GUIDE: Making a DIY Single Wiper.
35 posts • Page 1 of 1
Single wiper conversion.....
Right pay attention class there will be a test at the end.
Tools you will need:
1, Hacksaw,
2, Vice
3, Hammer
4. 13mm spanner
5. Angle grinder (or a file and some excess energy)
6, Drill
7, Small round file
Procedure:
1, Nip down 2 your local scrapyard and get yourself another wiper assembly (Just in case it all goes horribly wrong or don’t get it done all in one day)
2, Remove the link arms from the assembly (use a spanner to pop the plastic cups off the metal balls)
3, Cut the round tube on the drivers side off next to the main section of the linkage.
4, Unbolt the centre arm (with the double ball) from the motor.
5, Taking the drivers side section you cut away. Cut the rotating arm (with the ball) off next to the rod that passes through the fixed section of the linkage. This cut needs to be made as close as possible to make the new centre link as long as possible.
6, Drill a hole in the end of the piece that you just cut. This hole needs to be the same as the one in the end of the original centre link (the double balled one) File it to suit the motor shaft. Grind the end round where you cut it to make it look professional !
7, Put the same section in the vice and bend it to resemble the original centre link.(but longer) You need to make clearance for the linking rod to pass over the centre shaft.
8, Now reassemble the linkage but leave the centre nut very loose.
9, Remove the wiper assembly from your car. And replace with your freshly modified version.
10, Turning your attention to the wiper arm. Either use one from a car with a single wiper as standard (Citroen BX is suitable.) or put one of your existing wipers into the vice and straighten it. (the best you can do is a strange shape still though.
11, Position the wiper arm in line with the linkage arm on the other side of the scuttle panel.
12, Wipe the screen once. (remember that nut is loose so the wiper itself won't move.
13. Position the wiper on the screen manually where you want it. then tighten up the nut on the motor spindle. (should you wish to reposition the wiper later undo this nut and adjust it)
14, Make sure the linkage doesnt catch on its self or anything else. (if it catches on itself bend the flat bit on the passenger side to cure the problem)
Job done. Congratulations.
Right now 4 the test. See how many people turn up at next years shows with single wipers.
If anyone needs any clarifiction i will do me best!
[stickied by Proj]
1, Hacksaw,
2, Vice
3, Hammer
4. 13mm spanner
6, Drill
7, Small round file
Procedure:
[stickied by Proj]
- ZetecSX
- Location: Norwich Drives: Sierra Sapphire 2.0 Ghia. Rebuilding: Fiesta SX 16v
why dnt use just buy the haynes fiesta maxpower manual it shows you how to do that an [ERRR] pics its got 31 easy steps!!!
i got it from halfords in warrington 4 £18.99
so now theres less chance of me f**kin any thin up on my car cause it shows me how to do most things properly.
- mullen
whoahh dude gotta be a sticky thread!
now dont go stickin any more fireworks in s**t bins! or peoples front gardens for that matter!
peace out
shamooooone!
peace out
shamooooone!
- bluefiestamk3
- BANNED MEMBER
mullen :why dnt use just buy the haynes fiesta maxpower manual it shows you how to do that an [ERRR] pics its got 31 easy steps!!!
Got it in front of me, as far as i can see it a DIY guide to fit a single wiper kit... ie buy the kit and this shows ya how to fit... I think...
Good guide mate...
- AndyRS1800
bluefiestamk3 :whoahh dude gotta be a sticky thread!
Thanks but...
bluefiestamk3 :now dont go stickin any more fireworks in s**t bins! or peoples front gardens for that matter!
WTF?????
Percy! :Pics would be nice, will do it myself if it looks easy.
Pics added - go on save yourself £100 quid. AND get the wonderful sense of achivement when you done it!
- ZetecSX
that wiper on that fiesta is nearly touching the rubber screen aint it!?!
what size blade is that?,i used a super small one from halfords which sits 8-10" off the top where the rubber screen is.
"R.I.P Elm_Us 2004"
- PhatFesZs
WIll the arm do a 180 degress swipe to clear the whole windscreen, I am a bit confused as it would only go to 90 on the current motor won't it?
Also can it be set to be at the bottom when not in use as I don't really like them up the centre of the screen.
- Percy!
