16"s on FRST
Postby Nitrous on Tue Sep 18, 2001 8:36 am
Will 16"s go on my frst without any hassle?? a M8 told me I could get 17"s on without coilovers, I have been told by alot of people this is bollox, dont know who 2 beleive because he said he has done it on a few MK3's he siad it may need a bit of tweaking! I dont fancy buying new 17"s to have the rubber cained & for him to say it needs tweaking a littlemore, expensive way of finding out!! Also some people say 16"s with 195/40 will go without probs other people say its tight suppose its down 2 how much its lowered & what susspension is used?? Is it really worth me going for 15"'s may aswell keep my RS1800 & get some new tyres!!!
Help!
Nitrous
Postby andyc on Tue Sep 18, 2001 8:50 am
Dunno if this will help or not m8 but ive currently got 16s on my SI without any hassle. The only problems i get are when i have a full car and go over neasty bumps you hear the back come down and scrape the wheel a bit. Thats all. Im cutting the arches back next week. Just using a hacksaw and some pliers and tools. :Q
Dont drink and drive...You might spill it!
andyc
Postby Doc on Tue Sep 18, 2001 9:23 am
17" are a ball ache to fit as detailed on this site, arch cutting, suspension setups, spacers etc etc.
16" are a happy medium but still require some mods, you will have to space the back wheel out by either drum spacers or wheel spacers, you may also need to trim the arches slightly if your car is lowered.
Go for 40 profiles with 16" and try to get a tyre that has a rounded profile on the tyre wall as it will help clearence (P5000 Drago`s are ace for this)
To be honest its a matter of trial and error as all cars differ, some will require more work than others.....like mine :smile:
Doc
_________________
Imagecraig@IlsonIlson.com
<font size=-1>[ This Message was edited by: Doc@IlsonIlson on 2001-09-18 09:23 ]</font>
Doc
The Luurve Doctor...
Postby Dan Xr2i on Tue Sep 18, 2001 9:45 am
Doc - Are your Stealths 15's?
What hassle did you have with fitting yours?
Dan Xr2i
Postby Doc on Tue Sep 18, 2001 11:22 am
Yer 15", just sold them for some 16"
Stealths needed spacing 6mm on the rear due to them being 50 profile tyres - catching on the suspension cup.
The fronts catch when on full lock, apart from that they are easy to fit straight on jobbie :smile:
The new 16" are a bit harder, 45 profile tyres catch on the suspension cup again, this time i have to space out the rear drum setup 13mm! When i`ve done that i`ll tell you if i had to shave the arches :wink:
Doc
Postby Nitrous on Tue Sep 18, 2001 11:40 am
Nice 1 Doc, So 15" with 195/50/15 will fit but need spacers?? & 16" will with bigger spacers?? Do U have coilovers??
The arch cutting isnt really a problem, its the suspension side thats bothering me, im getting a full re-spray & they said I can get 17"s on without coilovers, I really want to know if this is possible??, I have printed the 17" fitting guide off of here but cant remember it said coilovers were defo required.
Cheers!!
Nitrous
Postby si sexpert on Tue Sep 18, 2001 2:13 pm
mines running 16's with 195 45 profile tyres, lowered 50mm at rear and 30mm front no arches have been trimmed and i only have scrubbige or full left hand lock, and with 2 in the back. hope this helps!
si sexpert
One Star Wonder
One Star Wonder
Postby Tom SX on Tue Sep 18, 2001 2:35 pm
brad had 17' MAS's on his Si with only Pi springs! dunno how, look for zetec69 :grin:
Tom SX
Your car: A big German gaymobile
Postby Doc on Wed Sep 19, 2001 1:54 am
I havent got coilovers, but to miss the suspension cup i have spaced the drum out 13mm.
Doc
Postby Dan Xr2i on Wed Sep 19, 2001 3:01 am
I still needed a 3mm spacer on the rear with my 45 profile tyres fitting 15inch stealths. Cos it rubbed on the suspension cup.
Dan Xr2i
Postby Nitrous on Wed Sep 19, 2001 7:48 am
Thanks 4 the replies!!!
If U space out the rear do U have to space the front to match aswell??
Also, how much R 13mm spacers?? (Roughly)
<font size=-1>[ This Message was edited by: Nitrous on 2001-09-19 07:50 ]</font>
Nitrous
Postby Doc on Thu Sep 20, 2001 9:13 am
No you done have to space out the front and
13mm spacers are thirty quid ish from Ian Howell - Fiesta Frenzy, go to the main board his number is there.
Doc
Doc
Postby Nitrous on Thu Sep 20, 2001 11:42 am
Nice 1 cheers!!
ive seen 16" Voodoo's for £495 with Uniroyal tyres & with F1's they R £600!!
Nitrous
Postby Ian C70T5 on Fri Sep 21, 2001 3:11 am
I've got 8x16's with 215/40 16... And a 5mm spacer at the rear... thats it. oh and major rubbing on arch...
Ian C70T5
Das Ist Kapput
Das Ist Kapput
Postby Nitrous on Fri Sep 21, 2001 7:55 am
What suspension R U using Ian?
Nitrous
Postby Ian C70T5 on Fri Sep 21, 2001 8:36 am
Standard Shocks and 35mm Chassis Dynamics Lowering springs.
Ian C70T5
Das Ist Kapput
Das Ist Kapput
Postby MadcatCraig on Fri Sep 21, 2001 12:27 pm
195/40 R16 are only made by Dunlop and are fookin expensive arround £80 a tyre :aaah: Im having them on me fezzy when i get me wheels :grin: oh mine is lowered 35mm the wheel place tried one on for size and they is putting spacers on and saw no need to trim the back arch fitted snugly :grin: all depends on wot style of rim u go for
MadcatCraig
BANNED SELLER
Postby jamiroquaifan on Sun Sep 23, 2001 1:29 pm
at the moment my wheels are standard size with big crappy tyres (13inch bk racing 5 spoke split rims things that came with car) and standard suspension setup. im going to buy some 35mm lowering springs soon and eventually fit some 16 inch 5 spoke mondeo wheels with 40 tyres. im going to buy wheels spacers for all the wheels and have the arches trimmed after, but what size wheel spacers should i get? :smile:
jamiroquaifan
Postby AndyBlackFRST on Mon Sep 24, 2001 8:26 am
I have lowered my 2i 60mm all round and have 15" s on. I use 195,45's and don't have any problems
AndyBlackFRST
BANNED SELLER
Postby jab on Mon Sep 24, 2001 8:44 am
Same as Andy (above) 195x45x15, -60mm rolled the arches back and front, no rubbing.
jab
Postby jamiroquaifan on Mon Sep 24, 2001 11:20 am
actually i think i`ll lower it 40mm on 16s on standard shocks with wheels spacers. what size wheel spacers are available? how much would clear the rear cups? :smile: mondeo 16s are going on
jamiroquaifan
Postby jamiroquaifan on Mon Sep 24, 2001 12:29 pm
i see above someone used 5mm spacers. now that doesnt seem a lot to me? surely just spacing the wheels 5mm will not clear the rear suspension cups? :???:
jamiroquaifan
