Zetec-S rear beam and Focus rear discs on the Type-R
119 posts • Page 1 of 4 • 1, 2, 3, 4
Beam me up - Type-R gets handling and braking for the 21st century...
- Focus rear stub axel assemblies, discs, pads and calipers £90 total
- 2001 model Mk5 Zetec-S rear beam. £70
- Escort Mk5 RS2000 handbrake cable £20
Total cost for improved handling and rear disc conversion - £180. Bit of a bargain eh!
Why Focus rear discs won't fit a mk3:
Only one of the four bolt holes line up. The pattern on the Focus is identical to the mk5, and the later mk5 beams are a direct fit on the mk3. mk3 drums won't fit a mk5 beam.
Mk3 at the back, Mk5 at the front:
Note stronger gusseting.
Focus disk components:
On the car:
Mk3 setup:
Mk5 setup:
On the car:
Mk3 setup:
Mk5 setup:
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
- chumkila
- Dirty Post Whore!
good good....now get a decent turbocharged lump in there! ...oh and stop hitting the rev limiter when reversing out of your drive!
Thanks - Sunny.
Thanks - Sunny.
Do you have any idea what 178.8mph feels like in a Fiesta? 2000 lb of pressure per square inch per second pushing back on your face. It feels like god himself is trying to rip the skin off your skull while someone lands a 747 on your chest.
- sunnyFRST
- AdrianFRST
Longer flexi hoses, that's it.
Be aware that this setuo is 10mm per side wider than drums. Fortunately the car had 10mm spacer blocks on and the necccessary arch work to clear.
- AdrianFRST
Adrian is this just a matter of unbolting the old stuff and replaceing it with new, you didn't have to modify the rear beam to get it to fit did you?
Was goin to get the Fiesta Centre rear disc kit next month but if I can do this and get the reat beam for less £ I know which I'll be gettin
Dan
Dan
- dannyboy
sphinx ::o Good read!
Will this work the same on a mk 3.5 cos of the rear suspention differences?
Yep.
- AdrianFRST
dannyboy :Adrian is this just a matter of unbolting the old stuff and replaceing it with new, you didn't have to modify the rear beam to get it to fit did you?
Dan
Yes.
No mods to the beam at all.
At the moment we don't have the handbrake cable functional (Ford didn't have it in stock, will be here this week). Shouldn't be too much hassle to fit.
Prices will depend on your breaker.
- AdrianFRST
- AdrianFRST
- AdrianFRST
sphinx :Jus 1 more thing. wot about ARB's? z-s doesnt have 1 does it?
If you put the beams up on their end, and hold the bottom, you can twist the frst beam with arb quite alot,
do the same with the mk5 beam and it won't twist at all, its sooo much stiffer.
As Ade says, it doesn't need an arb.
- MarkFRST
- chumkila
- Dirty Post Whore!
yeah, when i did mine, the half moon thing was hitting the floor of the car, as it was bigger on the new cable. So i put the smaller one off the fiesta cable, and that was the only tweak needed.
- MikeyXR2i
U feckin barsteward !!!!
Ive just spent £290 on my rear disc conversion and still aint got calipers i wanted an uprated rear beam aswell !
Thanks for ruining my month guys !
- FezzyMK3.5
cool
Mine was supposed to have rear focus discs a yr ago, but scrappy said to me £100 for pair of rear hubs / discs / callipers etc... I persuaded parents to pay (safety issue...), then when I went to collect, they changed minds to £100 a side. grrrrrrrrrrrrr
- fiestakingfisher
- PurePower
- Your car: Fiesta 2.0 Kingfisher, BMW Z4
- AdrianFRST
there is no need for a guide mate it's really simple all you have to do is bolt everything on you cant go wrong seriousaly you cant...
but that's besides the point....
DONT copy me you buggers
he he he
he he he
- mmogenius
- 2.0 16v Fiesta RS Turbo
Ade, i've been toying with doing this with these parts to my fiesta but i kept selling on the bits for escort conversions ( ££'s ) Now i have run out of bits for my car!! !!
What you need to do now is to get the St170 caliper carriers and discs, then you'll have 278mm rear discs! you can retain your caliper as all the do is move the holes out on the carrier to make the caliper sit further out , the caliper is actually the same ( also used on the St160 Puma )
- Gadget
- Your car: 05 Mondeo ST Tdci & FRST
mmogenius :there is no need for a guide mate it's really simple all you have to do is bolt everything on you cant go wrong seriousaly you cant...
Hey!! You aint read the thread about the cossie splitter have you! Fukkin thing!
Wont be doing it to this car anyway, next one though!
TJSEARCH
- TJ
I'm using 20mm spacers on the drum..
Does fitting the wider track rear beam move the wheel away from the wheel much, just thinking cause if i would need to keep the large spacer, it could cause major problems with my arches
Plus i assume, all Focus 2L large brake conversions will fit happily on this
- Ian C70T5
- Das Ist Kapput
