Rear Disk Conversion, (Pic of Parts) Updated
Postby MikeyXR2i on Wed May 14, 2003 6:52 pm
HI Peeps just recieved all my Rear disk conversion parts. Its all brandnew including hubs caliper mounting, bearings the lot.
Just thought it would give you all an idea whats needed.
Will put up more pics when the job is progessing, as ive got to get the calipers yet.
MikeyXR2i
Postby FlyKai on Wed May 14, 2003 6:55 pm
lovely-jubbly!
How much did you pay? Where'd you get it from?
FlyKai
Postby ianFRST on Wed May 14, 2003 6:56 pm
sweet dude. keep us updated as im thinking of doin that :P
Postby TJ on Wed May 14, 2003 6:57 pm
How much that set you back mate?
TJ
Postby MOONDUST FRST on Wed May 14, 2003 7:08 pm
Im doin this too :D just need a new handbrake cable :)
MOONDUST FRST
Postby MikeyXR2i on Wed May 14, 2003 7:15 pm
HI peeps, the conversion cost me £328 in all, the conversion uses either Sierra Sapphire Cosworth rear calipers, or rear's from the granada scorpio they are the same calipers.
I got them from the Fiesta Centre
here's my bill
Rear Disk Conversion Kit for Mk3 Fiesta £161.60
Handbrake Kit For Rear Disk conversion £29.95 (Ford Genuine Cable)
Brake Disks (EBC) Crossdrilled £24.95
Brake Pads EBC Greenstuff Cosworth Rear £28.20
Post & packing 24h £9.80 :D
Total £328.36
Gonna Paint it all up nicely Hammerite gold to match my Cossie Fronts.
MikeyXR2i
Postby TJ on Wed May 14, 2003 7:20 pm
Cool mate!! Lemme know if you want a hand with anything! !
TJ
Postby FlyKai on Wed May 14, 2003 7:38 pm
Excellent stuff!
Fiesta Centre's just down the road from me, I do like them. Saw a slightly overstyled yellow frs on 19"s therev once, believe it's been posted b4.
FlyKai
Postby Stoned on Wed May 14, 2003 7:45 pm
Yeah keep us informed as it's something I want to do too!
Stoned
Postby Stoned on Wed May 14, 2003 7:46 pm
I also gather 'Hi-Spec' offer a rear conversion kit according to X-Factor
Does anyone know about this?
Stoned
Postby MikeyXR2i on Wed May 14, 2003 8:02 pm
TJ :Cool mate!! Lemme know if you want a hand with anything! !
Thanks TJ
MikeyXR2i
Postby MikeyXR2i on Sun May 18, 2003 12:23 am
Hi peeps the work is progressing, picked up calipers today, one of them is brand new, they cost me 20 quid!!!.[/img]
The Calipers are also gonna be stripped and cleaned then painted.
MikeyXR2i
Postby Stoned on Sun May 18, 2003 8:33 am
Excellent. Once you are done I think this will be one for the technical section sticky list!!
Stoned
Postby blackRS on Sun May 18, 2003 8:40 am
very nice mate
How comes you need to replace the hubs ?
Adam
blackRS
Postby MikeyXR2i on Sun May 18, 2003 12:26 pm
Well up on the rear, as standard the wheel studs are mounted in the drum.
Where as on a brake disk there isn't any studs, so you need a Hub carrier.
And the disk sits over the carrier with the studs coming through. And all the bearings on a disk setup are in the Hub.
MikeyXR2i
Postby RS_Rawli on Sun May 18, 2003 12:34 pm
hmm, ive got some 4x4 cossie rear brakes in the garage, along wioth drilled n grooved disks :P
are they easy to fit?
how much can i get them adaptor plates for?
would i need a bias valve cos of the xtra power at the rear?
rawli
Postby MikeyXR2i on Sun May 18, 2003 12:38 pm
you can buy the Adaptor plates from the fiesta centre, don't know how much they are seperatly though.
MikeyXR2i
Postby RS_Rawli on Sun May 18, 2003 12:40 pm
whats the deal with replacing the hubs?
how much are they?
basically ive got the brakes themselves - calipers carriers disks n pads
just wonderin how much itd set me to convert my rears to disks
rawli
Postby MikeyXR2i on Sun May 18, 2003 12:43 pm
you can buy the plates, hubs, bearings, all the bolts, braided brake hoses, all for £160. but then you need to buy disks, pads, handbrake cable setup with spacers to give adjustment. You can get it all from the fiesta Centre. cost me £328 in all.
MikeyXR2i
Postby Stoned on Sun May 18, 2003 2:53 pm
Thats where ill be getting my stuff from. Did you get the bias valve as well to adjust the power?
Anyhow, hurry up and do it so we can all read about how easy it is ;)
Stoned
Postby MikeyXR2i on Sun May 18, 2003 3:24 pm
you don't need to buy a bias valve, you have pressure valves under the bonnet, bolted to the inner wing, behind the battery, this adjusts the pressure of braking to the back. But you shouldn't have to adjust it.
MikeyXR2i
Postby FezzyMK3.5 on Tue May 20, 2003 10:23 pm
Mikey are the discs for a fiesta or are they for the cosworth and is that £25 for the pair !?
FezzyMK3.5
Postby MikeyXR2i on Tue May 20, 2003 10:33 pm
hi m8, yeah if you use the fronts off a Mk3 Fiesta Non-vented, they are the right Width for the rear cosworth caliper. Also if you use those disks they make the offset right just like the drum setup offset. The price for the disks was £24.95 each, =£49.90
MikeyXR2i
