1.3 engine mod ( are there [ERRR] )
Postby Max M4X WW on Fri Sep 03, 2004 8:54 am
These stupid engines confuse me, So that manifold wouldnt fit my car?
And i dont have an LX, But its a Mk3.5 so why wouldnt i have a cam?
Postby jdfiesta on Fri Sep 03, 2004 12:14 pm
looking at that pic you provided jam, that's an hcs engine :P , not a kent. hcs is a 'dereritave'(sp) of the kent engine but it is different.
i'll re-word it, that manifold wont fit on the hcs engine, the one in your pic.
JJ
Is that the best you can do?
jdfiesta
Your car: V70 T5
Postby F22 JAM on Fri Sep 03, 2004 12:47 pm
Max M4X WW :These stupid engines confuse me, So that manifold wouldnt fit my car?
Dont suppose it would fit - but you will be able to get manifolds for your car.
I meant your cam wont have worn enough to warrent getting a replacement - mine was very worn so the new one made a huge difference.
JJ :that manifold wont fit on the hcs engine
s**t your right - i assumed it would fit the way my Dads mate was talking about it - i never even thought to look :rolleyes: - please lay off the gloating until tonight if your actually on!!!
Jam
F22 JAM
Postby Max M4X WW on Fri Sep 03, 2004 2:14 pm
Lol i thought the bolts were in a different place!
So you dont think my cam will be worn after 19k?
What about the tappet thing that i can sand?
Postby Liebo on Fri Sep 03, 2004 7:03 pm
Pulse Air System
<94 HCS CFi Engines has this. It uses air and pushes in into your exhaust manifold.
Its a series of tubes that go over the manifold and warm up the air.
Something for emmisions IRRC.
>94 they removed them because the ECU's got better
Liebo
Postby Max M4X WW on Fri Sep 03, 2004 9:35 pm
Ahhhhhhhhhh yea ive seen engines with that and wondered what the hell it is. Mines a 95 so would explain.
Postby Liebo on Sat Sep 04, 2004 8:07 am
Mine's a 94 (1st Aug 04 actually.... cant get any less M reg before it's and L :))
Mine has the casting points in the head for the system to go.
Liebo
Postby morpheus on Mon Sep 06, 2004 11:46 pm
Does [ERRR] of u lot know if you can put a better carb on a 1.3 HCS 1991 engine? Do you know if gettin the 1 of a MK3.5 with all the new ECU stuff will help? (theres a 1.1or 1.3 down at the scrappy). Cheers all!
morpheus
Postby F22 JAM on Tue Sep 07, 2004 1:59 pm
Im guessing yours is an SX like mine - they dont have ECU's.
I think you can get Weber twin 40's. Loads of places will do them, and ive seen them in the for sale section in Fast Ford etc.
Jam
F22 JAM
Previous
