1.6S
14 posts • Page 1 of 1
1.6S
Hello i have just recently bought a 1.6S i no that these r the same engine as the later xr2's, So if i put a XR2 carb on my 1.6S will it make a difference in performance wise and could it b done diy or will it need professionally doin? thanx for your help Ross
- Stokesy_y2k
It will make a bit of a difference and it is something you can do as long as you have everything.
I have a 1.6s and am about to start the tuning, a new cam is first on my list, a good fast road cam will give more power than a new carb will for only a bit more money.
- Daniel
Depends what year the carb comes from
The later XR2 engines are identical to the 1.6's and will have the same carb. The older XR2's (C reg and before I believe) had a older carb which gave 96bhp instead of 90
However it also gave worse fuel economy. They dont change these things over for no reason after all
- Stoned
i thought that the later xr2 engines had a different carb than the sport. actaully im quite sure they r different cus thats the only thing that is different on the engine.
- Stokesy_y2k
Stoned :The 1.6s uses the later XR2 engines. They were left over and Ford needed a use for them so the 1.6s was born
The man is right all xr2's after C reg came with the same carb as the one on the 1.6s.
A simple mod for 6bhp if u ask me! However I'm not sure about the fuel consumption being a problem if u get an earlier carb because they were actually a far better carb than the later ones!!
God knows why Ford changed them
now sold but not forgotten!
- 1600power
Modder_J :sorry if this is a dumbass question
but what are twin-40's and wot they do ?
i've seen a few pix of them, and it looks like twin carbs coming off the manifold or something ?
its basicully the equivalent of strapping a turbo onto a NA car.
Ok not exactly that dramatic but it turns a carb'd engine into abit of a beast!!! instead of having just one carb u have in effect 2 (I think thats right lol) therefore sucking in far more air than normal which in turn allows to engine to rev more freely and drink fuel faster than you can guzzle pints of special brew!
With regards to why bother with the small 6bhp increase, why bother fitting a charge cooler to a FRST if its already got a decent bhp? Ah yes because it allows you to run more boost gaining a few more bhp!
It works the same way for us XR2 engined drivers small bhp increases are as good as small bhp increases for you frst drivers! I agree that twin 40's would be in the ideal world the perfect mod to the air setup but they cost a crap load to buy and a crap load to keep fed!
- 1600power
