165 chip safe 4 9psi????
7 posts • Page 1 of 1
Got Phase zero chip (165) can this run boosts from 7-12psi? Is it ok to run on a lower boost? I want to run 9-9.5psi. I know the fueling will have to be adjusted. Any comments appreciated
Also anyone who wants to sell std 3 spoke FRST alloys text or call me on 07787996904.
CheeRS
CheeRS
- festaturbo
A Superchip 165 will handle 9 psi no problem, my 165 chip is handling 15 psi
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
If you're only going to run 9psi the chip will be redundant, the altered ignition curve wont be any good for 9 - take the chip out mate
I used to run my 165 Superchip with 15psi and this was fine! The chip i had took the boost cut to about 20psi ish as my gauge wasn't accurate until after about 18
The rev limit was also removed or was definately above 7000 which you're not really gonna use on a standard FRST lump
- nthorpey
