Guide to fitting central locking in a 3dr Mk3 Fiesta
Postby heeman10 on Wed May 21, 2003 7:55 pm
Ok, as this has been asked so many times, I thought I would put a guide on here for those who DO use the search facility! :D
To fit central locking to a 3dr Mk3 Fiesta, you need to acquire the door latch mechanisms from another Fiesta which has/had c/l, eg XR2i, Ghia etc...these can generally be found for about £30. On each side, there will be four wires.
1. White wire
2. Yellow wire
3. Live
4. Earth
The white and yellow wires are the lock and unlock wires. The white wire on the driver's side needs to be connected to the white wire on the passenger's side, and the same needs to be done with the yellow wires on each side. That's that job done.
The earth wire on each side needs taking to a suitable earth. I found there was already an earth bolt underneath the plastic sill on the driver's side. On the passenger's side I used a self-tapper into an existing hole in the sill under the plastic sill cover.
The live wiring is the most complicated, but not difficult. Bring both live wires into the cockpit and connect one to the other. This needs to be done in such a way that one wire is still free to be connected to a suitable live, perhaps using an IDC type connector (Scotchlock), or by soldering. There should now be a free wire which can be connected to the permanent live busbar on the back of the fuse box. Not being a genius at this sort of thing, I used the permanent live from my head unit. An in-line 15A fuse between the c/l live wire and the permanent live wire you're using ought to suffice.
Making sure the passenger door is open, shut the driver's side door and lock it. Hopefully you'll hear the solenoids operating the locks, and all will be groovy! :Q
Hope this helps anyone who isn't sure of what to do.
James.
Postby eXtreme-fiesta on Wed May 21, 2003 9:16 pm
handy harry cheers jimbo :D
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby Huggie on Wed May 21, 2003 9:43 pm
As easy as that!!! :)
Huggie
Location: Drives: People Mad oh...and a Multi Coloured Fezzy
Postby Rich si on Thu May 22, 2003 2:04 pm
you make it sound simple!
Wish my central locking still worked, damn thing opens itself as soon as its locked! :(
Rich si
Postby eXtreme-fiesta on Thu May 22, 2003 8:44 pm
just got my central locking kit and lookin at it and looking at the guide it seems like an absolute piece of piss!!
Cheers davetanner and good luck with the insurance mate :wink:
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby heeman10 on Sun May 25, 2003 12:36 pm
BTTT for Al :D
Postby BenSeb on Sun May 25, 2003 8:20 pm
done mine today! works a treat :P
the hardest bit is getting the wires through the rubber sleave between the door and the body - with 3 wires already in there. hate to think what im gonna do when elec windows go in!
BenSeb
Postby eXtreme-fiesta on Wed May 28, 2003 6:52 pm
done mine today :D
next stop alarm shop to get it hooked up to my key fob & alarm :)
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby Smacattack on Thu May 29, 2003 7:40 pm
Ure the man James :lol:
Help me theres no modding here!
Smacattack
Postby alwaysmods2do on Sun Jun 08, 2003 9:29 pm
Cheers james works a treat m8 :D
now work out bloody electric windows!!!
dave
|-Good things come to those who wait-|
alwaysmods2do
Postby Unplugged on Sun Jun 15, 2003 9:50 pm
Is that all thats needed is two motors?
Also where abouts are they located is it behind / near the inside handle cos im going to try and raid one tommorow need to know what to look out for
Unplugged
Postby alwaysmods2do on Wed Jun 25, 2003 1:25 pm
woohoo wiring for electric windows has been discovered!
if ur interested- http://www.fiestaturbo.com/phpBB/viewtopic.php?t=51066
dave
alwaysmods2do
Postby heeman10 on Thu Jun 26, 2003 8:31 pm
Wahey, it's been made sticky :D Glad it's helping ppl out now, and well done Dave for doing your guide too :)
Unplugged: The c/l motors are bought as a unit which consists of the usual latch mechanism (which you can see on the inside end of the door) with the motor attached to it. So it's just a case of remove the original latch, and screwing in the c/l latch/motor mechanism in through the same holes :)
Postby dj_mase69 on Fri Aug 01, 2003 10:52 am
i know its late but where can i get a central locking kit for a 5 door from? im really desperate for this. how much are we talking for one? HELP :-?
dj_mase69
Postby unknown_user on Fri Aug 08, 2003 1:48 pm
Any 1 know how to wire up a keyfob to lock n unluck the doors?
unknown_user
Postby alwaysmods2do on Mon Aug 11, 2003 6:57 pm
depends on ur alarm dont it? With mine i gotta buy a seperate interface for bout 30 squid and its a diy job so cant b too hard m8
dave
alwaysmods2do
Postby unknown_user on Tue Aug 12, 2003 11:44 am
im not using an alarm, i am wiring up a seprate keyfob to open the locks incase of a problem with the alarm(im delocking u see!).
unknown_user
Postby alwaysmods2do on Tue Aug 12, 2003 5:21 pm
ah i c. In that case i aint got a clue m8. :lol:
alwaysmods2do
Postby Unplugged on Wed Aug 13, 2003 1:28 am
You can buy remote central locking kits from maplins for about £50
The system works on a Negative Pulse so basiclly if you short the two signal wires it will lock or unlock effectivly.
