[info/rough guide] fitting ZS beam & Focus rear disks : Guides / FAQs | Fiesta Forums
Postby PUREtom on Sun Mar 06, 2005 5:22 pm
Right, this is to let you all know the problems I encountered fitting the ZS rear beam, focus brake set up and how i solved these problems.
ZS rear beam :- No real problems involved with fitting this. Just a direct replacement for the original. 4 screws each side, wheel off, handbrake cable off all clips.
The only problem I found with this was if you have RS2000 side skirts like me! I had to break the last rivet so that i could lower the beam down. As the skirts fit directly below the attachment of the beam to the body. Not a problem, just re-rivet it after.
Focus rear brake set up :- This is where the problems start. But they do fit perfectly to the beam!
Brake hose:- the existing brake hose of the Si is too short to reach the focus calipers. You can see this in this picture. Note the black hose is the new one, explained later:
okay this end
This is too short now:
So...i had to pop down to the local motor shop, they directed us to a helpful chap who has loads in Basildon. The fiesta Si hoses are 13 inchs, we need about 16 inches. So went to have a look in Basildon, and they had some 17 inch, Mk 3 escort 1980-83 front brake hoses that fit pretty much perfectly, as you can see from the pics above and below (black hose)
Please note that we moved the brake hose the other side of the strut after we tried the wheel!!
Hand brake cable :- after looking on FT.com for a while, XR3i handbrake cable was the cable that everyone said should work and that fit. But this wasn't the case.
We had to take the yoke off the fiesta handbrake and use that, as the yoke would not fit under the floor pan.
The outer cable is too short, but shortcuts can be taken, this is ok.
The inside cable was too long, and this was a problem. As you can see from the pic below, the cable is too long!
SO my dad had to make up some sought of spacers on the lathe.
This is what he came up with:
Now this fits here:
This is what it was like before:
After all these problems, the handbrake cable was cable tied into position (with shortcuts taken). The cable needed to be adjusted so that it was an MOT pass.
Now the brakes were bled, and the wheels were put back on. Notice the wheels stick out with the zetec s rear beam.
Here are pics of the final result:
Tom
PUREtom
Postby PUREtom on Sun Mar 06, 2005 5:23 pm
Moderators- if you feel this is worthy of being a guide, then please re-title and put in guide section.
Thank you
Tom
PUREtom
Postby Faith on Sun Mar 06, 2005 5:29 pm
Looking Good Fella, Notice the difference wen ur driving?? i used to have a zetec s so i kinda know how it should feel altho it is a diff car.
All that extra stopping power you now got!! bet it makes u feel safer! Can really put ur foot down now...lol :D
You seem like you know your stuff, think i mite be coming up to urs wen i get round to putting a zetec s beam on mine! :D $$$$$$$!!!
Adi :D
Faith
Postby PUREtom on Sun Mar 06, 2005 5:32 pm
beam is piece of piss, its the focus setup thats a chore!
I only went down the road. But as soon as I got off the drive and the rear went off the kerb, i could feel the stiffness! but braking, is a little better, just need to get the fronts then ready for 'the lump'!
PUREtom
Postby EvilFranky on Sun Mar 06, 2005 5:41 pm
Excellent guide mate.
Should defo be made a sticky :D
EvilFranky
Postby SPo0n on Sun Mar 06, 2005 6:18 pm
has the handling improved with the new rear beam? :)
SPo0n
Postby MAD_Adamski on Sun Mar 06, 2005 6:32 pm
looks good tom well done i painted my beam and calipers but still a good job unpainted, i think you'll find the wheels stick out around 20mm+ each side and many people will have to be careful how much they have lowered their cars as this conversion makes arch rubbing a big prob......
i personally used a mk5 handbrake lever, and a ford puma racing cables and these fit spot on with no spacer so worth people thinking bout...
but nice guide should help many others :wink: :D
MAD_Adamski
Postby Cellze on Sun Mar 06, 2005 7:33 pm
If this does become a Guide it looks like your dad will making a lot more of those spacers :lol:
What setup are you having up the front?
Great guide.
Cellze
Postby Jays_si on Sun Mar 06, 2005 8:06 pm
arent your wheels sticking out past the arches there mate?
Jays_si
Postby MAD_Adamski on Sun Mar 06, 2005 8:09 pm
his wheels are yes :D which is good for handleing there is a big BUT,
some MOT places can but v funny bout wheels sticking out past the arch just gotta have a mate in the right place :wink:
MAD_Adamski
Postby pollocks on Sun Mar 06, 2005 8:20 pm
could get wheels with a higher et say if he had 35 to start with get 55 to sort of offset the new gained width :D something i would think about tbh as u can always get your wheels with one offset front n diff rear D:
pollocks
Postby andyhardy on Sun Mar 06, 2005 8:21 pm
Could the RS2000 rear disc setup be used on a Zetec-S rear beam?
Postby fiesta_fras on Sun Mar 06, 2005 9:50 pm
if ur only in basildon u should come see us in Grays,
it is a fiesta house, three of us live here and own:-
1. Turbo Diesel Fiesta
2. Soon to be zetec turboed fiesta (mine)
3. 1.6s being scrapped soon because bits going into...
