[FAQ] Turbo shaft Play
5 posts • Page 1 of 1
How much play should there be in the turbo shaft?
[promoted to FAQ section - Proj 03.07.2K4]
- KEVFRST
there should only be minimal play side to side on the shaft and there should not be any play at all inwards and outwards on the shaft, this will mean the oil seal has gone and the turbo needs a recon
- fiesta3rst
up/down side/side movement is ok with the engine off, as the oil pressure removes this once running. There should be no endfloat at all, this indicates wear.
Gareth
Gareth
- Gaz7
- Authorised Trader
