1.1 azura has arrived : Member's Gallery - Page 6 | Fiesta Forums
Re: 1.1 azura has arrived moddifying begins
Postby jonyb4 on Wed Dec 29, 2010 3:07 pm
:lol: you know your way around a panel then :)
Postby b0yracer on Thu Dec 30, 2010 5:05 pm
fitted door strips today, and my car now has a straight through exhaust with just a janspeed back box, sounds nice (the back box was already on, the one with the 3" outward rolled tailpipe) :D
b0yracer
Your car: ford
Postby jonyb4 on Thu Dec 30, 2010 8:01 pm
nice mate, get a video of how she sounds :)
any pops on the over rev?
Postby b0yracer on Thu Dec 30, 2010 10:57 pm
down loading videos is something im not too good at, yeah it pops it sounds good and revs even cleaner than before :D
b0yracer
Your car: ford
Postby b0yracer on Sat Jan 01, 2011 11:38 pm
its a right little screamer now, not sure if its too loud though its good in town or flat roads but hilly roads ie going up hills it hums like f**k as im giving it constant full throttle.
well see how it goes maybe have to change it slightly
b0yracer
Your car: ford
Postby jonyb4 on Sat Jan 01, 2011 11:41 pm
xr2ilookalike :its a right little screamer now, not sure if its too loud though its good in town or flat roads but hilly roads ie going up hills it hums like f**k as im giving it constant full throttle.
likely due to it having f**k all power :P
Postby b0yracer on Sat Jan 01, 2011 11:42 pm
jonyb4 :
what do you mean its got loads of power :D
b0yracer
Your car: ford
Postby jonyb4 on Sat Jan 01, 2011 11:56 pm
:bonkers:
Postby b0yracer on Sun Jan 02, 2011 10:44 pm
right guys i need a list of every thing i will need to change from 1.1 hcs to 1.6 cvh
im changing the box too as i dont think mine will be any good for a 1.6, so will i need different drive shafts, and as mines a mk3.5 will (if i need different drive shafts) the different drive shafts fit my hubs, i know EUFEZ has had problems getting coil overs to fit as he said mk3.5 hubs are different. and i need to know what fuel pump i need, dont even know where my fuel pump is.
thanks guys :D
b0yracer
Your car: ford
Postby b0yracer on Sun Jan 02, 2011 10:54 pm
fitted front bumper strip, im gonna redo the side stripes when i get a light blue to match this one, i was gonna do the whole lot with the darker blue but think its pointless putting a stick on stripe over the bumper ones, im back to painting the body kit myself now when weather is better, ive got over throwing the teddy out about painting i like doing my car myself so i can say yeah i did it :D
b0yracer
Your car: ford
Postby EUFez on Sun Jan 02, 2011 10:56 pm
Pftttt tell me about it. Oh well, all worked out in the end. Good things come's to those who wait... 7weeks. :D
EUFez
Postby rs220bhp on Sun Jan 02, 2011 11:34 pm
xr2ilookalike :right guys i need a list of every thing i will need to change from 1.1 hcs to 1.6 cvh
thanks guys :D
Your shafts will fit the box so you can keep all you suspension etc, Upgrade the brakes though
rs220bhp
Postby b0yracer on Sun Jan 02, 2011 11:48 pm
rs220bhp :
thanks guys :D
what so if i get a box to suit the 1.6 cvh my shafts will fit that box?if yes thats good
what brakes do i use do i have to upgrade rears as well or just fronts and with fronts will i have problems again due to it being a mk 3.5 ?
cheers :D
b0yracer
Your car: ford
Postby rs220bhp on Mon Jan 03, 2011 12:26 am
Yeah you shafts will fit ant BC box from a 1.6
Get some calipers etc from an xr2i/rs or a fiesta si and they will bolt onto your current hubs. There 240mm brakes and will be fine for a 1600
rs220bhp
Postby jonyb4 on Mon Jan 03, 2011 12:41 am
personally id use RS2000 escort brakes, theyre 260mm ventilatedc will stop your car fine, the rear brakes will be fine. i have a 1.8 and my RS2000 brakes are perfectly fine :)
your current grearbox will fit the CVH too :) will make a slightly quicker accerating car, but wont feel as good, or be as strong
Postby b0yracer on Mon Jan 03, 2011 12:44 am
jonyb4 :personally id use RS2000 escort brakes, theyre 260mm ventilatedc will stop your car fine, the rear brakes will be fine. i have a 1.8 and my RS2000 brakes are perfectly fine :)
my box would be s**t with a 1.6 cvh its ok but going down into 2nd i have to be below 20 mph or i can feel it grating as it goes in
b0yracer
Your car: ford
Postby b0yracer on Mon Jan 03, 2011 12:45 am
rs220bhp :Yeas you shftw will fit ant BC box from a 1.6
Yeas you shftw will fit ant BC box from a 1.6 whats this mean lol :D
b0yracer
Your car: ford
Postby rs220bhp on Mon Jan 03, 2011 12:51 am
Sorry mate miss typed it
I ment yeah your shafts will fit. BC box is the type of gearbox fitted to the mk3 and 3.5 fiesta's in 1.6 and other engines
rs220bhp
Postby jonyb4 on Mon Jan 03, 2011 12:56 am
thinkt he splines are the same across most of te ford range, its the length of the shafts that varies on the track of the wheels
Postby b0yracer on Mon Jan 03, 2011 12:56 am
ok cheers
will box still be ok if came out of say a escort or orion with cvh engine?
