1.1 azura has arrived : Member's Gallery | Fiesta Forums
Postby b0yracer on Sat Oct 16, 2010 7:52 pm
today my 1.1 mk3.5 fiesta arrived
its staying as a 1.1 but getting the xr2i arches etc and hopefully a nice recaro interia
here it is (pics a bit crap as off my phone)
i fitted my switch (not wired in yet) and my cd player
i fitted the rev counter and thanks to you guys on this site got it working
bought this but it wont fit (the steering lock part is smaller)
so this ones staying for now its better than i remember it when i went to see the car
still more to come got full xr2i body kit ready to fit but needs painting first
fit boot spoiler soon
b0yracer
Your car: ford
Re: 1.1 azura has arrived moddifying begins
Postby rs220bhp on Sat Oct 16, 2010 8:28 pm
That steering wheel should fit mate, i fitted one to a mk3.5. I had to use the mk3 cowling though or ive seen the 3.5 cowling trimmed down to allow it to be fitted.
Looks like a good base to start with though
rs220bhp
Postby b0yracer on Sat Oct 16, 2010 9:00 pm
yeah the cowling was one problem but i could have trimed it.
but the teeth on the back for the steering lock (well the diameter of that part is totally different, much smaller diameter on the 3 spoke)
not to worry anyway as the standard wheel is nice
ive put the 3 spoke back on ebay :D
b0yracer
Your car: ford
Postby b0yracer on Sun Oct 17, 2010 6:40 pm
just fitted my boot spoiler but too dark to take a pic now
had no gromits for the outer screws so put a bit of filler in and painted satin black
also on this 1.1 model ive been told the plugs are likely to snap off in the head, i got the car off my dad hes had it 4 years and had the plugs done when he got it, hes not done many miles at all, the plugs look very rusty where the thread is and ive sprayed wd40 and blown/scraped the flakeing rust away and now soaked engine oil around them.
but darn t try to remove them
i might do all the other service stuff and think about the plugs for a while??
b0yracer
Your car: ford
Postby russ-RST on Mon Oct 18, 2010 9:29 am
if ur going to take the plugs out matey nip them UP a little tiny bit first trust me i know it sounds stupid but i done 3 helicoils on my old 1.3 untill my uncle told me this trick :lol: , do it up so it only just moves then undo it smoothly and you should be fine :)
russ-RST
Your car: fiesta rs turbo
Postby Ratspeed on Mon Oct 18, 2010 6:56 pm
Or if the plugs do snap, dig all the porcelain stuff out so just the threads are left in the head, then smack a big spline or torx bit down and wind the threads out. Works every time for me :)
Ratspeed
Postby Max M4X WW on Mon Oct 18, 2010 9:13 pm
xr2ilookalike :but the teeth on the back for the steering lock (well the diameter of that part is totally different, much smaller diameter on the 3 spoke)
I'm going to try and fit the Mk3 column and see what happens!
Postby b0yracer on Tue Oct 19, 2010 6:04 pm
boot spoiler fitted (its staying black)
also today i primered the rear bumper, just need to get some paint mixed up (oh and hammerrite the rear valance) then that can go on
and fitted 2 x handheld fire extinguishers in the foot wells (thats all thats looking any different inside im not doing this car like a race car((like my cortina was)) its just i had these so thought id fit them at arms reach if needed)
b0yracer
Your car: ford
Postby b0yracer on Wed Oct 20, 2010 6:39 pm
todays the first time in years ive been to a scrapyard to buy a few little bits for my car
i only got silly little bits
got a cig lighter (so we can charge our phones in the car)
boot light
parcel shelf rubbers (to hang the shelf as boot opens)
boot contacts (as boot closes, to allow rear screen heater window wiper etc to work)
sun visors and clips
ford badge
£10
all heated window and boot light work now and cig lighter wired in :D
b0yracer
Your car: ford
Postby jonyb4 on Wed Oct 20, 2010 9:48 pm
i fitted a Rs three spoke wheel to my mk4, same case, if your prepared to lose your airbag rock on, you will need a mk3 (not 3.5) non airbag cowlings and steering lock, its a bit stiff, but will knock off with some strength
Postby dazza fairless on Wed Oct 20, 2010 11:36 pm
hi ,chap how much work was it to get the rev courter working ? , ave just got the same model ,and am going to reshell my rs 1800 into it .but ad like to put the clocks in now until next summer ,when al reshell the lot cheers dazza
dazza fairless
Postby b0yracer on Thu Oct 21, 2010 6:56 pm
the plug on the back of the clocks plugged straight in and everything worked APART from REV counter
i added 1 x wire from the edis unit (green wire ((2nd wire in) straight to the back of the rev counter (number 10 on the plug) and it works :D
b0yracer
Your car: ford
Postby b0yracer on Thu Oct 21, 2010 7:08 pm
today i added my rear bumper (still in primer) had to do some welding behind bumper first then painted valance in ronseal black
b0yracer
Your car: ford
Postby knuckles on Thu Oct 21, 2010 8:37 pm
xr2ilookalike :Image
this is what i did to my 1.1 ! :o
if only someone could find the pics of my embrassing fiesta :lol:
knuckles
Your car: Fiesta Rs turbo
Postby jayrs on Thu Oct 21, 2010 8:39 pm
knuckles :
this is [ERRR] i did to my 1.1 ! :o
i canrt be arsed to upload the normal pic so ive taken it from the pikey thread :bonkers:
Postby b0yracer on Fri Oct 22, 2010 7:17 pm
bought a (new to me) back box today £3 bargain
i welded my 2 inch out rolled trim to it
would prefer the 3 inch one but the 2 inch fitted better/easier
my back box was f----d had holes in it so good job done
will start fitting the body kit if weathers good over weekend :D
b0yracer
Your car: ford
Postby b0yracer on Sat Oct 23, 2010 5:33 pm
tail pipe.
