1.1- bigger
17 posts • Page 1 of 1
1.1- bigger
ive got a 1.1 mk3 fiesta and i want something bigger but still want my car, becasue of insurance i cant go very big just want something a bit better, will the engine out of a newer car fit, dunno wot the 1.25 zetec engines r like and how much better r they compared to my s**t engine suggestions please
- wobblybob
if you want more poke but still cheap insurance , go for the 1.4 cvh. pretty sure the swap wont cause any headaches if you swap everything, fuel tank, fuel lines etc.
hope this helps a little.
cheeRS
Ross
cheeRS
Ross
- Ruishy1
I know the 1.3 engine is a straight swap and I found after driving a 1.1 and a 1.3 that the 1.3 does have abit more to it, nothing impressive, but it is noticable.
Just put a 2.0 in (had to say it before someone else did )
- Percy!
- Your car: Citreon
i used to have the same problem with my puney old 1.1, but instead of changing the engine, me n my dad spent a couple of weeks stripping it down and re-building it, grinding in the valves, replacing god knows whats, then sent it to the local mechanic for a bit of tuning, and it came back with a top speed of 112mph when id be lucky to get 95 out of it before we started!
- choc
choc :i used to have the same problem with my puney old 1.1, but instead of changing the engine, me n my dad spent a couple of weeks stripping it down and re-building it, grinding in the valves, replacing god knows whats, then sent it to the local mechanic for a bit of tuning, and it came back with a top speed of 112mph when id be lucky to get 95 out of it before we started!
same here, now it does 90-100 easy
1995 Fiesta SI 3 door, green something, 2L + diesel gearbox in(130mph @ 5,000rpm ), focus inlet in, + k&n, passed mot without a cat < FIESTA FOR SALE! GOT A BMW 528I SE MANUAL NOW
http://www.finalgear.com
- VUK
putting better brakes on allows you to go faster, me and my mate just getting 95 everytime out of his 1.1 on a long straight!, but having to brake really early for the roundabout!
jimmy
jimmy
- jimmy
stik with the 1.1 for now and save up your peenys and go for a 2.0l mondeo lump with it being a zetec it will be cheaper and more reliable to run than a cvh
- chris-fiesta
OK I'm a bit drunk and it's 4 in the morning in Southamerica so I hope I can explain what I'm thinking. The first fiesta that came to Argentina was the Mk 3.5 1.4liter, so we never saw the 1.1 and the 1.3 and this is what I think. If the engine block from the 1.1 and the 1.3 are the same then I would change the crankshaft for a 1.3 liter engine and then have the original engine numbers but with a littel more donkies under the hood You will certanly need to take the block for a very slightly cilinderwall rectify so the pistonrings can get a proper seal.
That's all fallks. Have a nice sunday
Fahr nicht schneller als dein Schutzengel fliegen kann
- FedeArg
