1.1 azura has arrived
Re: 1.1 azura has arrived moddifying begins
You can get fairly good power out of the 2.0l pintos jony. Cheap and cheerful tuning too
- Ratspeed
EUFez :Soo you have two projects then? I bet your full attention won't go on the Fiesta now. Shame...
Sierra looks nice though. What do you plan on doing with it once you've tarted it up? Drift on the round abouts?
im going to drag race it
- b0yracer
- Your car: ford
Ratspeed :You can get fairly good power out of the 2.0l pintos jony. Cheap and cheerful tuning too
thanks youve backed up what im saying, i know my pintos and thats what i want something i can do myself and know how it works
- b0yracer
- Your car: ford
my old man used to put his foot down in his 2.0 capri lazer on round abouts and we used to spin facing the other way lol
we done that coming out o silverstone for trax one year
how have they done this or were these made ?
http://cgi.ebay.co.uk/fiesta-mk3-rs-tur ... _500wt_950
- b0yracer
- Your car: ford
looks made to me buddy
- russ-RST
- Your car: fiesta rs turbo
Yeah thats been made by someone Get a 2.0 pinto! Can get loads of power from them! With the right mods you can see over 200bhp easy!
- - Danny Boy -
- Your car: Fiesta Si 2.0
hi everyone im back !!! ive still got the fiesta and now im gonna start more mods on it, im gonna strip it lower it put bucket seats in harnesses etc and bigger motor when i find one probally 1.6 cvh
the sierra went to ford heven it was not good, then i got a renault megane and gave my wife the fiesta but today we just swapped cars so now im on with the fiesta
it wont be a quick project as im not rolling in money
- b0yracer
- Your car: ford
oo wondered what happened to you
love the plans
love the plans
give me a list of what i need to convert to 1.6 cvh on carb
remember i had a going on about ecu when i was going to upgrade to 1.3 hcs earlier this year, so my biggest question is what do i do regaurds ecu when changing to 1.6 cvh do i need a ecu??
thanks dave
thanks dave
- b0yracer
- Your car: ford
carb'd engines dont use an engine management, so no ecu, its a slightly tougher job considering yuor going from efi to carb
best thing to do is lose all the loom from the engine bay and put it aside, but you will still need stuff like fuel pimp prime and oil pressure and air intake temp... i dunno lol its a bit of a Bic™
best off converting to a Xr2i engine with Mpi
would be far easier all you'd need then is the engine, inlet and exhaust system complete, fuel pump and loom and ecu, preferably the gearbox too, done
jonyb4 :carb'd engines dont use an engine management, so no ecu, its a slightly tougher job considering yuor going from efi to carb
+1, except id go the full hog and zetec it mate
if youre getting a cvh try and pick up an old xr2i, or a scrapper, get everything in one
- Michael!
Or get an RST mate it's a very easy conversion I done mine in November and would regret it if I put anything else in instead tbh
- russ-RST
if your going for average power, the 1.6 cvh is perfect, its easy many around and straight forward
if your going for more power, with promising development in the future, a larger zetec or RST engine
which i dont think he wants
cheers guys but i just want simple cabr/dizzy/coil 1.6 cvh it will be much better than the little 1.1 im no good at all at understanding ecu injection and lots of wiring.
surely all i need to do is wire in the coil/dizzy through ignition obviously still use my original wires for oil water alternator and starter, and disgaurd all the edis coil pack cfi wires
am i on the right track with that??
- b0yracer
- Your car: ford
like is aid mate i cannot say
best thing is to simply try it and see, if your not relying on the car you have little to loose, if it goes funlumps up refer back to the 1.1
That's all I wassayin it would be far easier to stick with injection than move over to carb you just swap the loom and ECU from your 1.1 ECU to the new loom and swap ecu's is very simple it is only the engine loom you need to change to.. An xr2i engine would best suit you IMO
- russ-RST
agreed
mind you'd want the fuel pump too, it would be hampered by a 1.1 pump
Do the xr/rs' have bigger fuel tanks?
I'd stick with injection too... an rs engine would be awesome but pricey!
Just a normal 1.6cvh will give this enough poke mate
EDIT: you'll need;
Ecu
Engine loom
Both mounts
Engine
Fuel pump
Probably a new clutch, would you be using the 1.1 box with it?
EDIT: you'll need;
Ecu
Engine loom
Both mounts
Engine
Fuel pump
- Michael!
no i want a box to match the new engine my 1.1 box is s**t at going into 2 coming down
- b0yracer
- Your car: ford
Checked the fluid ?
Mate of mine has his 2i on a 1.1 ib5 and it runs sweet, fast too
- Michael!
Michael! :Do the xr/rs' have bigger fuel tanks?
Both mounts
No all mk3 fiestas have the same 42litre capacity (the 2 litres is the reserve, after the needle has reached the bottom of the gauge
both mounts? only 1 on the engine, but yet it will be needed
even if the 1.1 clutch would fit it be almost useless as it would likely slip under power
Michael! :Checked the fluid ?
he aint strictly wrong, thick old mucky oil can make changes stiffer, but not 1 gear on its own
its faster on acceleration due to the gear ratios built for the 1.1 engine being close and short
it will hamper top speeds
I got a whole RS turbo with mint interior for 400 quid so there are good bargains out there!
Yeah I agree an xr2i dinar car would bs perfect for this
EDIT: you'll need;
Ecu
Engine loom
Both mounts (there is only one engine mount ?? )
Engine
Fuel pump (yes although my RS ran ok on the 1.3 for quite a while lol)
Probably a new clutch, would you be using the 1.1 box with it?[/quote]
If you get a low milage one or a dinar car you should be fine with sticking with that clutch u have lol
Depends how much of a budget you gave for doing this with? I thought you didn't have alot.... And I would defo run it on the 1.6 box as with the driveshafts I have looked at my RS shafts and the 1.3 shafts and can see no difference at all so Im still on the 1.3 shafts as my donar was a mk3 and my car is a 3.5
EDIT: you'll need;
Ecu
Engine loom
Engine
- russ-RST
Also i would grab 1maybe 2 metres of fuel hose as when I done my 1.3 to RS conversion I found the fuel line that went to the single point injection wouldn't attach to my fuel rail so just used fuel hose has worked fine for me
- russ-RST
posted it from my iphone, and the screen looks like marble
i meant "engine mount"
- Michael!
- b0yracer
- Your car: ford
- b0yracer
- Your car: ford
usually something daft
aint argos selling a range of cd players now then, heard about it when i worked for halfords as they knew they'd loose business
they even offer free fitting
collect my vented discs and calipers tomorrow they kept them behind counter for me at my local scrapyard
- b0yracer
- Your car: ford
hope you didnt put your self too much out of pocket
- b0yracer
- Your car: ford
god i hate it when pads do that!
i honestly dont know how they do it, all my cars have always had fantastic condition brakes
its only ever when i buy them theyre like it if at all
same story for you?
same story for you?
i knew the backs of discs were a bit dodgy but didnt realise they were that bad, yeah they were like that when i got the car
- b0yracer
- Your car: ford
