3 BAR MAP FAULT!! help needed
4 posts • Page 1 of 1
ive just put my brand new 3 bar map sensor on my ofab frst, but the car is now running lumpy and miss fireing when i rev it. i put the standard 2bar back on and every think is ok again
is there 2 sorts of 3 bar map sensors one for cossies and another one for rst's? or do you think they have sent me a faulty one???
any advise would be greatly thankful, cheers
- bluebones
bluebones :cheers bud,will it run a 2.5 with out a map??
You can't change the MAP sensor for another with a different reading without having a remap.
The signal voltage for 10psi of boost on a 2bar sensor will be completely different to that of a 3 bar or 2 bar sensor.