fitted rear arch today can only do one at a time only got three x clamps :D
b0yracer
Your car: ford
Postby MK2 Jamie on Sat Oct 23, 2010 7:07 pm
Would it not have been better to paint the arches before you out them on?
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby fezza89 on Sat Oct 23, 2010 7:20 pm
means alot of masking off to paint these now
fezza89
Postby speedyxr2i on Sat Oct 23, 2010 7:55 pm
looking good keep it up.
xr2i 16v :)
speedyxr2i
Postby jayrs on Sat Oct 23, 2010 7:56 pm
leave them yellow, be different :bonkers:
Postby b0yracer on Sat Oct 23, 2010 8:22 pm
im just gonna mask it off and paint once fitted
i was thinking id probally mark them with the tape or clamps so chose to do it this way
b0yracer
Your car: ford
Postby knuckles on Sat Oct 23, 2010 10:53 pm
found my pics ! :D :lol: :lol: :lol:
knuckles
Postby fezza89 on Sat Oct 23, 2010 10:55 pm
knuckles :Image
was you not sure on a colour ? lol
fezza89
Postby jayrs on Sat Oct 23, 2010 11:22 pm
clark, you ch@v! :lol: :bonkers:
Postby knuckles on Sat Oct 23, 2010 11:26 pm
fezza89 :was you not sure on a colour ? lol
to be fair i was young and stupid and just really really wanted a xr2i bodykit. :lol:
knuckles
Postby b0yracer on Sun Oct 24, 2010 9:14 pm
maybe im old and stupid :D 38 and still messing with cars like a boy racer :D
rear arch stuck ok fitted front today hope it sticks because it rained after i clamped it on :o
b0yracer
Your car: ford
Postby fezza89 on Sun Oct 24, 2010 9:16 pm
should all go on ok matey
fezza89
Postby jayrs on Sun Oct 24, 2010 9:21 pm
yeah should be fine mate, the matting surfaces were clean and dry before i take it, so rain would hit the sealent and run down the ouside of it
Postby b0yracer on Sun Oct 24, 2010 10:25 pm
cool hope youre right :D
b0yracer
Your car: ford
Postby jonyb4 on Mon Oct 25, 2010 12:32 am
oh my clark, what was THAT! :lol:
i would have paintedf them whilst they were off mate, just maikes your job of painting them alot harder and its going to be challenging getting a good finish
Postby b0yracer on Mon Oct 25, 2010 8:13 pm
jonyb4 :oh my clark, what was THAT! :lol:
i know youre probably right but ill sort it,
what does this mean
b0yracer
Your car: ford
Postby b0yracer on Mon Oct 25, 2010 8:19 pm
just quickly posting this on here maybe shouldnt really but want a quick reply
my gear change going down gears seems to be hard to engage 2nd gear (you can really feel it going in, especially at higher revs)
what about if i try ajusting the gear linkage and checking oil level
and are the gear linkages easy to check, do they wear out, anything i need to look out for?
cheers dave
ps instead of taking this post up pm me if you have any advice tips :D
b0yracer
Your car: ford
Postby b0yracer on Wed Oct 27, 2010 2:41 pm
this is s??t i wish i kept my cortina now, 1.1 fiesta is so slow it couldnt pull back the foreskin on a garden gnome,
il finish doing it as a xr2 look aq like as ive the all the kit and bumpers but just give it to my wife
i need to get a fast car this is depressing
b0yracer
Your car: ford
Postby jayrs on Wed Oct 27, 2010 7:58 pm
:lol: :lol: :lol: , come on mate, you didnt expect anything special with a 1.1 did ya
