Guide: Replacing Reverse Light Switch
Postby Maff Si on Sun Feb 29, 2004 2:14 am
I finally got round to fitting my new switch today, heres a guide to removal and fitting, Enjoy :)
This is what you need, think they are around £7ish but dont really know cos i used the one from my old B5 Gearbox
The reverse light switch is situated at the front of your gearbox (If you don't believe me take a quick peek at your bell housing) :lol:
If you follow this there is no need to touch the undertray :D
It may be worth cleaning the electrical plug connections first incase its just dirty !
once you have established the switch is faulty by bridging the connector
loosen the switch with 22mm spanner then snap off the plastic connector :oooh:
this will enable you to use a socket and some sort of T piece to undo the switch :Q
Here is what i used for the job...
You will have to screw the new switch in as far as you can with your fingers :rolleyes: then use the spanner to give it a final tighten :D
See also http://www.fiestaturbo.com/phpBB/viewtopic.php?p=740488&highlight=#740488
No Filler Nova Killer - Goes Like A Bomb
When I'm not here I'm somewhere else
Maff Si
Your car: Nothing til end of the month
Postby Excursion on Sun Feb 29, 2004 1:13 pm
The switch in your third pic down is actually an escort one, I don't think they work in a fiesta.
You can only use black ones I think.
Postby Maff Si on Sun Feb 29, 2004 11:22 pm
Excursion :The switch in your third pic down is actually an escort one, I don't think they work in a fiesta.
Yeah Mark thats why i was replacing it as the gearbox was from an escort
Maff Si
Postby ~Tony~ on Sun Feb 29, 2004 11:35 pm
hey thats great mine has just gone great guide mate
Postby Rhinopower on Fri Mar 05, 2004 11:10 am
went to do it this morning, i cant find the switch, can any1 illustrate a bet better where it is, haynes manual is a loads of s**t aswel
Postby M4RK Si on Sat Jun 05, 2004 11:19 am
guide forum ;)
M4RK Si
Postby Project on Sun Jun 06, 2004 12:06 am
Yep - useful information in there which is a helluva lot more helpful than haynes.
