Rover M16 inlet on zetec engine with ofab/ofac guide
Postby Red16 on Sat Oct 29, 2005 6:43 pm
heres how the complete rover m16 inlet manifold looks
rover fuel rail modified by drilling and tapping 2 new holes to allow fitment of the fiesta turbo fuel pressure regulator
the old throttle body on the end of the rover plenum was cut off as in the below pic
idle speed control valve was fitted by drilling and tapping the necessary holes to allow it to screw onto the plenum, a spacer plate was needed to prevent the sensor plug fouling the plenum. a flange to suit the fiesta turbo throttle body was made, and welded onto the end of the open rover plenum chamber
rather than use an adaptor plate i cut the flange that bolts to the cylinder head off the rover inlet
and also cut the flange from a zetec manifold
then welded the two together, the injector ports needed a small amount of weld build up and then have it ground out inside the port
this face was the milled flat at work, this was necessary because when it was welded the flange wasnt bolted down to something solid so it warped and was no longer flat
heres the finished face, all nice and perfectly flat and smooth, it may not look it in the pic but it is 100% true
the finished manifold with all the ancillary's bolted on looks like this :Q
RS1600i restore, weld in multipoint cage, t34 zetec turbo
http://www.passionford.com/forum/viewtopic.php?t=130905
Red16
Postby jdfiesta on Sat Oct 29, 2005 6:57 pm
looking good, fine piece of work
Postby heeman10 on Sun Oct 30, 2005 3:18 am
FRST blues? :o Don't tell me you're going to do all that then limit yourself to 160bhp Benjamin? :p
Postby Red16 on Sun Oct 30, 2005 6:15 am
heeman10 :FRST blues? :o Don't tell me you're going to do all that then limit yourself to 160bhp Benjamin? :p
:lol: :lol:
no theyre just in ther cos i dont have any other injectors yet :wink:
Red16
Postby FezzR on Sun Oct 30, 2005 9:48 am
good work mate
could do with some measurements if you can get them or if you know anyone that can get them
measurements needed are the green lines
FezzR
God Damn Lazy
God Damn Lazy
Postby alti on Sun Oct 30, 2005 12:21 pm
looks very good :)
fine work!
but whats the main reasen that do you use the
rover manifold?
flow the stock zetec manifold so bad?
thanks alti
alti
Postby Red16 on Sun Oct 30, 2005 6:36 pm
alti :but whats the main reasen that do you use the
rover manifold?
because the rover manifold does not use a crossover pipe :wink:
Red16
Postby Red16 on Sun Oct 30, 2005 6:47 pm
the measurements between the ports are measured from the zetec flange, as i can no longer measure the rover manifold as the zetec flange is welded on, strange how the distance on the right hand side of the pic is smaller than the other two measurements.
and the height i had to guess at between 30 and 35mm as its also hidden away behind the zetec flange.
hope this helps :wink:
Red16
Postby FezzR on Sun Oct 30, 2005 7:18 pm
thanks mate that helps loads :D
its probably too good for what i need but hey worth keeping in mind :wink:
FezzR
God Damn Lazy
God Damn Lazy
Postby Red16 on Sun Oct 30, 2005 8:08 pm
no worries :D what you planning ?
Red16
Postby FezzR on Sun Oct 30, 2005 8:14 pm
have a 1.3HCS turbo on the go (very slow go) as i thought manifolds are proving to be a bit of... well im sure you can guess :cry:
FezzR
God Damn Lazy
God Damn Lazy
Postby Red16 on Sun Oct 30, 2005 9:04 pm
yeah, know what you mean :(
Red16
Postby turboboss on Tue Nov 01, 2005 2:58 pm
red16
when will the car be finished.. next year there are going to be some powerful fwd cars about
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
turboboss
Postby Red16 on Wed Nov 02, 2005 1:00 am
turboboss :when will the car be finished.. next year there are going to be some powerful fwd cars about
next year :Q im hoping to have it sorted for around about april maybe may :D
keep an eye out on my passionford thread in my sig, progress reports added regularly :wink:
Red16
