1.3cfi turbo - (anyone seen one running positive boost?) : Member's Gallery - Page 2 | Fiesta Forums
Postby FezzR on Wed Jun 01, 2005 8:09 pm
plastic bath :oooh: i did ask tho :lol: (knowing full well what the answer would be)
FezzR
God Damn Lazy
God Damn Lazy
Postby FedeArg on Thu Jun 02, 2005 2:23 am
What is commonly used here in Argentina (we are still on the stoneage :bonkers: :lol: ) is an extra inyector on the top of the pressurisation manifold (I´ll ad a pic of the before mentioned manifold so you can understand what I´m talking about) that is comanded by a pressure diaphragm (spelling) So when you are on the upper RPM range you have the necessary fuel so the combustion doesn't get lean and you melt a piston. This inyector only works on the upper range, when the engine is idling or in the middle RPM range it's swithced off
I'll add the picture in a couple of minutes
This is for an IDF carburator
And this is for a car that had SPI and they changed ir for a carb but it is the same that you could use because of the design of the FORD SPI that is very similar to a carb. This one doesn't have the inyector I mentioned but I couldn't find any with it. I'll continue searching
Hope this gives you an idea[/img]
Fahr nicht schneller als dein Schutzengel fliegen kann
FedeArg
Postby TomRS1800 on Thu Jun 02, 2005 5:11 pm
Stoneage indeed
and as Stoned said
Lets see somepics of the rusty beast
TomRS1800
Postby FezzR on Thu Jun 02, 2005 11:29 pm
fedeArg, that thing loos bit random certainly not like what im using
Tom plenty of pics of it about from when i was stripping it down,
todays update:
Cleaned the head, by dipping
then started some porting
FezzR
God Damn Lazy
God Damn Lazy
Postby scarlet_pimp_mobile on Mon Jun 06, 2005 10:45 pm
an hcs being tuned!?!? :lol: :lol:
this is a wicked project, you have to video it blowing up with the turbo :P (that is your aim isn't it?)
imagine if you got chatter! :lol:
" San Diego... German ofcourse, meaning 'A Whale's Vagina' "
scarlet_pimp_mobile
Location: Hurst Green, East Sussex/ Constitution Hill, Swansea
Postby Pez on Mon Jun 06, 2005 11:06 pm
At the end of the day, the HCS is only a ponced up emissions friendly OHV motor, and there's OHV's out there pounding 150bhp+ and then some, and then you add forced induction on top. Good old 1760cc monsters :aviator:
Pez
Postby FezzR on Mon Jun 06, 2005 11:07 pm
scarlet_pimp_mobile :an hcs being tuned!?!? :lol: :lol:
i think i will be investing in or borrowing a video camera to capture every running moment, if there is any,
but it wont be running long :devil:
remember how much needs doing today :cry:
FezzR
God Damn Lazy
God Damn Lazy
Postby Max M4X WW on Mon Jun 06, 2005 11:19 pm
Why dont you do it all proper and try and make it work for longer than a week?
Postby Smo on Mon Jun 06, 2005 11:22 pm
Are you going to attempt to lower the compression at all?
If so, how were you thinking of doing it? Spacer plate? Or a second head gasket or something? :lol:
Smo
Postby FezzR on Mon Jun 06, 2005 11:41 pm
Max M4X WW :Why dont you do it all proper and try and make it work for longer than a week?
because the cost isnt worth it, at the moment im only going to have to buy
some pipe work
gasket
management - which ill continue to use on other projects anyway
i was tempeted to lower compression, until i found out it was already 8.8:1
ill deside nearer the time of bolting the head back on, i was planning on using one of those funky copper head gaskets, which are thicker anyway, and there is plenty or material in the combustion chamber that can be removed if i want.
FezzR
God Damn Lazy
God Damn Lazy
Postby krsi on Tue Jun 07, 2005 12:23 pm
Can't wait to see this finished mate. I wanted to buy a HCS fiesta a little while back to have a play with turbo set-up on one. Good luck mate, even if it produces in the region of 100bhp, it'd pretty good for an engine that weighs as much as a breeze block :lol:
krsi
Postby scarlet_pimp_mobile on Sat Jul 30, 2005 1:18 am
BTT :P
I wanna see this in action, so come on fezzr! Any progress?
