old post, no parts for sale : Parts For Sale | Fiesta Forums
Postby jayrs on Thu Feb 02, 2006 11:44 pm
if you dont see what ya after ASK i might just have it as i have lots of bits about
can get pic's of any bits wanted, open to offers, and deals for few items etc.
right as not many people seem to beasking about too much of this stuff, im gunna put it into sections, of £5 a item, £10 a item and anything else.
i want some of it gone as i wanna get on with my RS.
everything here is £5 each
chrome strut tops, not mint but not bad
MK3.5 electric window switches, got about 12 (per pair)
Screw on end for actuator
lights front and back (each)
FRST steering wheel, NO leather and the plastic spacer from back is missing
some fiesta mk3 inner trim
FRST main engine mount, cant remember condtion but idel for zvh conversion
these items are £10 each
FRST intercooler
coilpack
FRST boost pipe (metal one from turbo to intercooler
XR2I inlet manifold (same as frst but no sensors in it at all and not fuel regulator, might have fuel rail)
T2 standard down pipe
T2 standard actuator
T3 standard actuator ( when i find it, no end bit)
1 FRST/Xr2i drivers arch, 2 studs snapped, but cant replce them
1 FRST/Xr2i drivers side side skirt
FRST bottom wish bones support (like lower strut brace)
FRST brake bias valves (boltted to passanger inner wing)
FRST front hub housing complete with hubs (each)
T2 oil feed pipe
FRST boot pop (will check it still works) with boot pins
Zetec rocker cover, unpaited
few mk6 escort bits like lights, mirrors etc
£15 or more, bigger bits like gearbox etc is more
Escort mk5/mk6 master cylinder
ERST intercooler complete with top boost pipe, UNCUT! and still ford sticker on it
mk3 fiesta complete lock set
2x mint late spec xr2i wingback front seats
XR2I rear bumper ( black) x2
FRST front shocks (standard shocks and springs)
FRST front and rear anit roll bars
FRST brake servo and master cylinder
Escort 1.6/1.8 zetec inletmanifold complete with injectors and spacer plate
FRST gearbox
FRST drive shafts (pair
FRST cv joints (pair)
Heated front screen loom
Inner loom (just the job for electric windows , central locking etc for people wanted to add it to the
1.1's etc, its the bit that runs under the dash, itys been cut where the wires go into the engine bay
and all the wires that go to the back of the car, inc fuse box, )
i also got some mk2 xr2 bits, off the top of my head, (ask)
head, cpmplete with cam etc (early head!)
dizzy
carb with inlet (vac type, i.e later one)
come on guys and girls, got to go
FRST fuel pump/complete sender unit as 1 (standard, full working order)SOLD
dump valve, diaphram type, blue SOLD
XR2i rear spoiler, near mint apart from couple of busted studs SOLD
piper cross blue oil breather SOLD
FRST idle speed control valve SOLD
FRST gear slector SOLD
T2 exhaust manifold SOLD
FRST boost pipes (not a complete set as some damaged)SOLD
dump valve BIG T pieceSOLD
OFAB ecu, SOLD
£50 for chip SOLD
OFAB loom, someone has replaced a couple of wires on it to the amel vavle, with speaker wire by the looks of it but easy to replace it back to norm wire £50 SOLD
OFAB sensor panle, contains edis, co2 sensor and map sensor £60 SOLD
amal ( boost control) valve, sold on ebay
rad fan (in box) SOLD
speedo,with blue lockwood dials guy reset the clocks to zero, dunno why? SOLD
inlet manifold ( complete, injectors etc etc) SOLD
T3 manifold £15 SOLD
power felx front and rear anit roll bar bushes as well as the rear axle bushes £45 SOLD
2 GAZ rear shocks with lowering springs, adjustabe (not ride hight) SOLD
disc's and calipers (standard) SOLD
engine SOLD
charge carrier SOLD
peco BB4 back box SOLD
C/L motors SOLD
prices do not inc postage
these are the parts, still loads of other bits that are not in the pic's, the box of bits is from the frst too.
Image[/URL]
Image[/URL]
so, what ya want, all parts open to offers but prices will be plus postage
Postby jdfiesta on Fri Feb 03, 2006 12:49 am
if its OFAB i'll have the wiring loom and as many sensors as you can sell. send me a pm when you've got it
Postby Syorme on Fri Feb 03, 2006 1:48 am
whats the steering wheel like
Syorme
Postby craigc38 on Fri Feb 03, 2006 7:58 am
lo Jay :p
If the car ur breakin aint got the loom ur after i might have it in the 2i im breaking (getting the car 24th feb) so i will let you know..