4. brand new engined FRST build
5. XR2i 1800 16v runabout
6. One soon to be started Rs1800i
and Andys girlfriend has a mk4 one, thats makes 7
thats gotta be a record for fiestas registered at one house, technically number 7 is not registered. but she stays over loads :D
RIP Robert Martin - Rob - Elm_us
fiesta_fras
Elite Poser
Elite Poser
Postby rich_frst on Sun Mar 06, 2005 10:56 pm
wicked guide tom!!! you finally got a beam then!! where did you get it in the end!?? did you try nevedon?! :D
nice to know the puma handbrake cable works well with it-cheers ad!!!!! :wink: :wink: i had a xr3i cable lined up for mine, nevermind :D
rich_frst
Your car: mk1 sierra cos, mk2 escort est
Postby rich_frst on Sun Mar 06, 2005 10:57 pm
adamski frst :i personally used a mk5 handbrake lever, and a ford puma racing cables and these fit spot on with no spacer so worth people thinking bout...
how did the fitting of the hand brake lever go mate!??!?! any trouble?!?!? i might try a focus one!!!! :D :D :Q
rich_frst
Postby PUREtom on Sun Mar 06, 2005 11:10 pm
SPo0n :has the handling improved with the new rear beam? :)
Defo mate, works a treat, sticks to roundabouts!
PUREtom
Postby PUREtom on Sun Mar 06, 2005 11:11 pm
Jays_si :arent your wheels sticking out past the arches there mate?
One side is a bit more than the other. Maybe cuz all the bits are from breakers and bin in crashes!
PUREtom
Postby PUREtom on Sun Mar 06, 2005 11:13 pm
mine is lowered on 35mm Gmax (mk3) on mk3.5 struts. This makes it sit a bit higher. I don't get any rubbing with it, but if it was lowered more then it would def rub more.
rich_frst :wicked guide tom!!! you finally got a beam then!! where did you get it in the end!?? did you try nevedon?! :D
I got it from that place in rainham called FLP or something. Nevendon only had a puma one when i rang them
PUREtom
Postby andyhardy on Sun Mar 06, 2005 11:36 pm
Anyone know if the RS2000 rear disc setup will work with the Zetec-S/Puma rear beam setup?
Postby rich_frst on Mon Mar 07, 2005 9:41 pm
andyhardy :Anyone know if the RS2000 rear disc setup will work with the Zetec-S/Puma rear beam setup?
no mate it wont the stub axel pattern is different... :D
rich_frst
Postby Jays_si on Tue Mar 08, 2005 11:33 pm
PUREtom :
:o say no more :D
Jays_si
Postby DeanoW on Wed Mar 09, 2005 2:03 pm
which brake master cylinder will you be using once the fronts are done?
DeanoW
Postby PUREtom on Wed Mar 09, 2005 6:06 pm
Jays_si :
PUREtom :
:o say no more :D
Nope, its all ok really, just an optical illusion!
PUREtom
Postby PUREtom on Wed Mar 09, 2005 6:07 pm
DeanoW :which brake master cylinder will you be using once the fronts are done?
WHen i get cosworth fronts. Don't think i will need a dif one.
PUREtom
Postby PaulC on Wed Mar 09, 2005 6:11 pm
PUREtom :
If one side is more out than the other, the beam might not be lined it squarley - it is possible for it to be slightly too far forward/backwards or too one side.
Good guide tho :D
Postby AdamB on Thu Mar 10, 2005 1:18 pm
the passenger side will generally be a bit wider... this is done because of the fuel filler pipe,
mine is exactly the same
AdamB
Postby MAD_Adamski on Thu Mar 10, 2005 5:25 pm
AdamB :the passenger side will generally be a bit wider... this is done because of the fuel filler pipe,
as was said my beam also sticks out more on the 1 side this also may be to do with the camber of the roads :wink:
MAD_Adamski
Postby MFkev on Thu Mar 10, 2005 5:42 pm
Excellent guide, on my to do list.
fiesta_fras :if [ERRR] only in basildon u should come see us in Grays,
Cool someone else from the dive that is Grays!!
Mr. T once captured Bigfoot, but released him after he shaved the beast and realized that it was just Chuck Norris walking around naked in the woods.
MFkev
Postby PaulC on Fri Mar 11, 2005 9:47 am
adamski frst :
The wheels/beam on the red Type-R doesnt stick out of one side :wink:
Surely it would bugger the tracking up if the back wheel sticks out further than the fron passenger one
Postby mmogenius on Sat Mar 12, 2005 12:31 am
When me and adrian first fitted the rear beam we spent some time aligning the rear beam correctly as the position that you put it in streight away is not always it's final resting position.
With some gentle aligning this can be solved and as paulc mentioned how could you ever expect a car to be tracked and even drive correctly if the rear beam is offset to one side?
mmogenius
2.0 16v Fiesta RS Turbo
Postby PUREtom on Sat Mar 12, 2005 2:12 pm
mmogenius :Hi,
But it doesn't seem to effect the tracking. Mite loosen the bolts though on the chasis and see if i'll be able to pull it over a little.
PUREtom
Postby wyll_2k on Thu Mar 17, 2005 3:27 pm
If its OK when the time comes Tom, can I ask for yr help with a rear conversion? I'll soon be getting me fronts done having atlast found a nice set of cossie calipers
wyll_2k
Postby Adam_W on Tue Apr 19, 2005 10:05 am
with the rear beam conversion, does it have to be a ZS rear beam or can it be any mk4/5 one? and also can anyone clarify how much it widens the track by please?
adam
Just you wait! Its gonna be a beast!
Adam_W
Postby PUREtom on Tue Apr 19, 2005 2:52 pm
The track is only really made wider by the Focus calipers by about 20mm, the beam is only about 10mm more i think.
The beam can be any mk 4 or mk 5 but best to use ZS as they are stronger and hold the road better.
PUREtom
Postby beanyfrst on Wed Apr 20, 2005 9:12 pm
When i change my beam over to a Z's one can i use cossie 4x4 rear calipers and on what discs :D
Has bought my Fiesta RS Turbo back, Needs a lot of TLC
beanyfrst
