FRST handling fine tunning
4 posts • Page 1 of 1
I'm going to drive my FRST on some trackdays and would like to get it handling better since I'm used to clio's.
I dare to say that the castor is wrong when it comes to handling, so does anyone knows any upgrade so that castor (at front of course) can be changed?
Camber can be changed without any sweat since lowering the FRST -40mm will give you at front almost -1.5 degrees and at back almost -0.4 degrees. I say its spot on
At the back, you might have to align the camber from one side since they usually are not equal
I used two washers between the drum and the axle arm to get the same camber of each side.
The red circles are not real
Any Track Nutters out there?
- BUTRE
You could upgrade to fully adjustable arms ....etc ...... i have seen it on a few cars that didnt have it before
2009 FRS2 : 377bhp ATW / 395lb/ft
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
No not that. I have seen a S2 with fully adjustable tca's, anti-roll bars ... etc ....... should handle the road/track with no problems
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
