Guide Fitting An Intermittent Wiper
Postby AW3K on Thu Jul 22, 2004 10:38 pm
Guide for fitting a intermittent wiper
Go to a scrap yard,
Find a fiesta with an intermittent option on the stalk (push down)
Remove the steering column shroud upper and lower, lower has torx screws and upper has 2 pozzi on the top and a further 2 under the shroud.
If the car has a manual choke, depress the button on the side with a screwdriver and remove the handle, then twist the locking nut off and remove.
With the above removed unplug the multi-plugs from the switch then remove the wiper/indicator stalks by un doing the single screw on the top. Pull the switch assembly upwards and set aside. You need this!
Look at the plug on the right hand side, the one that is for the wiper, in the top there is a red bung type thing, prise that out with a small flat screw driver.
Now the contacts are exposed, locate the ones for the Brown with yellow strip and the black with green strip.
DON’T just pull them out or the connectors will be damaged
Gently push a small screwdriver down each side of the contact while gently twisting to release the barbs. When release pull them out.
Cut open the loom all the way back down to the fuse box removing just these 2 wires.
These 2 wire will go into the fuse box and connect to a red large relay, relay II, remove it and keep it.
Take note of the pin/connector positions on the plug.
Using the same principles as mentioned above for removing the connectors, remove all the connections from the relay socket.
Also remove the small plastic thing that the relay sits in, it looks like a T shape.
This is done by prising the 2 clips down and pulling the T upwards.
You will also notice that there are another 2 wires going to one connector, remove these as described above and chase the wires as far as possible up the loom, then cut them both.
That’s all the removal bit done.
Now to fit to your car.
DISCONNECT THE BATTERY PLEASE AS YOU ARE PLAYING WITH ELECTRICS!!
Remove the shroud and switch as mentioned above. Open the connector, like above and push the wires into the connector in the same position as they came out of the donor car.
Find the brown wire with the white strip and cut it as far away from the connector as possible, Now do you remember that connector from the relay that has the two brown with white wires in it, solder one of these wires to one end of the cut wire and the other wire to the other cut end. Insulate the joins with your preferred method.
Tape all wires together and tie wrap them to the rest of the loom all the way to the fuse box.
Open the fuse box and push the cables through until they get to the relay position.
Push the wires through the holes and into the plastic T shape, now do you see why you needed it. Using the diagram you drew when you removed them from the donor car.
With all the connectors in place gently push the T down into the relay board until it clicks.
Put the relay in the correct way around and be sure to put its support tag in as well. This stops the relay from coming out due to its size.
P
Put the wiper stalks back on and screw them down and ensure the red bung is in the connector, then connect the plugs to the back of the stalks.
Re connect the battery and test the wiper by pushing the stalk down, it should come on then wait 5 or so seconds and start again, test all the other functions of the stalks to ensure they work,
Put all the steering column shroud back on and screw the fuse box back to the dash and now the job is finished.
Hope this guide is of some help to people.
Postby Max M4X WW on Thu Jul 22, 2004 11:24 pm
Christ did some really not come with this?
Postby AW3K on Thu Jul 22, 2004 11:26 pm
Max M4X WW :Christ did some really not come with this?
yup my 1.1 freedom and my brothers 1.1 pop plus and many others appernatly
Postby Max M4X WW on Thu Jul 22, 2004 11:29 pm
:oooh: And i thought mine was badly specced.
I suppose some fiestas didnt have gloveboxes, parcel shelves, centre consoles or passenger side door mirrors!! :lol:
Postby AW3K on Thu Jul 22, 2004 11:44 pm
Max M4X WW ::oooh: And i thought mine was badly specced.
he he mine dint have a glove box, centre consol, clock, electric windows, central locking, boot release or int wiper
it now has all.
Postby Max M4X WW on Fri Jul 23, 2004 12:04 am
Mine had central locking, airbag, console, g-box, shelve, both mirrors, pas.
Now has 3.5 mirrors, boot popper and central locking that wont work.
Postby AW3K on Fri Jul 23, 2004 12:09 am
heres mine added 3.5 mirrors
not bad for £450
Postby wywywywy on Fri Jul 23, 2004 9:16 am
Do they have 6-speed intermittent wipers like my Escort or Mondeo?
Fiesta Mk3 The Complete FAQ
Have a look, and do a search, before you ask anything :)
Project Log
Postby Max M4X WW on Fri Jul 23, 2004 9:23 am
wywywywy :Do they have 6-speed intermittent wipers like my Escort or Mondeo?
No!
Postby ~Tony~ on Sat Jul 31, 2004 5:46 am
really useful will be doing this on mine, and yes my XR2i doesn't have this.......................why because the previous owner removed it as they kept finding themselves turning it on. will do this asap cos its begining to piss me off, even my 1.1 had it!
Re: Guide Fitting An Intermittent Wiper
Postby mel76 on Thu Jun 03, 2010 9:16 am
What do you do if you only have the wiper stalk and not the wires that come with it from the donor car ? Is there anywhere you can buy the required relay 2 and or wires that you need? Or find out which wire goes where if you haven't removed the stalk yourself from the donor car?
mel76