Unplugged
Postby unknown_user on Thu Aug 14, 2003 1:24 am
cheers unplugged, been helpfull
unknown_user
Postby badboy si on Fri Oct 03, 2003 7:20 pm
i see that u have pics 4 the elec win but there isnt 1 here 4 te central locking, av u got 1 m8?
badboy si
Postby eXtreme-fiesta on Tue Oct 07, 2003 9:51 am
Dan,
After work one day if we get time i will take my door card off and show you whats needed. Alternatively let me know when you are fitting it and i will help you :wink:
Jamie
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby Ford_whore on Sat Oct 11, 2003 5:34 pm
i cant get my old latchs out the screw are fudgekin tight
Ford_whore
Postby eXtreme-fiesta on Tue Oct 14, 2003 10:12 am
electric screw driver ;)
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby Ford_whore on Tue Oct 14, 2003 11:01 pm
if u got a really nice one but the cheapo one i got anit got much well i will use a whrech on the baxtered are they torx or posi
Ford_whore
Postby heeman10 on Wed Oct 15, 2003 10:27 pm
Torx?! :o It's a huge crosspoint. I'd go for manual over electric any day, got more control over what's going on. If you were closer I'd do it for you :rolleyes: Just persist with it. Make sure the head fits it perfectly, push in nice and hard and twist like you did last summer! :lol:
Re: Guide to fitting central locking in a 3dr Mk3 Fiesta
Postby wywywywy on Wed Oct 15, 2003 11:37 pm
I was trying to install a central locking system but I ran into some concerns... I hope someone can help me please.
heeman10 :The earth wire on each side needs taking to a suitable earth. I found there was already an earth bolt underneath the plastic sill on the driver's side. On the passenger's side I used a self-tapper into an existing hole in the sill under the plastic sill cover.
Where exactly do you mean by "plastic sill"?
I cannot find a good earth!
And, how do you route the wires?
Should I do it under the carpet?
Last thing. You know, most of the wires need to be connected together.
Now my car is a 5dr, so there are even more wires to be connected... (4 yellow, 4 white, 4 live and then 1 live coming out).
I have a sort of "connector block" thing that would connect multiple wires together. But where should I (safely) hide this block? Passenger side footwell a good idea or not?
Thanks.
Postby Ford_whore on Fri Oct 17, 2003 4:02 pm
well i got thewrhechs out and i got it to come out just got to sort the wireing out now
Ford_whore
Postby eXtreme-fiesta on Fri Oct 17, 2003 10:29 pm
The plastic sill is between the bottom of the inside of the door and the carpet. Undo a few of the screws, and you will see another wire which is earthed.
I think the drivers side doesnt have anything earthed under that sill but the whole to earth something too is still there, however on the passenger side under that point of the sill there is a wire earthed there. Check it out ;)
On my 3dr i just ran the wires behind the dash, meeting up with eachother in the centre console, but obv with a five door i would just run the wires down the sill (where the earth point is) and straight up into your rear doors.
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby wywywywy on Tue Oct 21, 2003 7:28 pm
Thank you eXtreme-fiesta.
Anyone know how to feed wires through the loom??
Postby Joris on Mon Nov 03, 2003 2:21 pm
How much are new central locking motors from ford ?
for a 3dr.
as mine didn't work when I bought the car. should check it sometime, only been 3 years :lol:
Joris
Postby heeman10 on Wed Nov 05, 2003 8:20 pm
Joris :How much are new central locking motors from ford ?
for a 3dr.
Call them and ask.
Postby phatboy on Wed Nov 05, 2003 8:40 pm
new motors will be very expsnsive, and pointless, when you can just get some 2ns hand ones
id say its just as likely to be the wiring.... check the ground is connected well
phatboy
Postby Daniel on Fri Dec 12, 2003 1:57 pm
Im doing mine right now, all fine except I cant work out how to get the wires from the door into the car. The rubber sleeve has a plug in the end so i cant shove wires down there.. Any ideas? I dont really want to leave wires just hanging between the door and bodywork incase they get trapped or crushed between the two.
Daniel
Postby phatboy on Fri Dec 12, 2003 7:31 pm
in the rubber bit is speaker cable. I put new cable in, and smashed the 2 plugs out of that thing, and now can fit loads of cable in it!
phatboy
