1.8 or 2.0 into 1.6si
11 posts • Page 1 of 1
How hard is it to put a larger zetec into a 1.6si, what would need changing? Which companies would do it for me as i have no technical skills whatsoever,what sort of cost would be involved?
Sorry about all the q's.
- Dave106gti
if its the 16v you have got the engine is just a straight swap apparently..............dont take my word on it tho as im not positive.
as for 1.8 or 2.0 go for the most you can i reckon as youll only regret it later when you get used to the speed......an what your insurance co. lets you have
Now owner of a Mk2 Golf, but a FRST is next mark my words (or a VR6 conv. for the golf )
- TimEdwards
- TimEdwards
Yeah as its a 1.6 si the engine mounts and various other parts can cope with a bigger zetec.
rs1800 or a 2.0 will probably be your best bet.
you could do the coversation yourself you and a haynes manual you will have it done in a weekend. as a garage wil probably rip you off.
[img]
- Bad Boy Si
http://www.zetecinside.com
http://www.fiestaprojects.com
etc
Fairly straight forward swap. The 2.0 needs a different water pump fitting, and the sump and oil pickup pipe needs swapping for a 1.8 unit.
Fuelling will be a problem afterwards. You'll need to get the ECU tweaked or use a later ECU mapped for the 1.8 RS1800 for instance.
etc
- grahamb
- Phil Si
Car: 2000 BMW 330 Ci
Bad Boy Si :
oh or did i mean conversion
[img]
- Bad Boy Si
the sump needs swapig, oil pick up, oil pump, power steeering pump, water pump...use the 1.6 ones off ur old engine... then u need the mass airflow sensor/throttle body/ECU from the 2.0. u can use the manifolds of the 1.6, as the ports are alot wider than the engine.. werid really... but there ya go! i guess we have mr ford to thank
i cant think of owt else...
in all fairness it aint too hard.. altho i did have 2 top maties working on it
- Phil Si
