1400 si (cvh)
8 posts • Page 1 of 1
1400 si (cvh)
Hi alli have just read the guide on putting a 2.0 16v into a 1.6 16v si is it the same to a 1400 cvh as well or do i need to more??
any more help or old posts would be sweet as
many thanx
whitty
many thanx
whitty
R.I.P ROB GONE BUT NEVER FORGOTTEN
- Whitty_696
pretty sure therer is more work involved, i swapped a 1.6cvh turbo engine into a 1.4si, the mechanics were pretty straight forward, had to change to manual steering rack tho.
but the wiring is a bit of a Bic™ ( i hate wiring looms )
if i was you go the turbo route
Ross
Ross
- Ruishy1
- Whitty_696
Jpex :aparently its alot of work getting the zetec engine set up.. i think thats why people go for cvh engines like the rs turbo engine or the xr2i
Rs turbo sounds like an idea but what am i looking at work wise??
so i would need:
engine
turbo
gearbox + drive shafts
loom + ecu
intercooler
what bits would i need to change??
- Whitty_696
ive just boughta 1.4 si CVH,and im putting a xr3 lump inntit,strait swap-ish but mines gonna be run on twin dcoe 40,s.il be posting pics of the project when it starts(nxt week hopefull) so if you have any q's just PM me and il try and help you out mate.
projectMK3
projectMK3
- PMK3
The only problem is your going to need to upgrade the brakes, gearbox(clutch) and suspension if you go for a 2.0l or 1.6turbo, becuase the parts from a 1.4si are not up to the job, they are fine for a 1.6 but any bigger engine like a turbo'd 1.6 or 2.0l and your not going to be able to stop or change gear particularly well, and these are some of the most expensive parts including labour for a car. IMO you should sell the 1.4si and buy a 1.6si, that way its an easy swap to a 2.0l and standard brakes and gearbox will be sufficient!
Mike
Mike
- diablosvy
