1.1 azura has arrived
Re: 1.1 azura has arrived moddifying begins
i phoned burton power the person i spoke to said mk3 fiesta will fit but he didnt sound very convincing, he didnt really seem to understand when i said its a mk3.5 fiesta.
i had a similar conversation with these guys
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 772wt_1000
so i dont know what to do/buy
- b0yracer
- Your car: ford
i sent gmax an email with all the details of my car and they sorted me out with a set for 1994-1995 fiestas, i wish i just got a normal mk3, would of made life so much easier lol
- fezza89
what the hells this PI buissness all about then?
who what are they?
they make the springs or just a shop that sells them?
who what are they?
just a shop that sells them on i reckon
- fezza89
jonyb4 :what the hells this PI buissness all about then?
who what are they?
i just found them on ebay on the advert there was a phone number so i phoned up but not many places seem to take me serious when i say mk3.5 fiesta
- b0yracer
- Your car: ford
i just give them the year of the car and see what they come up with
- fezza89
who what are they?
They're a company, not just a shop.
- MK2 Jamie
Well Ford never actually called it a 3.5, its just a figure made up by enthusiasts, same for 6.5 or q.t, fqcelift might be more appropriate to some.models like the mk1.5 focus, but yea give the year and sate its the later mk3
right guys, not to all your tatse i know, but ive purchased a 1.3 hcs for now its out of a N reg mk3.5 fiesta it was cheap and will give me slightly more bhp/torque for now, bigger upgrade will happen later.
ive also had a go at making my own pod for tim oil and vac gauge
had to cut holes top and bottom to allow for widness of gauges
- b0yracer
- Your car: ford
looks tidy, what did you use to cut the hole?
midn me asking how much the engine cost?
Look good mate Im guessing he would have used a hole cutter Jony lol. Engine should be a nice little upgrade from the 1.1 Got the ecu too? And is your 1.1 injection or carb? Just wondering because you will need the looms if its carb Keep us updated though
- - Danny Boy -
- Your car: Fiesta Si 2.0
His car is a MK3.5 so it will be injection.
- MK2 Jamie
Ahh yes, I looked through the thread and saw I didnt read it before
- - Danny Boy -
its injection please dont tell me i need the ecu???
mine is 1.1 cfi (injection) im fitting 1.3 cfi, wont my ecu run it??
mines N reg mk3.5 and the 1.3 is from N reg mk3.5
- b0yracer
- Your car: ford
well according to this link he ran a 1.3 with a ecu from a 1.1
fiesta-1-3-tuning-vt177671/
help anyone i know its not all your cup of tea but hey its a fiesta and im on a fiesta forum asking for your knowledge
one day it will go cvh or zetech but just for now your knowledge of ecu and 1.1 1.3 hcs engines please
also im running all my 1.1 stuff its basically the 1.3 engine block head (sump lol) using my original cfi unit temp sensor exhaust manifold etc etc, fitting new 25psi oil switch with T piece and elec oil pressure sender unit. ive looked in my haynes manual the 1.1 and 1.3 have same stroke of 75.48mm the compression ratio is only different between carb/cfi models so im geussing its only bore size the difference from 1.1 being 68.68 to 1.3 being 73.96 even valve clearance is the same not sure on valve sizes.
- b0yracer
- Your car: ford
jonyb4 :looks tidy, what did you use to cut the hole?
engine was £100 and no hole saw was used it was the old fashioned mark it out drill several holes , meet them up, then used a rotary bit in a drill to smooth it off to the circle previously marked
trial fit just waiting for vacuum gauge to arrive then fit them both in and wire them up
- b0yracer
- Your car: ford
xr2ilookalike :jonyb4 :looks tidy, what did you use to cut the hole?
looks good
- MK2 Jamie
xr2ilookalike :well according to this link he ran a 1.3 with a ecu from a 1.1
bump anyone( i dont want this part missed im gonna try fit the 1.3 soon, after a quick paint and clean up, but i dont have the 1.3 ecu)
- b0yracer
- Your car: ford
you need to get the ecu, it will run on the 1.1 ecu, but it wont be right, it will under fuel, and maybe even rev funny
when i used my 1.6 ecu on the 1.8 it wrefused to rev past 4k and suffered in underfueling too
where is the ecu ?? and is it actually a ecu on this model or just something similar to a ecu i cant find any info on a ecu for a hcs engine in my haynes manual
- b0yracer
- Your car: ford
look under the passengers footwell, up behin the dashboard, look up and theres a silver recangular box should have a code on a sticker at the bottem, this si the ecu, go intot he engine bay look behind the firewall (behind the jack and brace)
theres a rubber gromet with two size 10mm bolts its under here that you can unbolt and unplug it
shame you didnt do this when i was doing my rst conversion you coulda had everything you wanted for the conversion for chips as i only threw it
yeah johny is right on location of ecu its nice and easy to find just shove ur head in the passnger footwell and look up behind the dash you cant miss it lol as for removing it it has 2 10mm bolts either side on the outsside of the loom/plug and then a 10mm bolt on the inside holding it in keep up the work
- russ-RST
- Your car: fiesta rs turbo
- b0yracer
- Your car: ford
its not going in its staying as a 1.1 xr2ilookalike, and im getting something else thats faster without all this fudgekin about
- b0yracer
- Your car: ford
oh well thats bit of a downer condering you just got a new engine
what you gonna aim for? hopefully a ford?
try an Xr or Si
try an Xr or Si
yes it will be a ford and i will keep the fiesta for lindsey i will still add the other bits i have for it and lower it slightly its just staying as a 1.1, its not fast enough for me
im getting either cortina capri or sierra sapphire powered by 2.0 pinto, i miss my oldskool stuff and love pinto power
- b0yracer
- Your car: ford
YES get a mk3 capri mate!
dont really see the buzz of a pinto tbh, old and unreliable at times, mind you never actually owned one just going from my dads experiance, never witnessed a 2.0 pinto either
glad your going to keep the fiesta though, would have been a shame to get rid of her
pintos are easy to maintain they are easy to get power out of lots of tuning parts available and very reliable engines
- b0yracer
- Your car: ford
found this today put a deposit on it, its 1.8 glx, i will fit a fast pinto in it eventually, im also gonna lower it as low as i can, make it as loud as i can, paint it satin black, strip the interior and fit 2 x bucket seats and harnesses.
keeping the fiesta as it is, will paint body kit and leave it at that for lindsey to use.
this is my new toy.
this is my new toy.
- b0yracer
- Your car: ford
Soo you have two projects then? I bet your full attention won't go on the Fiesta now. Shame...
Sierra looks nice though. What do you plan on doing with it once you've tarted it up? Drift on the round abouts?
- EUFez
like the sierra, dont think it will be a very quick toy though theyre rather heavy
Agree with Jony. Heavy sh*ts! What litre are they? 1.8? Not a 2.0 model is it?
I reckon your looking at around 1128 kg.
- EUFez
its 1.8 but i will be putting a fast 2.0 pinto in a tuned up pinto, yeah they are heavy but it will still go fast a xr4i will pull nearly 150mph my cortina was heavy but did 120 mph and was doing low 16 second 1/4 mile runs
- b0yracer
- Your car: ford
lol i dunno about this pinto tuning, theyre 110bhp standard on the 2.0
the i4 they have the twin cam is a tidy engine, mind i dont think tyheyre very tunable if theyre anything like the 16v version
the xr4i have a good 2.8 which puts out 150bhp standard, much better engine to start with imo
