Metal Clutch Ratchet
Postby festaturbo on Wed Apr 10, 2002 4:42 pm
Clutch ratchet has given up again after only 2 months! used a cheap pattern part...neva again. Should i get the ford item or could any one tell me where i can get a metal clutch ratchet. I keep hearing about them. Has anyone got one? Where can you get them?
CheeRS
festaturbo
Postby snake on Wed Apr 10, 2002 6:30 pm
Erm, get a Ford one and it will last, they are only about £10
snake
Trainee Burger Flipper
Your car: ford
Postby Ian C70T5 on Wed Apr 10, 2002 11:41 pm
ahhhhhh. mines gone too. i think
What are the symptoms, mine makes noises when reversing and when i change down a gear
Ian C70T5
Das Ist Kapput
Das Ist Kapput
Postby nigel on Mon Apr 22, 2002 8:03 pm
does a mk5 rs2000 clutch pedal and ratchet fit?
this pedal does`nt use a ratchet
nigel
Postby Maff Si on Sun Nov 17, 2002 7:30 pm
Dunno my ford one only lasted 6 months B4 it started clicking again, changed the pedal bushes too :rolleyes: :-?
No Filler Nova Killer - Goes Like A Bomb
When I'm not here I'm somewhere else
Maff Si
Your car: Nothing til end of the month
Postby Jur on Mon Nov 18, 2002 4:10 pm
hmmz.. common Fiesta (ford) problem ..
just changed mine.. was in there for 10 years..
changed it for an original one..
had the same problem before..
guess it works fine for around 60kmiles
*If you start to see in Black and White, you know you're pulling enough G's*
Jur
Postby turboboss on Tue Nov 19, 2002 7:37 pm
right then just do away with the self adjusting ratchet, ford did a
conversion on the late mk3 fiesta 94-96 that made the adjusting mechanism manual which i have on my fiesta due to the trouble i had with my ap four paddle clutch so you can adjust the pedal to where ever you desire by turning a nob which locks the small toothed arm in position i will post the finis codes later once i find the receipt
turboboss
Postby Maff Si on Tue Nov 26, 2002 8:19 pm
No 31 - 7304012 - £1.38
No 30 - 7304020 - £2.12
No 29 - 7346848 - £1.82
No 3 - 7304014 - £21.46
Not sure if there are any other parts needed :rolleyes:
Maff Si
Postby turboboss on Tue Nov 26, 2002 9:53 pm
spot on m8 ur heard about it aswell sorted my clutch no end also the part that the small paw hits against u have to cut off the part where the number ten is pointing too
thanks turboboss
turboboss
Postby FezzR on Wed Nov 27, 2002 1:42 am
interesting VERY interesting :wink:
FezzR
God Damn Lazy
God Damn Lazy
Postby XR2HI on Wed Nov 27, 2002 10:07 pm
Do you need the a different clutch pedal, if so whats the difference.
A stupid question i know but i had to ask.
XR2HI
Postby FezzR on Fri Nov 29, 2002 12:05 am
XR2HI :Do you need the a different clutch pedal, if so whats the difference.
i thought the image illustrated it quite well :rolleyes:
FezzR
God Damn Lazy
God Damn Lazy
Postby F.U.K FESTA on Sat Aug 06, 2005 7:44 pm
in the pic what does #30 actually do??
F.U.K FESTA
Postby Jur on Sat Aug 06, 2005 8:00 pm
F.U.K FESTA :in the pic what does #30 actually do??
It locks the toothed part in place.. so that the pie-piece shaped (don't know the exact english word for it) part will stay in the selected position..
the standard clutch ratchet is self-locking.. and disfunctions every once and a while (-:
Jur
Postby FezzR on Sun Aug 07, 2005 12:17 pm
what jur said :D
FezzR
God Damn Lazy
God Damn Lazy
Postby CRF on Fri Aug 12, 2005 9:03 pm
http://www.fiestaturbo.com/phpBB/viewtopic.php?t=33200
Not the funnest of jobs in the world!!!
CRF
