley on Wed Feb 22, 2006 4:14 pm
What kind of extra power is expected using this setup?
Just because I keep talking about definetly doing it doesn't mean I'm actualy going to do it.
lucasdemoley
Postby Dazza on Wed Feb 22, 2006 9:37 pm
Well I rolling roaded my 2.0 after it was put in, it made 128bhp but had a few 'teething' problems - Id say with the manifold you should see the 136bhp thats expected
Dazza
Postby RS rob on Sun Mar 12, 2006 4:51 pm
so basically can someone sum it up as lots of different options have been said,
1.8/2.0 focus inlet manifold with bolts
also the matching throttlebody and iscv
induction hose
block two of the holes on the manifold
alter loom accordingly
then it should work?
one or two questions
will the induction pipe fit over a 2.0 mondeo maf sensor?
does the focus throttle body connect to the fiesta throttle cable??
do i need a gasket for the inlet manifold where it bolts onto the head?
RS rob
Postby Dazza on Mon Mar 13, 2006 1:27 am
Hey
Yes it does
Unfortunetly not, I have yet to find out if a focus tb cable will fit, altho I have reason to believe it will as I have looked into this (I have pics of both ends etc)
Opps I should have put that in the guide too - Yes you will
Just to note, you only need the ISCV and TB plugs not the sensors themselves
Dazza
Postby lucasdemoley on Mon Mar 13, 2006 1:38 am
Rhinopower :you can jsut say sod it and use an un modified throttle body of a 2.0 mondeo, the linkages are made for 'horizontal' use, and the accelerator cable will clip straight on! then you can use standard TPS, and not change any of the wiring!
Fitting the 2.0 throttle body would be a hell of a lot easier then due to the wiring etc? Basicly, does the inlet have petrol/ wires going into it or does it all go into the tb?
Does this have to be done with the engine out of the car, or is there enough room to do it with the engine in the car?
lucasdemoley
Postby Dazza on Mon Mar 13, 2006 2:11 am
Take Rhinopowers word if it helps mate, I believe it would work but I have not done it. You'd still need to alter the wiring for the ISCV tho.
It can be done with the engine in the car, and the wiring is part of a 'sub-engine loom' thats easily removed (Basicly only contains wiring for the inlet)
Dazza
Postby lucasdemoley on Mon Mar 13, 2006 2:16 am
Ok, cheers. No doubt I'll post again when I have everything infront of me and in a total confusion as to what to do where!lol.
lucasdemoley
Postby jdfiesta on Mon Mar 13, 2006 2:35 am
what happens with the injectors? are the focus ones used? do they work with the mondeo ecu, ie, are they the right impedance etc.
this is something i may consider, seems a lot to change though.
might pop down scrappies tomorrow and get a price
are the 1.8 and 2.0 focus ones the same?
Postby Dazza on Mon Mar 13, 2006 2:44 am
Focus inlet is stamped 1.8/2.0 so yes.
Focus injectors are used and as far as I know work perfect with the ECU, mine runs sweet as a nut.
Id expect to pay around £40 for the inlet
Dazza
Postby RS rob on Mon Mar 13, 2006 7:44 pm
ok so how do i go about connecting the throttle cable to the thottlebody?
does the mondeo 2.0 throttlebody item go straight onto the focus inlet manifold?
RS rob
Postby phil_pearce on Mon Mar 13, 2006 8:56 pm
can i use my rs1800 throttle body? i have got a price on all the parts but before i buy i need to know this. I dont mind buying a mondeo tb if i have to.
2.1 Zetec turbo Fiesta RS - 261bhp 310lbft
phil_pearce
Postby Rhinopower on Tue Mar 14, 2006 12:07 am
i've got a focus inlet for sale, £20 would be nice!
Postby lucasdemoley on Tue Mar 14, 2006 12:28 am
Rhinopower :i've got a focus inlet for sale, £20 would be nice!
How much inc postage? Have you got paypal? What other bits would I need if I was to use the 2.0 modaeo tb? (that wouldnt loose [ERRR] power over the focus one right?)
lucasdemoley
Postby Luke_Si on Sun Mar 19, 2006 12:48 pm
Have you got any more gain from using the fous one.
Because I am using the 105/130PS XR2i 1800 one with a modifed 2.0 TB on it that seems to be fine.
I just want to know to see if its worth me upgrading or not.
Luke_Si
Postby allinking on Sun Mar 19, 2006 1:24 pm
Just to let ppl know I used a focus throttle cable when i did mine fits a treat :)
allinking
Postby Dazza on Sun Mar 19, 2006 1:31 pm
Excellent to hear and thanx for informing me :)
They do two types of throttlecable for the focus (say Ford) and they are both about £21 all in. All the motorfactors around here dont stock throttle cables and sorry I didnt get a code for it
Dazza
