1.8 zetec - 130ps spec
12 posts • Page 1 of 1
Just to make sure i've got this right...
if i put my 2.0 throttle body, DEEP ecu, 2.0 cams and 2.0 MAF onto my 1.8 105ps zetec, it should work correctly?
Or do i need an RS1800 ecu and maf? as i imagine they're kinda hard to find :S
thanks a lot,
thanks a lot,
oh hoh
- demolition_man
Re: 1.8 zetec - 130ps spec
If I had a pound for everytim.................
This was discussed fairly recently mate, give it a search and I'm sure you'll come up with something.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
i've read that it will work, but i also read that it works to a point but the RS1800 ecu is better. but i don't know if this is true...
oh hoh
- demolition_man
should work fine mate make sure you got all the bits off the early zetec e lump the one with dohc on the cam cover and you'll be ok
- 2.0zetec
which inlet you using i'm using the fiesta 1800 1 with the 2l throttle body with no probs eith the 1800 injectors but i'm gonna try the 2l ones when i can but that wont be for a while cos i took off my kit 2day the car was meant to be going for paint this week and both rear arches are fouqqette (time to get the welder out )
- 2.0zetec
wounded yeah using 1800 inlet, i'm currently running the 1800 with a 2.0 deep ecu, 1.8 maf and throttle body, runs fine, wont run properly with 2.0 ecu and MAF, i'll fit the 2.0 cams and throttle body in the next week or so and see how it runs, then try swapping the injectors.
thanks for response,
oh hoh
- demolition_man
if you stick all the 2.0l bits in should be fine where did you get your maf from is it clean on the little coil type bits as ive heard that any oil or grime from the breather return can gum these up and fouqqette the dealio if all else fails try cleaning these with some thinners/alchohol cos this will evaporate totally
oh btw i'll be interested to hear how you get on with the injectors
p.s could you send me some pics of your front bumper cos i've just got hold of one with the same lip and wanna see it on before i have it painted cheeRS
- 2.0zetec
sorry mate, didn't see your reply - here is a link to the thread, plenty of pics of the front bumper painted towards the bottom.
freshened-up-the-fiesta-now-white-lots-of-pictures-vt158118/
haven't got round to messing with the injectors yet - way too busy atm!
oh hoh
- demolition_man
why would you wanna use 2.0ltr management on a 1.8 engine?
- happypaul
cheers m8 will post piccies of mine when work out how lol still unsure as tgo the lip cos its got cracks in the fibreglass and i dunno if they'll come back in time? oh btw you did a great job painting that yourself m8 looks stunning
- 2.0zetec