rgds
im lookin to swap for a diesel or reliable golf, anything considered
craigc38
Location: xr2i spares to be collected from hounslow tw3 4lr
Postby STOKE7UP on Fri Feb 03, 2006 12:10 pm
sensor panel if it is ofac (map,edis,co2 pot)
thanks alex
stoke7up@yahoo.co.uk
STOKE7UP
Your car: Depends what day it is
Postby jayrs on Fri Feb 03, 2006 3:24 pm
jdfiesta :if its OFAB i'll have the wiring loom and as many sensors as you can sell. send me a pm when you've got it
will let ya know mate, any sensors in the inlet will stay in there mate other wise ill be stuck with it lol
Syorme :whats the steering wheel like
not 100% sure mate, if im remembering right its got the normal wear and tear, but could be wrong, will let ya know
craigc38 :lo Jay :p
If the car [ERRR] breakin aint got the loom [ERRR] after i might have it in the 2i im breaking (getting the car 24th feb) so i will let you know..
rgds
hello mate, what loom ya mean? or do ya mean the ecu if so not bits like that will be any good for my rs dude,
STOKE7UP :sensor panel if it is ofac (map,edis,co2 pot)
thanks alex
ok mate, the edis, co2 sensoer and plate are same as xr2i mate, i got all that as spares from a 2i i stripped ages ago, the map sensors different or course, but as for the edis, and co2 sensor and plate, maybe we coukld do a deal for that and the head rest?
Postby jayrs on Fri Feb 03, 2006 3:40 pm
Mikee_RS has asked about the loom, i have asked him to post it up on here as it easy for me to keep track of who wants what and who asked first so its all fair.
Postby jdfiesta on Fri Feb 03, 2006 8:27 pm
i have money waiting if its an OFAB loom
let me know fella
Postby jayrs on Sat Feb 04, 2006 12:00 am
well i now have the car, matey got it round on his mate trailer as its got a starting problem, it IS ofab so no spare ecu for me :( and its got a chip plugged in it, im thinking this might be why its not starting as he said hes got spark and fuel, but im gunna check tomorrow
also its got blue lockwood dials, seem matey decided to zero the speed :-? dunno why also its got gaz rear shocks, think fronts are standard but couldnt really see.
the steering wheel is fooked mate, theres not leather on it and the center cap parts is missing.
might do someone for a banger car for a few quid?
Postby jayrs on Sat Feb 04, 2006 10:01 am
car is being stripped today, post up what ya want
Postby STOKE7UP on Sat Feb 04, 2006 11:47 am
will leave the sensors then mate as i it is just the map i need just wanted to get a good whole panel
STOKE7UP
Postby Fezzy Turbo on Sat Feb 04, 2006 1:19 pm
Dont suppose its got a black interior ?
2009 FRS2 : 377bhp ATW / 395lb/ft :)
1990 FRST : Sold.
Fezzy Turbo
Tartan Turbo Terror
Tartan Turbo Terror
Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Postby jdfiesta on Sat Feb 04, 2006 3:19 pm
price for OFAB loom and MAP sensor if available
Postby jayrs on Sat Feb 04, 2006 8:54 pm
no mate, the interor is normal, but the recaro front seats have been replaced with the late spec xr2i wingbacks :-? why would anyone wnat to do that :lol:
give me a min to answer the other questions as im gunna put a list up of what i got, some will prob be missed out as i got to do it from memory for now
Re: @
Postby jayrs on Sat Feb 04, 2006 9:58 pm
STOKE7UP :will leave the sensors then mate as i it is just the map i need just wanted to get a good whole panel
ok mate no worries.
right cars all stripped, parts that are for sale is as follws, will get pics up of any parts that are asked about but i will have to do this sunday as the bits are still at my parents house.
never started the car today, had it turning over but car had no spark so wouldnt firer up, didnt have time to check it oevr as it had to be stripped but at least i know the engine turns ok.
OFAB ecu, it has a plug in chip, cant remember make but its a 165 chip as there isnt any other uprated stuff like injecters etc (cant split chip from ecu) chip is untested, but guy had car running so must work ok
OFAB loom, someone has replaced a couple of wires on it to the amel vavle, with speaker wire by the looks of it but easy to replace it back.
speedo,guy reset the clocks to zero, dunno why?
