1.3 HCS engine, help!
18 posts • Page 1 of 1
Hey,
wondering if anyone can help me, got a 1.3 LX made in 1994 with an HCS engine for my first car ! Thing is i want to make it go faster, (i'm still learning whats with cars) but i cant see my engine on any price lists for air filters or anything. So what can i bolt on to get it sounding and going as good as possible?
(i think its a mark 3 but i'm not to sure, told ya i'm learning!)
Cheers, Ian
Cheers, Ian
- Newfezzyfan!
K&N bolt on air filter for an 86-89 XR2 (trust me it's the right one)
Powerflow for a cat back exhaust (1 big box and 2" bore will be just right)
Fukk my teeth really fukkin hurt now - don't let them get so bad you need a root canal mate
Al
Al
- Project
- fiftyoneCL
Great, cheers mate!
How easy is the air filter to fit? I'd like to give it a go but i dont wana fob it up to badly.
<font size=-1>[ This Message was edited by: Newfezzyfan! on 2001-10-19 09:06 ]</font>
- Newfezzyfan!
realy easy after a quick phone call to alex and halfods actually labeling the K&n filter up right!!!! - Ta alex again!
All you need is a small torx bit for ur socket set and a philips screw driver!!!
Take of the air box and undo the 4 torx bolts on the carb (one at a time not all together) put the alloy base for the filter over the carb and put the L bracket on the bolt and do the bolt back up. then do next bolt!!! piece of pie
- xrsi
- XR(ustyAtTheMo)SI
I got a 1.1, HCS engine - would a K&N be worth it? if so, would i get the same, and how much would it be? I may have picked up some knowledge in other areas - but tuning is still new to me
(It Goes!)
- Chilliedog
new little oval air cleaner - U will need these filters
56-9257 - 1.0
56-9042 - 1.1 89 - 92 only
56-9028 - 1.4 using DFTM carb 89 - 92
56-9042 - 1.6 89 - 92
56-9257 - 1.0
- Wooly
For the exhaust, check http://www.supersprint.com
and look for your local dealer
The K&N filter can be obtained at (almost)every car-shop (you have the partnumber). You also could check the autostyle cataloque(I don't know if there is one available in the UK, though).
Hope this helps. Cheers
- G-Forze
I got a bolt on K&N filter, easy as pie to fit, also uprated the jets on the carb when i was doing it =]. Sound is stunning when u first hear it at high revs, the car to me no longer sounds like its struggling (although it probably is), it makes it sound more "beefy" and combined with a good supersprint exhaust the car can make a great tone =]
- MarkB
i doubt it - the CFi unit is totally different - speak to fiesta fras anyway - he may be able to help!!
I bought an XR2 K+N for mine but i didnt realise mine was a CFi - didnt fit
- Wooly
Wooly you numpty, I fitted my old XR2 K&N onto Fraser's CFi unit!
And they are the same, externally! Ford doing the rip off thing again (so they didn't have to change the design of the airbox I think).
- Project
- fiftyoneCL
it is true, fits straight on, ,made my lumpy cam more bareable, idles better and has a much better mid range and sound, all in all wikkid, the HCS air flow's are do-doe, not enough good air in, really helps em breathe to have a K&N, my car was running too rich on idle before, and my fuel economy is actually the same or better!
- fiesta_fras
- Elite Poser
- Wooly
