Zetec Turbo engine - whats it worth?
Postby Red16 on Thu Aug 04, 2005 2:32 am
zetec turbo engine, never been started or ran
2ltr block rebored to 86mm
calibra turbo pistons (new rings) on zetec rods
ARP rod bolts
new big end and main bearing shells
new main bearing cap bolts
new oil pump
new water pump
breather under exhaust manifold blocked
2 new breather ports fitted
turbo oil return fitted
1.8 sump and oil pickup
cylinder head drilled and tapped for fitment of Escort RS Turbo exhaust manifold
valves lapped in
new valve stem oil seals
Rocker cover silver with black FORD and DOOHC 16V lettering
RS Turbo manifold included but no turbo, all new gaskets but no head gasket
whats this worth?
RS1600i restore, weld in multipoint cage, t34 zetec turbo
http://www.passionford.com/forum/viewtopic.php?t=130905
Red16
Postby heeman10 on Thu Aug 04, 2005 3:19 pm
Is it worth the laughter in which you'd be immersed when I fitted it into the Metro? If so, I'll take it and put it in there, no joke ;)
Postby SimonT on Thu Aug 04, 2005 3:46 pm
I'll say a grand
Too old and too bald.
SimonT
Your car: Fiesta Zetec S TDCi
Postby Red16 on Mon Aug 08, 2005 1:20 am
bttt
Red16
Postby joel_winders on Mon Aug 08, 2005 10:29 am
i'd say about £200 now can i buy it lol :lol: :lol:
i'd be prepared to pay about £1000 for it maybe even a bit more, but ive got my engine now :Q
xr2 turbo
joel_winders
Postby RosscoPeeco on Mon Aug 08, 2005 4:55 pm
id be prepared to pay a grand, dont suppose u do 6 or 9 months intrest free do ya :D
RosscoPeeco
Postby Red16 on Tue Aug 09, 2005 4:52 pm
no can do on the finance fron... im as brassic as the next bloke :lol:
Red16
bits
Postby s2turbo on Tue Aug 09, 2005 5:54 pm
bit off subject but where u get the (insert ghey rap term) rocker cover and spark plug cover from
s2turbo
Postby RosscoPeeco on Tue Aug 09, 2005 7:04 pm
hhmmmm, dont think i can afford that then, would love it, so would my mechanic, more money for him, but dont think his missus would be happy if i got it
RosscoPeeco
Postby Red16 on Tue Aug 09, 2005 11:57 pm
s2turbo it was off ebay for about 10 quid. looks nice but the pegs its screwed into need cutting down slightly as you can see in the photo it sits a tad higher than the rocker cover, easy done tho :wink:
RosscoPeeco you girl would love it mate :Q
Red16
Postby lazy_arse_pie on Wed Aug 10, 2005 6:18 am
whats needed to be complete and ready to run/fit ?
lazy_arse_pie
Postby Red16 on Thu Aug 11, 2005 12:29 am
engine management, inlet manifold, alternator and flywheel, not a problem if its going in a fiesta turbo, head gasket, timing belt, alternator belt
Red16
Postby Red16 on Sat Aug 20, 2005 2:18 am
bump
Red16
Postby xr2i_babe on Sat Aug 20, 2005 9:59 am
how do u no it will run tho as its never been run. compression could be out etc?
dont no how the full zetec engines work but ive had alot problem from my zetec bottom end
xr2i_babe
Postby ianFRST on Sat Aug 20, 2005 10:46 am
xr2i_babe :how do u no it will run tho as its never been run. compression could be out etc?
what do you mean by the compression could be out :-?
its a new build engine, any competant mechanic could build an engine up without much hasstle. all new parts have been used etc
as for yours, well, id have a word with who ever built it.
Postby Max M4X WW on Sat Aug 20, 2005 5:27 pm
You not putting it in the S1 anymore then? :(
Postby ianFRST on Sat Aug 20, 2005 6:16 pm
i think you'll find it was goin in place of a 2l williams engine :D
Postby Max M4X WW on Sat Aug 20, 2005 7:14 pm
Well he has a topic on PF about putting it in an S1!
Postby heeman10 on Sat Aug 20, 2005 8:49 pm
It was originally destined for French tat :p
Postby xr2i_babe on Sat Aug 20, 2005 8:57 pm
Are you likely to be selling, or do you just want to know a price?
Maybe interested in the near future.
xr2i_babe
Postby Red16 on Sun Aug 21, 2005 1:32 am
compression etc on the engine will be spot on, block has just been rebored to accept the larger diameter forged vauxhall pistons, new piston rings fitted and all 16 valves lapped in and leak tested :D
it was originally destined to go in my Clio 16v in place of the williams engine thats in ther now, but i planned on fitting it into my Escort RS1600i not a S1 :wink:
i was just geting an idea of what its worth to people because im interested in selling it as i want to build a new higher spec engine for my RS16i.
Red16
Postby xr2i_babe on Sun Aug 21, 2005 10:19 am
What turbo is it designed for, and would a T3 go straight on and run right?
I could be a potential buyer if it goes up for sale!
xr2i_babe
Postby heeman10 on Sun Aug 21, 2005 11:24 am
xr2i_babe :What turbo is it designed for, and would a T3 go straight on and run right?
Check out his sig. T34. What do you mean by "designed for"? :-?
Postby Red16 on Sun Aug 21, 2005 1:12 pm
i was planning on using the t34 i have but a t3 would be fine :Q
its up for sale now on ebay :D
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 4570195014
Red16
Postby STOKE7UP on Sun Aug 21, 2005 1:13 pm
in the pics the t34 is sat on a escort rs turbo manifold which was made for a t3
so you would think one would fit just wont run as high boost
STOKE7UP
Your car: Depends what day it is
Postby Red16 on Sun Aug 21, 2005 1:30 pm
yeah the t3 will fit straight onto the manifold on the engine
Red16
[color=red]PLEASE PLEASE HELP ME [/col(ESCORT RS TURBO SUMP)
Postby maddogwhite(29) on Tue Aug 30, 2005 6:43 pm
CAN SOMEONE PLEASE HELP I HAVE A FIESTA RS TURBO WITH A T3 CONVERSION AND IT KEEPS BLOWING TURBO'S AND I HAVE BEEN TOLD THAT I HAVE TO PUT A ESCORT RS TURBO SUMP ON INSTEAD AS THE ESCORT SUMP HAS THE OIL RETURN GOING INTO THE SUMP AND NOT THE BLOCK LIKE MINE ON THE FIESTA :devil:
CAN SOMEONE HELP ME GET THIS CAR WORKING RIGHT GOD DAM :-?
maddogwhite(29)
Postby phatboy on Sun Sep 11, 2005 9:48 pm
someone got a seriously good deal!
damn id kill for a 2L turbo!
phatboy
Postby Farooq on Mon Sep 12, 2005 12:53 pm
maddogwhite(29 u still havnt sent me the info yeT?
Farooq
Postby heeman10 on Mon Sep 12, 2005 3:09 pm
Man, it sold for 920? :o
