do FRST braided lines fit cossie caliper?
Postby ianFRST on Tue Aug 02, 2005 8:24 pm
says not cossie on the bottom on the goodridge pack :-? :rolleyes:
Postby FezzyMK3.5 on Wed Aug 03, 2005 1:52 am
no you have to have new ends made up to fit them ! :)
FezzyMK3.5
Postby ianFRST on Wed Aug 03, 2005 9:21 am
bigger or smaller?
Postby Max M4X WW on Wed Aug 03, 2005 9:45 am
:x :x :x
Your joking? I was sure they fitted :-? :-? :-?
Postby ianFRST on Wed Aug 03, 2005 9:51 am
:( says they dont fit cossie calipers on the packet
so can you just remove the ends that go in the caliper and replace them? because i dont want to have 2 buy another set :rolleyes: :oops:
Postby Max M4X WW on Wed Aug 03, 2005 10:26 am
Hmm, Just looked at mine. Maybe it means not Fiesta Cosworth?
The ends on them must be the same as the standard hoses and im sure they fit.
Postby PaulC on Wed Aug 03, 2005 10:34 am
My goodridge ones said all fords except cossies if I remember correctly.
Postby PaulC on Wed Aug 03, 2005 10:35 am
Max M4X WW :Maybe it means not Fiesta Cosworth?
A what? :lol:
Postby Max M4X WW on Wed Aug 03, 2005 10:38 am
No idea. They say Fiesta XR2i not Cosworth.
Andyhardy where are you
Postby andyhardy on Wed Aug 03, 2005 1:14 pm
Mine slapped straight onto my Cossie calipers.
Bought XR2i/FRST Goodridge braided hoses.
Can't see how the unions can have changed!
Postby EvilFranky on Wed Aug 03, 2005 1:53 pm
Same as Andy here, fit straight onto my Escort Cossie calipers.
EvilFranky
Postby MarkRS2K on Wed Aug 03, 2005 1:57 pm
I can third that :D
MarkRS2K
Postby Max M4X WW on Wed Aug 03, 2005 2:05 pm
:x Go away cossie brake people lol.
Postby MarkRS2K on Wed Aug 03, 2005 2:07 pm
:P
MarkRS2K
Postby fiesta_turbo_daddy on Wed Aug 03, 2005 5:27 pm
ill fourthed that :lol:
fiesta_turbo_daddy
Postby ianFRST on Wed Aug 03, 2005 5:48 pm
i just had a go at doin it....... :(
was a bit tight, undid it, and it seems to have wrecked the theread on the braided hose :( :( :( :cry:
Postby Max M4X WW on Mon Sep 19, 2005 4:28 pm
BUMP! They fit in my calipers. Proj needs to update the guide index i think!
Postby xfactor on Mon Sep 19, 2005 4:58 pm
They will fit fine on a fiesta the difference is the join at the brake pipe end not the caliper, therefore on the cosworth the fitment to the pipe is different, but the fitting of the caliper end is the same so they will work no probs.
Call 01753 632811 or visit http://www.xfactormotorsport.co.uk
xfactor
Authorised Trader
Authorised Trader
Postby Sphinx on Mon Sep 19, 2005 5:11 pm
Yeah surely if cossie calipers fit on a fiesta, and the standard fiesta pipes fit the caliper then the FRST/XR etc braided pipes will fit the caliper and car, just logic.
Postby Max M4X WW on Mon Sep 19, 2005 8:47 pm
Exactly!
Postby Zetecfiesta on Mon Sep 19, 2005 11:58 pm
so thats sorted then braided lines will fit on to exsiting metal brake pipe and the cossie calliper? hope so i need some soon too!
Zetecfiesta
