2.0 litre zetec on bike throttle bodies
Postby RS_BOB on Wed Feb 08, 2006 5:28 pm
how do. currently hunting for bike throttle bodies and was wondering which type are good to use on a 2.0 zetec
i know asad used gsxr 750's. are the 600's any good or another makes suitable too
these will be fitted to what i have now found out is a st170 inlet :D which im happy about as its get the injector holes i wanted
RS_BOB
Postby chris-fiesta on Wed Feb 08, 2006 5:33 pm
Asad's the man to ask or do a search and check his recent post, very detailed to :wink:
chris
chris-fiesta
Postby Excursion on Wed Feb 08, 2006 6:26 pm
I had a set of these a while ago: GSXR 43mm
They came with what can best be described as rubber 'boots' that originally joined them to the cylinder head on the bike. They make fitting a doddle, fabricate a manifold using a Zetec head flange and pieces of tube welded on to connect to the 'boots'- easy!
Postby RS_BOB on Wed Feb 08, 2006 10:24 pm
oh asad post been a great help for me, [ERRR] made me look for st 170 inlet. i know he has used gsxr 750's but was out bid on a set. seen some 650 and also wanted to know what else would fit like the 750's
if not ill keep hunting
RS_BOB
Postby lucasdemoley on Sat Feb 11, 2006 1:25 am
How much do they cost, and what power do they give (soz to hijack)
Just because I keep talking about definetly doing it doesn't mean I'm actualy going to do it.
lucasdemoley
Postby Asad on Sat Feb 11, 2006 4:09 pm
Mine were from a GSXR1000. They are 42mm TBs.
I believe that the GSXR600 TBs are 38mm.
You should be able to get a decent set for around £80.
Asad
Asad
Postby scotty_boy on Sat Feb 11, 2006 5:30 pm
:( I want throttle bodies.
scotty_boy
Postby ant pittaway on Sat Feb 11, 2006 7:01 pm
excursion, i had them off you :) , mines nearly done, im also using the st170 inlet and injectors, they just need a bit of modifying :D
ant pittaway
Postby lucasdemoley on Sun Feb 12, 2006 6:14 am
Asad :Hi,
Asad
What kind of power difference do they offer? also, do they use a hell of a lot more petrol?
lucasdemoley
Postby RS_BOB on Sun Feb 12, 2006 10:34 am
ant pittaway - looking really nice, im guessing the header you have got is from the states? will it be custom piping to attach it to the rest of the exhaust system ?
Asad - once again cheers for your help and information
RS_BOB
Postby aaron on Sun Feb 12, 2006 1:54 pm
ant pittaway :excursion, i had them off you :) , mines nearly done, im also using the st170 inlet and injectors, they just need a bit of modifying :D
that looks the nut sack, I've got the same headers n down pipe, I've got some r1 throttle bodies in the pipe line, Would love to see this running
aaron
Postby Asad on Sun Feb 12, 2006 2:24 pm
Im using 330cc injectors so yeah it does drink a load of petrol. Im geting around 40miles to £10. But that is with giving it a bit of a caning! I havent got the art of economical driving sussed yet!
I'd imagine it would be more petrol friendly with standard ST170 injectors, something which I may put back on.
As for the header, there is a UK seller on Ebay - search for "obx focus" on ebay and you should find it. Seller's ID is nautica35.
Asad
Asad
Re: 2.0 litre zetec on bike throttle bodies
Postby fwr48t on Fri May 09, 2008 8:46 am
Hi All
Can someone tell me if i deffinately need an inlet and outlet to a fuel rail when using GSXR750 tbs on an ST170 engine? :-?
Regards: Navi
fwr48t
Postby heeman10 on Sat May 10, 2008 10:01 am
Yes you do. Fuel pressure will be controlled by a fuel pressure regulator, which requires a fuel supply and a fuel return back to the fuel tank. Throttle bodies require a regulated high pressure fuel supply to the injectors, unlike carbs.
Postby fwr48t on Sat May 10, 2008 11:29 pm
Thanks heeman10
Thought there might be a chance because there is only a supply connection on the throttle bodies i got off a bike.
Hit another set back today with a trial fitting, the alternator i got from Retro Ford is hitting the tbs and manifold i got made from Bogg Brothers. :x
What to do now?????
fwr48t
Postby Si_2000 on Sun May 18, 2008 10:43 pm
soz for another hijack but what controls the idle when useing throttle bodies? something that i thought about the other day whilst trying to find managment. thanks, tom
Si_2000
Postby ads_t on Mon May 19, 2008 7:13 pm
ant pittaway, what exhaust manifold is that on the engine, where can i get one??
ads_t
Postby krestudon on Tue May 20, 2008 9:56 pm
I have seen exhaust manifolds similar to that in ebay america, for their focus 2.0. dont know if it's engine is a black top or a different zetec.
do anybody know if these american manifolds will fit european silvertops? and going deeper, anyone knows which are the diferrences between euro and american zetecs? can i buy arp cam/head/con rod bolts from usa? and vernier pulleys?
krestudon
Postby SiZT on Sat May 24, 2008 7:04 pm
its an OBX manifold, look on ebay for 1.... only major difference between Euro and USA Zetecs is the inlet manifold AFAIK
Ratspeed :Maybe Wardy257 has a magazine article on it................
SiZT
Postby Oranoco on Sun May 25, 2008 9:56 am
These are my mates, as supplied by Bogg Bro's
In place
Oranoco
Postby SamT on Sun May 25, 2008 1:01 pm
i wrote up a guide on my site for using the st manifold and gsxr tbs :)
http://www.sportingfords.com/forums/viewtopic.php?f=16&p=19574#p19574
SamT
