1.3 engine mod ( are there [ERRR] )
44 posts • Page 2 of 2 • 1, 2
These stupid engines confuse me, So that manifold wouldnt fit my car?
And i dont have an LX, But its a Mk3.5 so why wouldnt i have a cam?
looking at that pic you provided jam, that's an hcs engine , not a kent. hcs is a 'dereritave'(sp) of the kent engine but it is different.
i'll re-word it, that manifold wont fit on the hcs engine, the one in your pic.
JJ
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
Max M4X WW :These stupid engines confuse me, So that manifold wouldnt fit my car?
Dont suppose it would fit - but you will be able to get manifolds for your car.
I meant your cam wont have worn enough to warrent getting a replacement - mine was very worn so the new one made a huge difference.
JJ :that manifold wont fit on the hcs engine
s**t your right - i assumed it would fit the way my Dads mate was talking about it - i never even thought to look - please lay off the gloating until tonight if your actually on!!!
Jam
- F22 JAM
Lol i thought the bolts were in a different place!
So you dont think my cam will be worn after 19k?
What about the tappet thing that i can sand?
Pulse Air System
<94 HCS CFi Engines has this. It uses air and pushes in into your exhaust manifold.
Its a series of tubes that go over the manifold and warm up the air.
Something for emmisions IRRC.
>94 they removed them because the ECU's got better
- Liebo
Ahhhhhhhhhh yea ive seen engines with that and wondered what the hell it is. Mines a 95 so would explain.
Does [ERRR] of u lot know if you can put a better carb on a 1.3 HCS 1991 engine? Do you know if gettin the 1 of a MK3.5 with all the new ECU stuff will help? (theres a 1.1or 1.3 down at the scrappy). Cheers all!
- morpheus
