1.6 ecu or 2.0 ecu????????????
13 posts • Page 1 of 1
Get my car back in a few days and getting a little concerned about this factor of the conversion. i am running the 2.0 injectors and the bloke who is doing it said that the ecu's were the same, so i took his word.
Can someone please explain this to me cos i am lost:-
which is the better ecu? dumn question i know
would i be able to tell any difference in performance + why?
will the 2.0l work ok on the si ecu?
will the 2.0l injectors be firing correct?
many thanks, Adam.
many thanks, Adam.
- Wude Si 16v
runs ok bottom end with si ecu.. but top end it runs pants and doesnt rev as high as it should.. well it revs but takes much longer
best get 2.0 ecu
best get 2.0 ecu
- Phil Si
Car: 2000 BMW 330 Ci
rightio il share my knowledge of zetec e ecus,
the codes are as follows:-
GERM - 1.1i not a zetec but i thioght the name was funny
GURU - 1.6 si etc
DEEP - 2.0 mondy ecu 130 spec style
CULT - 1.8 RS1800 fiesta ecu 130 spec, thk revs better than mondy one
i tired TELL (2.0 mondy one again) that didnt work at all, might have been a dodgy one thou, the code can be seen on the sticker at the connector
GURU - 1.6 si etc
- fiesta_fras
- Elite Poser
Nb: if you have no E-DIS module on your bulkhead (centre of the bulkhead), you must use ECUs with an engineering code beginning 94, eg "94 AB CDEFG AA" - these include the 130ps RS1800, 130ps 2.0L Mondy engine, possibly the 115ps 1800 Mondy engine, and not a lot else.
If it now has E-DIS, you need to use a 92-94 ECU. Since you still have the Si ECU, you must use the 94 version
Al
Al
- Project
- fiftyoneCL
fiesta_fras :some 93 mondys have edis inside ecu mate
Oh testicles. Think they all do, don't they? (I'm sure you've told me that several times before).
D'oh!
- Project
- fiftyoneCL
well i have a mondeo ecu
And it has DESK on it... i read some where that mondeo ecus where desk duwe and deep ??
- unknown_user
- Phil Si
The code written on mine is TELL, is this gonna work correct, cos in one of the earlier posts someone had trouble with this ecu.
cheers, Adam.
cheers, Adam.
- Wude Si 16v
i had a TELL ecu, its from a manual mondy 93-94 less sir con
my one did not work, the fuel pump didnt even prime, i thk the ecu was probly just dodgy.
it should have worked in thoery, but no promises
- fiesta_fras
- Elite Poser
