[info] Zetec-turbo injectors that fit Zetec fuel rail
Postby disc on Mon Jun 20, 2005 8:53 pm
[FAQ/Guide'd as it's so useful! - Proj]
OK.
Since I'm plan to build ZT few months ago start search for sidefeed injectors that fit Zetec fuel rail. They can be not direct replacement fot ECC-IV, cause I'll use Megasquirt. And finally found!
Nissan 200SX (S14) injectors fit perfect in Zetec fuel rail! Just need to swap small O-rings, cause Zetec ones is little bit big.
Now some comparison:
Zetec injectors (1 800cc, 105HP):
Flow rate ~ 160-170 cc/min
Impedance - 16 Ohm
Nissan injectors (SR20DET - 2 000 cc, 200HP)
Flow rate - 375 cc/min !!!
Impedance - 10,7 Ohm
So if u plan ZT why don't you take a look at Megasquirt <-Click, also check Asad's Megasquirt topic <-Click. MS is cheap, easy DIY thing.
Now some pics.
Nissan fuel rail:
Nissan injector:
Zetec fuel rail vs. Nissan fuel rail:
Ford vs. Nissan injector:
And finally Nissan injector in Zetec fuel rail:
But that's not all. If you plan REALLY BIG power 375 cc/min can't be enought. 375 cc/min Nissan injectors are good for 300+ HP. Then... just simply shave the cap of injector!!!
Read more about this mod here:
http://forums.probetalk.com/showthread.php?t=1701147295
Ok, with "shaved" cap now you have ~550 cc/min injectors and can get up to 500HP (!?!).
Have luck!
Sorry for my bad english...
disc
Your car: 1991 Orion ZetecTurbo 270BHP
Postby Captain Tightpants on Mon Jun 20, 2005 10:12 pm
Looks like a good fit mate, top work.
As you say though, I would be concerned for the longevity of the injector drivers with a 10.7 Ohm impedance, On EEC-IV.
Definately the cheap way to do the ZT inlet. Not the best certainly, but a good way.
Thanks,
Captain Tightpants
Postby Asad on Mon Jun 20, 2005 11:37 pm
You could use those injectors with megasquirt, which is what he is planning.
You dont even need a flyback board.
GL with the install mate!
Asad
Asad
Postby heeman10 on Mon Jun 20, 2005 11:49 pm
This modifying of injectors sounds interesting. Depending on the shape of the underlying cavity the cutting is aimed to open up, it could be either a very simple way of getting better flow rates, or a good way to give yourself four injectors providing varying flow rates!
Postby StreetDragster on Tue Jun 21, 2005 8:05 am
Great info, Cheers Disc!
I'll add this to my website too if you don't mind?
StreetDragster
Postby disc on Tue Jun 21, 2005 11:17 am
Cheers mates!
Scort: Injectors are perfect for my install, but not for ECC...
Asad: Thanks!
heeman10: Try this mod with caution!
StreetDragster: Use all info whenever you like! If you want I can supply part number of injectors.. they are JECS
disc
Postby Avinitlarge on Wed Jul 27, 2005 7:05 pm
I fitted these injectors in my zetec rail in october last year, I am running OFAC management. They seem to be spot on, They do over fuel a little though. Also they are noisy, Even when new they are noisy, After a while you get used to it
NOTE: The Std ford injector power plugs do NOT fit the S14 injectors, You do have to change the plug.
Avinitlarge
Postby paradox on Tue May 23, 2006 3:00 pm
will the nissan injectors work with omex managment?
paradox
Postby allinking on Tue May 23, 2006 6:41 pm
Your best of using a foucs 2.0 manifold if your running a zetec and use any top feed injector :)
allinking
Postby disc on Tue May 23, 2006 8:04 pm
Omex :The 600 series ECU has two injector outptuts that are used to control 4 injectors semi-sequentially or up to 8 cylinders batch fired. Injectors should be high impedence, but low impedence injectors can be used with ballast resistors.
The 710 series ECU can control up to 12 injectors sequentially with controls for staged injectors. Injector start angle can be mapped and single cylinder trims are possible. Injectors should be high impedence, but low impedence injectors can be used with ballast resistors.
disc
Postby adamburzynski on Mon Jun 19, 2006 9:17 pm
injector talk baffles me... side fed, top fed, then greens beiges etc,...
can someone do a guide of the differences between the different types, and what can be used with what...
adamburzynski
nissan injectors
Postby MK4 Rick on Thu Jun 22, 2006 10:20 pm
i have some nissan injectors for sale
MK4 Rick
Your car: Mk5 Fiesta
Postby djpleban on Mon Sep 04, 2006 1:57 pm
I have one question. would only fitting the Nissan injectors (without any more mechanical/ECU modifications) give some extra power? would it have some disadvantages? thanks
cheers,
Michael
djpleban
Postby disc on Sun Sep 10, 2006 12:34 pm
djpleban :I have one question. would only fitting the Nissan injectors (without any more mechanical/ECU modifications) give some extra power? would it have some disadvantages? thanks
cheers,
Michael
Without any mechanical/ECU modifications your engine will run pig rich and performance will be worst than if you drive your car without engine :D
Engine can burn extra fuel (from larger injectors) only if there is extra air - fuel mixture mut be perfect to get decent or perfect result. If you add just fuel then mixture goes rich and engine can't burn it - result is poor performance or even engine can't start.
disc
Postby gcodin on Sun May 20, 2007 4:43 pm
How's the fuel consumption mate? :D
gcodin
Re: [info] Zetec-turbo injectors that fit Zetec fuel rail
Postby jonyb4 on Sat Jan 01, 2011 6:01 pm
awesome guide! you have just revoluntionised the use of the zetec inlet on Zetec turbo's!
Postby Tweek on Sat May 19, 2012 7:01 pm
Just bought some of those injectors as a Plan-B for my ZT build. Cheers :)
Your car: VW Golf GTD
Postby MK4 Rick on Sun Mar 16, 2014 1:22 pm
Mazda RX8 injectors also fit and there 450cc
MK4 Rick
Postby disc on Sun Mar 16, 2014 1:25 pm
It's good to know that Rick!
disc
Postby MK4 Rick on Sun Mar 16, 2014 3:08 pm
If the Subaru injectors go in the zetec rail the RX8 injectors will
MK4 Rick
Postby philip_d on Thu Jul 23, 2015 2:46 pm
Just noticed there is two different types of filters for these injectors, which one is best?
one has the filter near the bottom and the other has it near the top?
see here:
http://injector-rehab.com/shop/images/D/jecs3-04.jpg
Link:
http://injector-rehab.com/shop/Nissan-J ... -Feed.html
philip_d
Your car: Ford Focus RS Mk1
