inlet manifold!! frst
6 posts • Page 1 of 1
can a 90 spec xr3i inlet manifold be used on a frst???
any info on inlet manifolds for a fezzer turbo would help!!!
- riles@
Yep, but you need to use the FRST IAT sensor (top gearbox-side of inlet manifold), and replace all the gaskets with new ones, torqueing them up to FRST settings.
/Munk
/Munk
Use the FRST MAP sensor you have on the bulkhead.
The IAT sensor needs to be fitted with the adaptor, which is a standard thread size and available from plumber's merchants if needed.
/Munk
/Munk
