13 crossflow
16 posts • Page 1 of 1
13 crossflow
Iv got a 95 1.1 just now and was wonderin if i should get a 1300 crossflow cuz im gettin it for f**k all but dont no how much modification the OE engine loom would need and ideas?
allso what good mods can i do to the engine itself?
turbo restoration in progress
painted, interior half in, windows in let the rebuild continue
http://www.fiestaturbo.com/forums/post1715280/#p1715280
http://www.kinghorn1.wordpress.com
- KINGHORN
its a s**t hcs iv got just now and i hate it. crossflows can be quicker to
- KINGHORN
its still a s**t engine the crosser is better in my books
- KINGHORN
re
why bother in that case? just chuck a mk2 xr2 cvh in with the webber carb? would go a lot better! but if you really want the kent crossflow then use the standard dizzt etc ( i would go for a mk1 xr2 1600 crossflow meself!)
- the1gazza
but the fact its free helps sway me to the 13
- KINGHORN
WHAT U MEAN STANDARD dizzy outa what the engine thats in or the crosser
- KINGHORN
First off you wanna find out what the 1.3 is from.. If it's not from a mk1 fiesta then you gonna have to work on the mounts, oil pump, water pump amongest other things to make it work.
Dizzy wise? - It'll be using fords breakerless igniton afaik from standard, i don't have a clue how this wires in though. Might be best to check the message board at xroc.co.uk
I don't even know if it's possible to actually fit a kent engine into a hcs car - Without serious mods.
- James-UK
- Location: Cornwall Drives:Whatever is outside at the time.
Easiest thing to do is fit the 1300 HCS CFi engine from a 95 fiesta along with ECU and inlet manifold & injector.
Anything else is a pain in the arse and won't gain you a great deal of power without going down the tuning road, which is awkward with the mid-mounted cam set up of the X-Flow-derived Valencia/HCS engines.
For the grief outlined above you could fit a Zetec engine (you already have all the car-side wiring in place for the fuel pump and the engine loom is a straight swap).
The 1300 engine you're talking about will almost certainly bolt straight in but if you don't have the 1300 injection parts you might be better off seeing if it will run with the existing 1100cc management (it might run lean at top end but the ECU should be able to handle fuelling lower down).
hth a bit - Al
hth a bit - Al
- Project
- fiftyoneCL
THE XFLOW already has some tunning goodies including high lift cam but i hear what ur all sayin and im begining to think its a bit of a baxtered to get in. the engine is outa a mk1 but im gonna take my car to some bloke up here who is fezzy mad engine wise to see what he thinks.
more comments will be appriaciated
- KINGHORN
dead easy to drop the crossflow in. You will need to wire up the coil and starter, and maybe swap the plugs for the oil temp, i think they might have an anti run on for the carb which just needs a + ignition feed. You will have to bodge up the hoses with bits of hose, copper pipe and jubliclips which is pritty easy to.
I think crossflow engines are great, if its free its even better!
- Simmo
XR2iT :Who is the fiesta specialist in Aberdeen?
f**k NOS
- KINGHORN