- Your car: Citreon
no it only sweeps the passenger side of the screen, and you can only park it verticallyPercy! :WIll the arm do a 180 degress swipe to clear the whole windscreen, I am a bit confused as it would only go to 90 on the current motor won't it?
read it, what do u think
- RS_Rawli
the guide looks brilliant, however the process looks very confusing to me
Think il save myself the bother and stick with two wipers!
Jamie
- eXtreme-fiesta
- Fiesta XR1.3i
Righto. Some more answers.
The red fiesta passed the MOT with the wiper parked vertically (was given an advisory for it tho.)
Because the linkage is modifiyed (the bit that bolts to the motor is lengthened the wiper sweeps further. With a standard linkage it would only sweep 1/2 the screen. The red car wiper swept from rubber to rubber.
The wiper can be positioned anywhere on the screen.
The arm on the red car is a standard fiesta arm straightened with a standard wiper blade.
Yes and No the only bits i use are the wiper arm from a BX not the linkage. (i.e. only the bit you can see with the bonnet shut.) And a mk3 fiesta linkage.(the bit hidden underneath)
I have used black red and blue in my pics. i havnt highlighted any thing the different colours represent different parts of the wiper linkage.
Think thats covered all points raised.
Percy! :it wouldn't pass an MOT unless the wiper is down at the bottom when off would it?
Percy! :I am still failing to see how it would do a full 180 movement
RS_Rawli :Percy! :WIll the arm do a 180 degress swipe to clear the whole windscreen, I am a bit confused as it would only go to 90 on the current motor won't it?
percy! :Also can it be set to be at the bottom when not in use as I don't really like them up the centre of the screen.
Tonys_Phatfiesta :.that wiper on that fiesta is nearly touching the rubber screen aint it!?!
wywywywy : So I can use BX wiper arm and save lots of $$$?
TJ : Any chance you can change the highleted section on this to blue, or anyone infact, cos im colour blind and cant really see whats highlighted or not!
Infact, can someone do all the pics please.
Cheers!
- ZetecSX
gonna do this tomorrow but i dont see how u can change the parking position, as if you park it in the centre it will do 180 onto teh bonnet, or if its designed to do 90 each way from centre it will do 90 onto the bonnet when parked on the passenger side?
rawli
rawli
- RS_Rawli
Cheers buddy. Did mine today, took me a few hours tho on and off cos i cheated by not using a vice or a grinder. Looks smart and saved a wedge, great guide. Ive got a problem tho
, ive got it sittin in the centre but would prefer it jus 1/4 way up on passenger side. When i adjusted it like someone said above it hit the bonnet. Not a problem as it looks well smart anyways.
Get writing up some more guides, Carl
- Xr2i lookalike
xr2i_lookalike is carl
i got pulled the otha day n given a 14day cos i only had one wiper????
(a.k.a. single wiper conversion)
bizzies r thick fair do's!!
they wer lookin for anythin n everthin to do me for. all they got was a rear bulb n the wiper which wasnt even a problem!
- badj
badj :xr2i_lookalike is carl
stupid fuckin retards, thats most citreons ever made off the road then!
- phatboy
Just done this, Cheated by using standard middle bit as it started to rain and it doesnt sweep the whole screen.
Dont see how a bit of metal a few mm longer is gonna make much difference
But ill have a go tomorrow!
Max
Max
What did you do to take it out then just so i dont sruggle as much im not technically minded lol.
I really want to do this mod but im not sure whether the end result will be worth it? Do you think its looks nicer than 2 wiper arms?
btw what wiper arm have you used?
James
James
- mr_fez
Made one 4 my mate used a 306 later one(s reg) rear wiper arm looked like a proper kit as thick plastic arm
- thomasfrst
thomasfrst :Made one 4 my mate used a 306 later one(s reg) rear wiper arm looked like a proper kit as thick plastic arm
Any pics? Those arms dont look that long.
no pics any as car got nicked and burnt out. had to change the blade as was slighty 2 short but not 2 bad
- thomasfrst
great guide just saved me a bomb but still cost me 20 quid for a new linkage. which i didnt need
1.6 si coming soon
5 Door Register
Only motorcycle riders understand why dogs stick their heads out of car windows
5 Door Register
- Gazeddy