T2 manifold
engine bits, pipes, intercooler (standard) etc
2 front shocks, these look standard, springs might be standard i didnt look TBH
front and back anit roll bars
fuel pump
dump valve, diaphram type, blue with T piece
engine and gearbox, inc drive shafts and CV's
some other bits ive prob forgoten too
to start with im open to offers, if ya gunna PM me a offer, can you stick a post up on here saying you have PMed me and about what, want to keep it fair as some of ya have asked about bits already
will consider a swap/px if ya have something that im after
Postby jayrs on Sat Feb 04, 2006 10:10 pm
reisskahn asked about the ecu this morning, no offer as yet :)
Postby CyberMODS on Sat Feb 04, 2006 10:21 pm
frst bonnet ? opening rear windows with brackets and seals e.t.c .. if so how much please :D
first dibs if u do :D
CyberMODS
Postby jayrs on Sat Feb 04, 2006 10:28 pm
im keeping bonnet for now as a spare, open rears, the screws etc are rusty mate, might keep them as spares but havent decided, make a offer mate, glass is best collected mate but im on the isle of wight
Postby jayrs on Sun Feb 05, 2006 1:29 am
parts list with prices added to first and main post :D
as said, open to offers
Postby Raymondo on Sun Feb 05, 2006 1:41 am
Does it have a heated windscreen?
If it does do you have the two bolts/screw from the top of the a pillars for the earth?
Raymondo
Postby jayrs on Sun Feb 05, 2006 1:51 am
no mate no heated screen, but i got loads of bolts and stuff about if ya need some.
why just the bolts though? do fords not do them any more like the door hinge pins :x
Postby Raymondo on Sun Feb 05, 2006 2:00 am
ok mate. Im going to try ford tommorow to see if they do them, i only realised i needed them today.
Will you do the powerflex rear arb bushes seperatley aswell?
Raymondo
Postby jayrs on Sun Feb 05, 2006 2:06 am
if ya get stuck with ford let me know.
you mean just the 4 arb bushes? if so might do mate, would like to sell them as a lot, but if no interest then will split them, what i dont sell ill keep :lol:
Postby jayrs on Sun Feb 05, 2006 3:37 pm
right got all the patrs at mine now, will be taking pics of main bits later today, dont seem to be getting a great deal of interest on things :( will be sticking bits on ebay through the week im thinking if no one wants anything ( apart from whats been asked for already )
Postby jayrs on Sun Feb 05, 2006 10:26 pm
pic's added
Postby turboben1 on Sun Feb 05, 2006 10:47 pm
what area are you in mate intrested in the rear shocks do you have the springs for the front as well
turboben1
Postby jayrs on Sun Feb 05, 2006 11:06 pm
im on the isle of wight mate.
rear shocks are gaz adjustables with pi spings, fronts are standard shocks and standard springs unfortunaly
Postby jdfiesta on Mon Feb 06, 2006 12:52 am
as said above, ofab loom, £55posted? IOW is a little far for me, lol.
have money waiting
Postby Raymondo on Mon Feb 06, 2006 1:25 am
jayrs :if ya get stuck with ford let me know.
Cool. If you cant sell them all together then let me know mate :D
Raymondo
Postby MAD_Adamski on Mon Feb 06, 2006 2:19 am
just so people know that chip is the V GOOD sort :o so for the 165 people this is the ideal chip :) i have the 195 one :)
MAD_Adamski
Postby fiestamk3.5 on Mon Feb 06, 2006 7:09 am
how much for the peco is it a peco bigbore 4
fiestamk3.5
Postby BillyCabrio on Mon Feb 06, 2006 10:43 am
jayrs :im on the isle of wight mate.
If these are still avaliable i want!!
How old and how many miles they done, and what do they lower by?
Oh and how much inc P&P to DA1 5SP (just the rears).
:aviator:
Click My Siggy To See My Cabbie Restoration Thread, All 29 Pages of it, make that 30!!
BillyCabrio
Postby jayrs on Mon Feb 06, 2006 9:55 pm
jdfiesta :as said above, ofab loom, £55posted? IOW is a little far for me, lol.
have money waiting
yeah thats cool mate, PM me for details dude.
Raymondo :
will do mate
adamski frst :just so people know that chip is the V GOOD sort :o so for the 165 people this is the ideal chip :) i have the 195 one :)
is it, didnt know that, lol, cool cheers mate
fiestamk3.5 :how much for the peco is it a peco bigbore 4
yeah its a big bore 4 mate, make me a offer
BillyCabrio :
:aviator:
yeah still available mate, think its a 30-40mm drop (from looking at car before stripping it), dunno how old they are but ther look in good nick so prob not that old, as for milage, again without knowing how long they were on there i can say, but theres no leaks etc and the springs dont seem to have any rust etc as all the paints still on them, hope that helps, as for postage, cheapest would be royal mail standard parcels, its done by weight, guessing £10-£15, if ya said £15, if its any less ill send the diffence back to ya, if ya wanna wiat till friday/saturday i can take them down post office and find out price mate
Postby BillyCabrio on Mon Feb 06, 2006 11:55 pm
That'll be kewl fella.....
Put my name down for them then :wink:
I'll await your quote on the P&P :Q
BillyCabrio
Postby jayrs on Tue Feb 07, 2006 12:00 am
ok mate will do. will you need the cups on the top? ( not shown in pic) if so not extra charge for them but ill get them in the box for postage cost.
