1.6 CVH
9 posts • Page 1 of 1
Re: 1.6 CVH
cams, power boost valve, ported and polished head, superchip and air filter from the top of my head. stripping some of the car down also saves weight as you will already know
if any of the above is wrong i apologise but im pretty sure they do the job
- slaney21
- Your car: Zafira A SRI 2.216V
Re: 1.6 CVH
Whats a power boost valve? Also i was looking at a Superchip, do these help, what sort of increase shall i expect?
- jeoff82
Re: 1.6 CVH
superchips can make a noticeable differnce in acceleration and bhp if you have a pretty much good setup elsewhere. power boost valve (again someone correct me if im wrong) is something which you can adjust to allow more fuel thus making it a bit faster
theres one on this site.
http://www.roadrunnermotorsport.co.uk/i ... prices.asp
hope that helps matey.
- slaney21
Re: 1.6 CVH
Yeah The Powerboost Valves Make A Difference Mate
Theyre Made By FSE And Only Cost About 80 Boys
- rowley63
Re: 1.6 CVH
well if your taking about a carb fed one then big carbs,cam kit,gasflowed head,exhaust manifold...if you mean efi then chip,cam,head,manifold...good filters and a good exhaust for both... my 8v 2i with a stage 1 head,kent cvh 22 cam kit,k&n,scorpion made 120 bhp....so for a round a grand it made 12 bhp...dont expect loads of gain for your money...
- FRSJON
Re: 1.6 CVH
i went 1.9 bottom end route with my old one, but it aint cheap to do.
as abovem head, cam, manifold, good system, chip, induction kit. if you got the cash then look at boring it out and fitting higher comp pistons. but talking mega money. my 1.9 cost me about 7k maybe more in the end,
- White2i
Re: 1.6 CVH
7k for a 1.9 bottom end!!
in all fairness 12bhp from a piper cam kit doesnt sound too bad. Have you considered turbo'ing it? There are engines floating about on ebay for a few hundred quid, the tuning potential per pound is tonnes better
rusey
rusey
- Rusey
Re: 1.6 CVH
Rusey :7k for a 1.9 bottom end!!
yea mate, steel crank, rods, forged pistons, head work, custom cam, custom inlet, etc etc
- White2i
