1.8 sierra cvh bottom end on frst
4 posts • Page 1 of 1
wot power gains could you guesstimate on this conversion!
im having 1 fitted this week with the compression ratio the same as a rst, im also running ofab management with 10 psi boost on a t3, filter and full straight threw exhaust system!
- tommy g
Re: 1.8 sierra cvh bottom end on frst
not much TBH. The extra torque will make off boost drving nicer though
- Ruishy1
Cool are you using the 1.8 head as there bigger
- j7aoc
yer i bourght it last night for £150, it came as a bare bottom end with oil pump! its got low compression pistons same compression ratio as a escort rst! hes had it all honed! and a full rebuild internally! all thats left for me to do is reposition the crank sensor and dip stick on the other side! everything else is the same really! carnt wait! hopefully on the rollers it will see a nice gain in torque!
- tommy g
