1.8 16V XR2I / RS1800 INLET MANIFOLDS
6 posts • Page 1 of 1
i have a 1.8 zetec xr2i and after talking to power engineering they made me aware of a variation with the inlet manifolds between the 2i and RS1800.
I have upgraded the ECU, throttle body and have cams to go in all from an rs1800 but the manifolds are suposibly different, i have an rs1800 manifold and the stuff power engineering said adds up. the 2i the manifold looks the same the only difference is 2 letters on the back on my current one it says SO (standard output) the rs1800 says HO (high output?)
this is exactly [ERRR] power engineering said to look for and apparently there is a major difference although not visable to the eye? can anyone confirm this.???
- martyb1800xr2i
Have heard this and am planning on getting the two flow tested back to back over the spring to see what's what
the rs1800 inlet ports have a bigger internal diameter than the 2i/si 16v.
if you put the 2 side by side you'll notice the difference
JJ
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
i knew my pic would come into it, couldnt find it myself
jj
jj
- jdfiesta
- Your car: V70 T5
jdfiesta :i knew my pic would come into it, couldnt find it myself
jj
its a very usefull pic mate lol
- RS rob
