[guide/FAQ] Identifying 105/130ps cams by eye
Postby alti on Fri Jul 15, 2005 6:20 pm
FAQ'd - Proj
Key:
A are the 105ps cams, used in the XR2i 16v
B are the 130ps cams, used in the RS1800 (and 2.0L?)
1: exhaust
2: inlet
3: cam phase sensor lobe
4: identification bands
5: flywheel end (?)
perhaps this can someone help.
alti
Postby PaulC on Fri Jul 15, 2005 7:23 pm
Great find :D Its spot on as well, my 130 spec cams I have match up with "B"
Postby Rhinopower on Wed Feb 01, 2006 10:55 pm
how can it be corred, neither of my 2.0l exhaust cams match?
top cam is from a series 2 2.0 zetec, bottom is from a series 1!
i've got a micrometer out and the lobes both have same profile, (height and width)
Postby PaulC on Thu Feb 02, 2006 12:33 am
Odd! Definately from a 2.0 zetec, not a 115ps 1.8 or anything like?
Postby Project on Thu Feb 02, 2006 5:17 am
No idea Rhino, but they're in sh*t-state. You going to use those again?!
Postby Rhinopower on Thu Feb 02, 2006 9:14 am
both 100% from a 2.0, the bottom cam matches bassboy's 2.0 exhaust cam as well!
the top one is broken, the bottom one one has surface rust, i'l stick it in the cleaning tank at work to bring it up as good as new, and throw it in this afternoon
Postby PaulC on Thu Feb 02, 2006 9:25 am
Just checked my 2.0 cam and the exhaust does match yours rhino!
RS1800 ones are the same as the pics above tho as I've got some of those cams
Postby madjim on Mon Feb 13, 2006 11:55 pm
Hi all new here, may be a silly question but do these cams fit in to the 1.8 n give you more power?
madjim
Postby abbat on Wed Feb 22, 2006 4:33 pm
Rhinopower :how can it be corred, neither of my 2.0l exhaust cams match?
So what exactly height and width was at your cams?And how did you measure it, where exactly?
Maybe it is a better way to know. If you 100% know that your cams is from 2.0L Mondeo.
Or maybe how can I measure lift of cam?
abbat
Postby escortbreakers.co.uk on Fri Mar 02, 2007 3:51 pm
130 cams are different to 2.0l cams.
i was told that the exhaust cams in both mentioned were the same but the inlet cam was not.
i have had a few sets of 2.0l cams and 130 cams.
i have noticed there seem to be different types or shall i say different rings in different places on alot of them.
here is three i have at the mo;
105 spec N stamped on both inlet and exhaust
2.0l with 90 stamped in inlet and the exhaust is blank
130 spec with N stamped on inlet and D stamped on exhaust
Postby ChrisFIN on Sun Apr 29, 2007 10:10 pm
I have compared cams from three different engines, Escort 1.6 '97 90hp, Escort 1.8 '94 105hp and Mondeo 2.0 '96 136hp. Made some measurements and came up with this:
1.6 intake ~43.8mm
1.6 exhaust ~43.8mm
1.8 intake ~44.3mm
1.8 exhaust ~43.9mm
2.0 intake ~45.2mm
2.0 exhaust ~44.5mm
When I was looking for 2.0 cams I got a few times offered cams that didn't differ from my 1.8 105hp cams at all.
Photos -> http://www.76s.net/zetec-kansi/index.html
Focus II, Fiesta Mk 1-2-3-6, Zetec+megasquirt+edis etc @ http://www.76s.net
ChrisFIN
Postby escortbreakers.co.uk on Mon Apr 30, 2007 8:59 pm
what about 130bhp 1.8?
Postby Smo on Tue May 01, 2007 12:35 am
There are various cams that were used in the 2.0 engine, i.e., there are differing part numbers. If I remember rightly, the 1.8 130PS exhaust cam matches that of one of the 2.0 combinations, and the inlet matches that of one of the other 2.0 combinations.
So therefore, even though a genuine 130PS set doesn't match any given 2.0 set, it would *probably* be safe to say that the 130PS cams and 2.0 ones are pretty much interchangeable.
Postby Smo on Tue May 01, 2007 12:48 am
Part numbers for anyone who is interested (to follow on from my previous post):
RS1800 (130PS) Cams
Inlet: 958M 6A266 CA
Exhaust: 938M 6A269 CB
Mondeo 2.0 02/1993 to 08/1996
Inlet: 938M 6A266 CB (No Match)
Exhaust: 938M 6A269 CB (Match)
Mondeo 2.0 08/1996 to 05/1998
Inlet: 958M 6A266 CA (Match)
Exhaust: 958M 6A269 CA (No Match)
I have to say, I think it's odd that the RS1800 inlet cam has a 95 year part number, but I can only imagine it was just replaced in some way, and that the actual cam itself is no different?
Postby Ollybee on Tue May 01, 2007 1:04 pm
Smo :I have to say, I think it's odd that the RS1800 inlet cam has a 95 year part number, but I can only imagine it was just replaced in some way, and that the actual cam itself is no different?
Now, that's a fair point!
Ollybee
Re: [guide/FAQ] Identifying 105/130ps cams by eye
Postby Greyxr2 on Thu Jul 03, 2008 7:44 pm
any idea where these cams are from? i think maybe a 2.0 but not sure.
http://i8.photobucket.com/albums/a27/li ... C00089.jpg
Greyxr2
Postby Greyxr2 on Thu Jul 03, 2008 9:27 pm
bump.
anyone?
need to know asap if poss.
Greyxr2
Postby FlashXR2i on Fri Jul 04, 2008 8:05 am
[quote="Greyxr2"]any idea where these cams are from? i think maybe a 2.0 but not sure.
thanks[/quote]
2,0 items
FlashXR2i
Postby Greyxr2 on Fri Jul 04, 2008 8:09 am
thanks, ill get them in asap :D
Greyxr2
Postby Motorga on Sat Mar 07, 2009 11:48 pm
I have a 1.6 16v zetec, I know it is difficult tune this engine because of the thunderous small valves, but I have a question, what cams would fit of my engine for maxmim power, 1.8 or 2.0, I have 2.0 and throttle body mondeo and I want to put 1.8 injectors or 2.0 , can give you some advice ?
Motorga
Postby escortbreakers.co.uk on Sun Mar 08, 2009 10:13 am
well i know back in 1998 when i was building up a 2.0l engine i noticed that the 130 inlet cams were different part numbers from ford than the 1993 mondeo 2.0l!!!!!!!!!!!!
i have had mant different sets of 130 cams and there does appear to be a few different types.
there seems to be some that have twin rings inlet and outlet and soem that dont.
i recon you cant got wrong with genuine rs1800 cams [ERRR] at the end of the day a 130bhp 1.8 has got to be more tuned than a 136bhp 2.0l!
but then were only talking a few bhp here, nothing really to worry about
