1.3 HCS CFi induction kit/air box options
10 posts • Page 1 of 1
Is there an induction kit for the 1.3 HCS engine?
I heard 'Green' make one but I cant find any info
please help
thanks!
please help
thanks!
- Liebo
http://217.204.20.36/index/GREFitInst.asp?PartNo=P296
Its in the listing as an 1.3 EFI but if you look at the fitting instructions its definately for the CFI single point injection.
Price is £93.50 + VAT
Ripspeed can get them in 3 working days
Matt
Matt
There is no spoon
- mgiantorange
Oh, it is more expensive than some because it includes extra breather filters, one for the oil filler cap feed, and one for the crankcase breather.
You can use a carb bolt on filter, eg one for a MK2 which are available for about £40, but you may find that you need to modify the base plate slightly.
Matt
Matt
There is no spoon
- mgiantorange
they do a panel filter as well but not a cone type induction kit.
With the CFI there's not much room between the top of the throttle body housing and the bonnet. This restricts the diameter of the pipe you could have to fix a cone on to - it would have to be very squashed and bend through a tight turn. This would make it really restrictive.
Unfortunately those of us with the HCS engine have chosen one that is pretty crappy for tuning anyway.
BTW the green bolt on type filter sounds good
Matt
Matt
There is no spoon
- mgiantorange
I'd be far too humiliated to take my engine to a rolling road, but i'd guess a couple of BHP at the most from the kit
Matt
Matt
There is no spoon
- mgiantorange
having said that, my engine felt like it had a lot more torque in the mid range and revved better at the top end; but that may have been just the noise and wishful thinking playing tricks on me.
Matt
Matt
There is no spoon
- mgiantorange