The sound will be quite horrendous, my old hcs had such a nasty, dirty noise to it...(shiver)
scarlet_pimp_mobile
Postby Max M4X WW on Sat Jul 30, 2005 11:00 am
scarlet_pimp_mobile :nasty, dirty noise to it...(shiver)
:lol: :lol: :lol: :lol: :lol: :lol:
Postby FezzR on Sat Jul 30, 2005 11:51 am
funny you should mention it, im back on the case as we speak, been away a while so no real progress other than modifying the head to flow better :D
FezzR
God Damn Lazy
God Damn Lazy
Postby scarlet_pimp_mobile on Wed Aug 03, 2005 5:05 pm
bangin' :D
scarlet_pimp_mobile
Postby FezzR on Sun Aug 07, 2005 3:46 pm
UPDATE - BEWARE PICS ARE HUGE
just throwing up pics ill add comments and thumbnails later
[URL=http://www.fezzr.co.uk/OPEN/Fiesta/Head/head7.JPG]
head
[/URL]
Head pic
Head pic
Head pic
Head pic
Head pic
FezzR
God Damn Lazy
God Damn Lazy
Postby MotorcyclesFish on Sun Aug 07, 2005 5:53 pm
Christ, I don't fancy the state of your inlet valve seat on that cylinder you've done. BTW are you sure you should have ground away ALL of the combustion chamber shroud?
Either I'm mistaken or that's a longitudinal engine... is it RWD? Also, what engine IS it? :lol: :lol:
MotorcyclesFish
Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
Postby FezzR on Sun Aug 07, 2005 5:57 pm
no im not sure of anything at mo lol. but it isnt call removed there is still plenty more there but it will be measured soon ish
yea i know about the valve seats and its pissed me off big time, wont go into how it happened tho. think should get away with it by the time its all back together tho
FezzR
God Damn Lazy
God Damn Lazy
Postby FezzR on Sun Aug 07, 2005 5:58 pm
as for pic i have no idea what it is
FezzR
God Damn Lazy
God Damn Lazy
Postby FedeArg on Sun Aug 07, 2005 7:59 pm
MotorcyclesFish :Christ, I don't fancy the state of your inlet valve seat on that cylinder you've done. BTW are you sure you should have ground away ALL of the combustion chamber shroud?
That is a Volkswagen Gol (not Golf) engine. That car is FWD. The picture was just to show how easy it is to attach a turbo to a carbed engine
FedeArg
Postby scarlet_pimp_mobile on Mon Aug 08, 2005 2:43 pm
FedeArg :That is a Volkswagen Gol (not Golf) engine. That car is FWD. The picture was just to show how easy it is to attach a turbo to a carbed engine
the 1.0 turbo? something stupid like 120 bhp aren't they!? wicked cars, the Gols :Q
scarlet_pimp_mobile
Postby FedeArg on Mon Aug 08, 2005 3:35 pm
No mate, that's an Volkswagen AP (Alta performance = High Performance) engine which could be 1.6, 1.8 or 2.0, but I'm preety sure it could be a 1.6/1.8 block with the 2.0 crankshaft so it should be a 1.9 liter engine. The AP engine is allmost impossible to destroy. Plain standard without doing anything an AP engine can handle 600gram. boost without any problem (of course you have to match the fueling on the upper rpm range)
The 1.0 liter engine is the volkswagen AT (Alta Tecnologia = High Technology) engine
FedeArg
Postby Gazeddy on Fri Dec 22, 2006 4:45 pm
I take it there is no update on this
1.6 si coming soon
5 Door Register
Gazeddy
Re: 1.3cfi turbo - (anyone seen one running positive boost?)
Postby rob pace on Sun Mar 11, 2012 10:10 am
i know its well out-dated but whatever happened to this?? :-? :lol:
rob pace
Postby FezzR on Sun Mar 11, 2012 10:38 am
Zero! I left the country and the car got scrapped :(
FezzR
God Damn Lazy
God Damn Lazy
Previous