b0yracer
Your car: ford
Postby jonyb4 on Mon Jan 03, 2011 1:02 am
thanks guys :D
oh just noticed this,
umm fuel pump should just about be ok, but if the car isnt achieving full power id blame this first ;)
shafts will fit the XR2i, Si or RST gearbox, all 1.6 engines
your 1.1 box will fit the cvh, zetec enging boxes will also aswell as obviously the cvh ones
you will need the cvh exhaust system as your 1.1 one wont fit and will restrict it too much as the bore is small
you will need the engine loom, it might still be plugged into the engine that you buy, but check as it may not, this can simply plug into your car at the two grey multiplugs on the bulk head
get everything the engine needs, eg alternator, inlet and exhaust manifolds, all the pipe work for coolant and vaccume hoses etc
cant think of anything else atm
Postby b0yracer on Mon Jan 03, 2011 3:47 pm
dont i need coil and dizzy mines on coil pack
where do i wire coil up to and what dont i need from my loom??
cheers dave
b0yracer
Your car: ford
Postby russ-RST on Mon Jan 03, 2011 4:22 pm
as this is a mk3.5 it will have the one single plug loom from interior to exterior not that hard to change over once you get the looms if you have trouble drop SMO a pm i'm sure he wont mind helping you as he changed mine over for me :D stick with the shafts you'v got buddy you wont need to change your hubs and everything this way and they will fit the box you have with the cvh engine..(im still using the 1.3 shafts on my RST and have had no problems) plus when i compared the RST shafts with the 1.3 shafts they were the same thickness anyway :-? so i wouldnt worry about them causing you a trouble,
as with the fuel pump you have the same problem as me as the fact yours is a mk3.5 which means you need to drop the tank to change the pump :rolleyes:
its a very easy job just unplug the pump and i used a screwdriver and a gentle tap with a hammer to turn the locking mechanism and it just unwinds and you pull the pump out of the tank (if you have any trouble with this i sh\ll be puttin the RST pump in my tank soon so PM if help needed)
your cvh with run fine with the 1.1 fuel pump but if you are looking at pushing it into higher speeds i.e 70+ then i would change it as the 1.3 pump i have on my rst starts cuttin about and jumping not being able to provide enough fuel after about 120....
although with this said if you get a MFI engine i wouldnt worry about the pumps at all as your in tank pump will essentially be just priming the mechanical fuel pump so i wouldnt imagine you would have any problems....feel free to correct me if im wrong on any of this
russ-RST
Your car: fiesta rs turbo
Postby MK2 Jamie on Mon Jan 03, 2011 9:24 pm
xr2ilookalike :
All my MK3's have done that as well as my MK2, The gear box isnt knackered. In regards to the engine swap you might as well go for a zetec over a cvh engine. If you do go for a cvh dont go MFI, it was out of date technology when ford put it in mk4 escorts let along 20+ years later.
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby b0yracer on Mon Jan 03, 2011 10:48 pm
whats mfi. and am i right in saying cvh have the fuel pump on the engine (rear near the head)?
if so when i take mine out of the tank what do i put in its place?
cheers dave
b0yracer
Your car: ford
Postby MK2 Jamie on Mon Jan 03, 2011 11:09 pm
xr2ilookalike :whats mfi. and am i right in saying cvh have the fuel pump on the engine (rear near the head)?
cheers dave
MFI is Mechanical fuel injection. Its what S1 and S2 Escort RS Turbos use as well as 88spec Escort XR3I's. To put it bluntly its sh*t. CVH's commonly come with eiter MFI, EFI -Electirc fuel injection (Fiesta RS turbo and Fiesta XR2I) and carb'ed (Escort XR3 and Fiesta XR2)
MK2 Jamie
Postby jonyb4 on Mon Jan 03, 2011 11:57 pm
basicly its mechanical, so a engine driven pump sucks fuel and pressurises it into the injector rail
efi uses a electronic pump in the fuel tank
im not sure how the pump goes about its buissness on a carbed cvh though, but it wouldnt need to be as powerful all it would do in that case is keep the float chamber at level
but your best off going for a mk3 xr2i cvh engine, as it will bolt in easier and will be of the right mechanical age so all the engine loom will work in the car etc
im not sure of the xr2i but i know the RST runs on a coil, but i dont think the xr wouldnt be
Postby MK2 Jamie on Tue Jan 04, 2011 12:52 am
Carb'ed CVHs have electric fuel pumps.
MK2 Jamie
Postby b0yracer on Thu Jan 06, 2011 12:17 am
no wonder my car revs better since chopping middle box out, i looked in it today its all colapsed
b0yracer
Your car: ford
Postby b0yracer on Thu Jan 06, 2011 11:20 pm
mines a mk3.5 will lowering springs for a mk3 fiesta fit mine?? cheers dave
b0yracer
Your car: ford
Postby fezza89 on Fri Jan 07, 2011 2:51 pm
dont think so
fezza89
Postby b0yracer on Fri Jan 07, 2011 3:32 pm
i dont mean coil overs just lowering springs on to my standard struts cheers
b0yracer
Your car: ford
Postby MK2 Jamie on Fri Jan 07, 2011 9:38 pm
Arent the cups on mk3.5 shocks different to mk3 shocks or am I imagining things.
MK2 Jamie
Postby jonyb4 on Fri Jan 07, 2011 9:44 pm
hmm i dont know, funny question that
calls for a compairison pic
Postby fezza89 on Fri Jan 07, 2011 10:22 pm
i believe the springs are different, because when i was looking for lowering springs i kept getting told mk3 springs wont fit and may pop out.
fezza89
