MSN - Don't quite get this...
21 posts • Page 1 of 1
Had a couple of times recently where MSN won't let me log in, although it was kind enough to provide me with this message:
Anyway, it's happening again at the moment, and usually I'd take that for what it says, i.e, the service is actually unavailable. However, I just tried to log in with two old accounts and both allow me to log in. I go back to my normal one and it still doesn't allow me to log in, coming up with the message quoted above...
The only difference between these accounts is that my old ones were @hotmail.com and this is @msn.com. Anyone else with an @msn.com email address that can or can't get on at the moment?
Searching for the error code above just seems to suggest exactly what it says, that the MSN Messenger service is having probs.
MSN Messenger :Signing into MSN Messenger failed because the service is temporarily unavailable. Please try again later. 81000314
- Smo
Ok, I should add to this...
Both the times before that I couldn't get on, Grant (MotorcyclesFish) couldn't get on either. Funnily enough, he's just text me to say he can't get on either! That puts the @msn.com email address theory out the window...
What's going on?!?!?!?!
- Smo
Could be that the server that holds your user account information is having problems. It might be a different one to your other accounts.....
- Paul RS1800
- Blue Thunder
Sounds about right. I thought it was a problem with just my machine on my LAN here, just spent about 20 minutes fiddling with the IP settings and DHCP, connecting via wires, connecting via wireless, blah blah effing blah ad nauseum.
Must be a user server problem, as my brother can get onto msn through an almost identical connection (he's on DHCP on our router though, I need my ports lol).
Modern technology eh? Might go and watch Dogma instead...
- MotorcyclesFish
- Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
- Smo
Yeah, we must both be on the same bit of coax that comes down from London to Thanet. Someone in Margate's probably taken the terminator off the end...
- MotorcyclesFish
- MotorcyclesFish
- MotorcyclesFish
- Smo
This is really starting to annoy me now!
Is no one else at all having this problem?
Everyone else I've managed to ask is on fine!
- Smo
Sometimes I fire up MSN and it can't connect, it's terrible... I have to ignore it even more than usual.
- Ollie
- Your car: VW Polo SEL 1.6 TDI
Car: 1988 Ford Fiesta XR2
It's just a big fat huge arse when I need to talk to someone or it dies right in the middle of a conversation
- Smo
I've registered another address, which is connected fine. Bloody weird if you ask me.
Temporary "bitching about MSN" address is kawasakibloke@hotmail.co.uk. Add me if I normally whinge at/talk to you, chances are I'll be bored until normal addy comes back...
- MotorcyclesFish
andymac :it's to do with the contact relationships, is a bit buggered at MS I believe. Is working ok for 99/100 people.
Where'd you find that out? Any word on when we can expect it to be fixed?
- MotorcyclesFish
- chris-fiesta
- Smo
MotorcyclesFish :andymac :it's to do with the contact relationships, is a bit buggered at MS I believe. Is working ok for 99/100 people.
Google, and I was watching some other boards when it started. Seems to be intermittant, works fine now for me *shrug*
Nothing to see here...
- andymac
- Elite Pie Master
- Your car: Your car: Your car: Your car:
- chris-fiesta
