1.6 EFi
23 posts • Page 1 of 1
xr2i 8v orion injection escort
to fit it you would need xr2i rad engine mount full zorst wireing loom ecu map sensor petrol tank with pump all colent hoses
- fiesta boy
- One big spelling error...
It is a 1.6 litre petrol engine, that's all.
As for fuel tanks, it appears you will only need the inertia switch, appropriate relay and pump, as wiring is already in place and, although I haven't absolutely confirmed this yet, the tanks *appear* identical. In any case, I have at least one tank you are welcome to.
HTH - Al
HTH - Al
- Project
- fiftyoneCL
so who is right?! is it just a 1.6 petrol engine or is it XR2i/Orion??!!! can some1 confirm?!
if i do only need inertia switch, relay etc. will this be included do u reckon? ad says "all ancillaries"?!!!! r these to be taken direct from the donor car or do i need to get stuff from other cars???!!!! (can u tell i don't know much about engines!!!)
- Danny 2i
- The White 2i Guy!
- Your car: N/A
Using my newly aquired knowledge, u would also need to get new transmission as with a 50% greater engine, the ratios will be different
- Chilliedog
That's what I meant, but for insurance purposes, 1.6 petrol means a lot less than XR2i, as you're less likely just to buy a 1.6 petrol to be aboyracer in than a 2i.
- Project
- fiftyoneCL
so u reckon best bet would be to say "hello! im putting a standard escort engine in my fez please?!!!" + "forget" to mention that it'll make the fez in2 n XR2i???!!!!
n e 1 know if i'll need owt else? also are these engines easy to do basic tuning to?
- Danny 2i
- The White 2i Guy!
- Your car: N/A
You "forget" to mention the proper details of the engine; they "forget" to pay out when you make a claim.
Not worth it - either be completely honest, or be prepared to take the fall if it goes ti ts up.
(soap box put away now).
Al
Al
- Project
- fiftyoneCL
just tell your insurance you've put a 1.6 in and then if they want to know more just say yep it's a cvh efi engine. If they ask what car it's from just say you dunno [ERRR] the engine was bought from a scrappy on it's own.
- zetec69
Me thinks that the insurance company would rather a car with the original engine, rather than one which has its engine transplanted in.
What im trying to say is:
Insurance should be lower for a XR2i, bcos the engine hasnt been played with, and is standard.
Where as they may not take kindly to an engine transplant, considering the things that could go wrong.
- TJ
