Guide: bleeding brakes
10 posts • Page 1 of 1
... is now here:
http://www.djstalker.com/content/view/89/45/
/al
/al
should add that u should never use the brake pedal to push brake fluid thru the system, the seals are not designed for this purpose, and with general wear and tear, u can invert the seals, or the seals will just blow out leaving u a bill for a new master cylinder..
- snake
- Trainee Burger Flipper
- Your car: ford
snake :should add that u should never use the brake pedal to push brake fluid thru the system, the seals are not designed for this purpose, and with general wear and tear, u can invert the seals, or the seals will just blow out leaving u a bill for a new master cylinder..
Hi, what do you mean by "push brake fluid thru the system"?
- wywywywy
Re: Guide: bleeding brakes
could someone reupload the guide pls ?
- dijsil
Just buy an eezi bleed kit. I've messed about with manual bleed kits in the past but eezi bleeds are so much easier. Just attach one end to the spare wheel and the other end on top of the fluid resevoir. it'll force the fluid through automatically when you open the bleed nipple
http://www.gunson.co.uk/item.aspx?cat=674&item=1818
Cheaper on eBay i will add
- sikora
- Your car: XR2i, Clio Trophy
the top link doesn't work can someone add a current link please
- pauldolman
i used a pressure bleeder, worked brilliant well, solid brakes after.
- Mav Singh
- Your car: 1995 Fiesta Si 1.6
